Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: Mid Mount Finish Mower for quasi bush hog territory.
    I wouldn't hesitate (do it often) doing it with any of my deere 425, 455, or X485 all with 54" decks. The only problem is getting the cut material out the discharge. I have the discharge cover off, but the first pass sometimes the cuttings plug up, and have to clear them by going a couple feet in reverse. Thistles are no problem, but when they lay over, the blades miss cutting them off. So there too, have to back up to get them up into the deck. I've mowed several acres and some prairie trails this summer with the diesel 455 that has the mulcher blades. Handles it with ease.
    Just watch your belts and give it a try, and stop if the mower will not handle it. But I'd at least try.
  2. #12
    Gold Member Jaylegger's Avatar
    Join Date
    Oct 2009
    Posts
    454
    Massey Ferguson GC2600L
    Quote Originally Posted by TripleR View Post
    Well, he has a Massey Ferguson, not a Kubota; not familiar with the deck or belts on that model.
    I took his question as not "could it be done", but "should it be done". I have no doubt my Kubota would do it, I just wouldn't. There is no way I would even consider it with my John deere 2305 as it would overheat and probably burn the belt or cause significant wear.
    You've interpreted my dilemma correctly, there's no doubt I could do it with the MMMM. If I'm lucky the tractor will overheat early in the process and through stroke of luck light the field on fire which will take care of the rest.
    Nightime snowblowing in rain.
    http://www.youtube.com/watch?v=yp50hn8lHf8
    _______________________
    MF2360 Front Snow-blower, 60" MF2340 front blade/Hydraulic angle, Woods BH6000 backhoe, Land-Pride GS1548 Grader/Scraper, 54" 2315 Mulch Mower, DL100 Loader
  3. #13
    Elite Member
    R.I.P.
    ChuckinNH's Avatar
    Join Date
    Jun 2003
    Posts
    3,075
    NH
    (B2620, had BX22) Simplicity Legacy w/48" mmm
    I have used the mmm on my Simplicity for that kind of thing in smaller areas. I've never had a problem, but I go very slowly, and only cut about half the mower width each pass. That makes it easier on the mower, and easier to spot land mines in the field.
    B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, Blizzard 54" 3PT snowblower, Tirechains. com v-bar duo grip chains (hate them), Simplicity Legacy with 48"mmm, turbo collector, Country Line carry all, Countryline Middlebuster, Woods 48" BB, Kubota QA for loader, Kubota forks, Kuhn EL23 rototiller, and more to come...
  4. #14
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,685
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    Quote Originally Posted by beenthere View Post
    You sure have had better service out of your John Deere mowers than I have. My 425 with 54" MMM was always bad to smoke or throw the belt and constantly clogged up when mowing anything heavy. I have had my JD2305 in the shop three times with deck problems and have to blow it out about every hour to keep it from over heating.
  5. #15
    Join Date
    Sep 2008
    Posts
    841
    Central, AR
    You have plenty of power. It will probably work out.
    Bush hogs are great for unknown territory. They are made from much thicker material. They have "stump jumpers" to avoid destroying them on unmoveable objects. They are PTO driven and do not have belts to break.
    I would probably try it with my newly acquired used JD LX279 riding mower with 17 HP and a 48" deck. But if I damaged it I know that I can replace the deck with another used one for $400. Much cheaper than your deck.
    I know that my B21 with a 5' bush hog would do it without causing any problems.
    If your GC is a working tractor and not a perfect garage queen then go for it. If you wax it I would keep it out of that mess.
  6. #16
    Join Date
    Jul 2010
    Posts
    929
    I should add, it wouldn't hurt to walk around a bit and have a look when you get there. We don't have alot of rocks and I know no one is dumping where I mow so I have not run into any surprises. I even mowed a couple acres of it one time when a Scotts 1642 (cheap John deere consumer 16hp single cylinder with 42" deck). The hydrostatic drive was wonderful, I could creep along as slow as I needed.
    Good luck, you'll do fine which ever way you decide to go...
    2007 Kubota L3130, LA723 FEL
    Land Pride FDR1672 rear finish mower, Frontier RB1172, Koyker KB60 BH
    Pallet forks, Golf cart canopy bolted to ROPS, 9" & 12" PHD
  7. #17
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,687
    Bethel, Vermont
    John Deere 4400 MFWD
    None of us can make the decision for the OP, however he is risking damaging a very expensive ($2K plus) piece of equipment mowing this lot.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
  8. #18
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    You sure have had better service out of your John deere mowers than I have. My 425 with 54" MMM was always bad to smoke or throw the belt and constantly clogged up when mowing anything heavy. I have had my JD2305 in the shop three times with deck problems and have to blow it out about every hour to keep it from over heating.
    I guess so. I've had the 54" decks since middle 90's, and to my knowledge have never slipped a belt. Have thrown them off a few times when a stick flips up onto the deck. I leave the belt covers off so I can blow off the tractor and deck after every mowing. Otherwise there can be grass build-up that plugs and rots under the covers.
    I can honestly say I haven't found where these mowers will not go through. But am amazed at the thick tall grass that these mower decks will plow through. I twice a year mow a three acre walnut plantation with no problem, mow between rows of spruce/oak in a 4 acre plantation, and recently broke the trails open at our Town prairie planting (the hired mowing service said they couldn't mow it with their ZTR).
  9. #19
    Elite Member
    R.I.P.
    ChuckinNH's Avatar
    Join Date
    Jun 2003
    Posts
    3,075
    NH
    I don't want to upset any green owners, but the commercial Simplicity, MF, and Kubota decks are built quite a bit heavier than the "C" series JD decks. They are more like the 7Iron in depth, and ruggedness.
  10. #20
    Join Date
    Mar 2009
    Posts
    13,685
    Missouri
    Sure wish mine had worked that well, they have pretty much soured me on the JD in this size. We went with them as we had such good service out of an old 265. We don't even use our 425 anymore and will be selling it this year or next.
Similar Threads
  1. Flail Mower Flail mower vs. rotary? (pros & cons)
    By TerryJ in forum Attachments
    Last Post: 06-06-2012, 09:52 AM
  2. Rear Finish Mower Bush Hog Finish Mower
    By T Nichols in forum Attachments
    Last Post: 04-28-2010, 09:51 PM
  3. Flail Mower Flail Mower vs. Bush Hog / Shredder ?
    By brin in forum Attachments
    Last Post: 04-26-2010, 01:53 PM
  4. Rotary Cutter Bush hog ATH 600 mower ?
    By passgas55 in forum Attachments
    Last Post: 06-08-2009, 07:36 PM
  5. Mid-Mount Mower Mid mount mower for JD4110
    By tld in forum Attachments
    Last Post: 08-23-2008, 05:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
