s1120
- Joined
- Nov 19, 2000
- Messages
- 1,720
- Location
- Columbia county NY
- Tractor
- 87 Ingersoll 444, 84 Ingersoll224/'44 GreavlyL/60'sGreavlyL/49 Ford 8N
Ok sense I am out shopping for a tractor, and a brush hog, I thought I should know how to use it.
I have a lot of saplings in my woods that I want to cut down. Most are about 1in, to 1.5in. Will a brush hog do this? Also do you run into the trees with the tractor to knock them down then mow over them? Or can you back the cutter into them. Seems like you would tear up the tractor running into them.
Any other tips you guys can give me? I don’t have the tractor yet, but it will probably be an older tractor, with out live PTO. I do plan on using an overrunning clutch on it if that’s the case. Thanks for any help, I can use it./w3tcompact/icons/smile.gif
