Results 1 to 6 of 6
  1. #1
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default 7.00-12 R1's
    Is this a bastard tire size? I need to put new tires on the front of my JD CUT and it uses 7.00-12 R1's. I've been looking around online and mostly what I see is forklift tires in this size. They are proving to be difficult to locate.
  2. #2
    Super Member 3RRL's Avatar
    Join Date
    Oct 2005
    Posts
    6,825
    Foothills of the Giant Sequoia's, California
    55HP 4WD KAMA 554 and 4 x 4 Jinma 284
    Default Re: 7.00-12 R1's
    Did you try East Bay Tires? Search them up online.
    I bought from them because they had my bastard size tires along with a great selection of others, and they are very reasonable too.
    Rob-
    ...The Older I get...the Better I Used to be...
    Member of the Month
  3. #3
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    I was able to track some down through a local tire dealer. My JD955 is supposed to have 7.00-12's on the front. It's a project tractor and I got it ff the trailer, I noticed that it had two different sized tires on the front ... both of them the wrong size.
    Here's a pic of the 7.00-12 leaning against the 6.00-12 that was on one side:
    7.00-12 R1's-700-12vs600-12-jpg
    And here's the 7.00-12 leaning up against the 6-12 on the other side.
    7.00-12 R1's-700-12vs6-12-jpg
    6.00-12 and 6-12 are not the same.... guess the guy that put these on this tractor didn't know that.
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,774
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    So mechanos. You found the 7.00-12 's you were looking for?
    What does "..got it ff the trailer.." mean?
  5. #5
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by beenthere View Post
    What does "..got it off the trailer.." mean?
    opps... see red correction above.
    no transmission in it. had to get it off the trailer after hauling it home. since the trans was out of it, there was no hydrualic fluid in the system so the steering didn't work. had to put the wife in the seat to work the brakes while I pushed it off the trailer and "steered" it by grabbing the front tires and turning them.
  6. #6
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Now I need to locate some tubes for the new tires. All I've been able to locate locally for the 7.00-12's are "industrial" tubes with a the extra long metal valve stem... like would be used on a forklift tire.
Similar Threads
  1. 12 pin to 6 pin attachment connector
    By overseas in forum Bobcat Construction Equipment
    Last Post: 02-18-2011, 04:02 AM
  2. 12 Volt Refrigerator
    By Derfwood in forum John Deere Owning/Operating
    Last Post: 06-29-2010, 11:00 AM
  3. Sprayer Hi Rate 12 Volt Pump
    By Rockin' G Ranch in forum Attachments
    Last Post: 03-16-2010, 10:17 AM
  4. MF 12 Project & new to forum
    By plugnickle399 in forum General Lawn & Garden
    Last Post: 03-03-2010, 09:06 PM
  5. Turf tires should go, R4's? R1's?
    By irwin in forum Parts/Repairs
    Last Post: 04-03-2007, 06:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
