Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. #21
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,731
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default Re: Rear Ballast Gentlemen, Rear Ballast
    I made the barrell weight, from a $9 55 gallon barrell, with a $26 drawbar, from Tractor Supply. then took a piece of 5/8 allthread bolted thru the drawbar and welded to the rear reciever hitch. then welded rebar on angle to the drawbar and also to the reciever hitch to strengthen it on an angle. the bolted 4 inch angle iron to the drawbar up to the top for a place for the top link to go thru. (between the 2 angle iron pieces). I did not need 4 inch, but it was in the junk pile, and it was what I had handy. I put a layer of 2 inch rock in the bottom. to hopefully make some air space for water to collect if any came down from the 3 2 inch PVC tubes I installed vertically. for shovel/broom/rake handles. then bolted on some hooks for hanging buckets on the outside. filled the whole thing up to about 8 inches below the top with concrete for room to carry other items. The top link goes thru a slot, which is also a drain area for the top 8 inches if left out in the rain. I will try to get the camera out and take pix later.
    James
    K0UA
  2. #22
    Bronze Member Famah's Avatar
    Join Date
    Apr 2010
    Posts
    52
    Wilmot, NH
    2010 Kubota L3700SU
    That would be great. Thank you.
  3. #23
    Gold Member jb62901's Avatar
    Join Date
    Apr 2009
    Posts
    270
    Cassopolis M.
    Kubota BX2360
    Picked up this unit last fall from a Guy who said he had no use for it, was new and never used. Cost Me 25 bucks just fill it with rocks as needed +/-.
    http://i34.tinypic.com/21e6g79.jpg
    09 BX2360 FEL, + Tons of Attachments Many Homemade
  4. #24
    Join Date
    Nov 2006
    Posts
    52
    Columbia Falls, Downeast Maine
    jd 1250 Kobota 5040 4 wd fel cab
    When I made my counter weight I got a 55 gal plastic drum cut the top out. I then got a drawbar from tractor supply, cut holes about halfway up the barrel and slide the drawbar thought. I then welded a 4x4 tube onto the drawbar after I cut holes and the back out so the top link would fit. Filled it with concrete about 6 inches below the top. After it setup I drilled 1/2" holes at the cement line to let any water out.
    The cement being down inside the drum makes for a great place to keep a chain and the water drains out .
  5. #25
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,665
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    ...and also, DON'T forget the FRONT ballast....
    Attached Thumbnails Attached Thumbnails Rear Ballast Gentlemen, Rear Ballast-img_1346-b.jpg
    Runner
  6. #26
    Join Date
    Jun 2009
    Posts
    7,731
    Branson, Mo.
    Famah, here are the pix you requested.
    James
    K0UA
    Attached Thumbnails Attached Thumbnails Rear Ballast Gentlemen, Rear Ballast-dscf0315.jpg   Rear Ballast Gentlemen, Rear Ballast-dscf0317.jpg   Rear Ballast Gentlemen, Rear Ballast-dscf0318.jpg   Rear Ballast Gentlemen, Rear Ballast-dscf0319.jpg   Rear Ballast Gentlemen, Rear Ballast-dscf0320.jpg
    Rear Ballast Gentlemen, Rear Ballast-dscf0321.jpg   Rear Ballast Gentlemen, Rear Ballast-dscf0322.jpg
  7. #27
    Veteran Member Timber's Avatar
    Join Date
    Jul 2006
    Posts
    1,702
    East Bridgewater Massachusetts
    Kubota B7800
    This is mine, It is over 800 lbs. It sits in nice and close and has no top link.
    Kubota B7800, Sundown Loader Forks, Landpride PHD, Sundown 66" Box Blade, 800 pound Ballast Drum with chain storage, ATI Grapple, 60" WR Long Diverter, Landpride Brush mower, 7' Landpride Rake,Manlift platform, Bucket mounted 6' Snow Plow, 3 point Cherry Picker, Subsoiler
  8. #28
    Join Date
    May 2010
    Posts
    69
    Adkins, TX
    Mahindra 3316g
    Quote Originally Posted by k0ua View Post
    James
    K0UA
    I am totally stealing that idea!
    Montyhp
    Montyhp
    So TX
    Mahindra 3316G
    "I'd rather be stupid on the forum than in the field"
  9. #29
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,063
    Somewhere north of Roseau,MN
    Fordson Major Diesel, Ford 1510, John Deere L111
    James
    K0UA
    Very nicely done! I'm also thinking of a barrel weight with top storage.
  10. #30
    Join Date
    Apr 2010
    Posts
    975
    Quote Originally Posted by Timber View Post
    Interesting, looks like it adds a good amount of weight. Does it swing around an bang the tractor? That would be my concern seeing it doesn't have a top link.
Similar Threads
  1. Ballast 4x20 owners, how much rear ballast do you run for the loader?
    By Ramairfreak98ss in forum John Deere Owning/Operating
    Last Post: 12-14-2008, 06:32 PM
  2. Ballast Cheap'n'cheerful rear ballast
    By chelydra in forum Kioti Owning/Operating
    Last Post: 12-12-2008, 08:01 PM
  3. Rear Ballast Weight
    By George2615 in forum Build-It Yourself
    Last Post: 10-31-2008, 10:44 AM
  4. Ballast Rear ballast to offset FEL
    By corwin5 in forum New Holland Owning/Operating
    Last Post: 07-11-2001, 06:54 PM
  5. Ballast B2710 - Rear Ballast for Loader Work
    By DRFoster in forum Kubota Owning/Operating
    Last Post: 08-13-2000, 09:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
