Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Platinum Member Agrantina's Avatar
    Join Date
    Aug 2010
    Posts
    606
    West Tennessee
    Kubota L3240 GST
    Default 1710 running hot
    I just replaced a friends Ford 1710 water pump, no problems after we got done but after running the tractor for 15 to 20 mintues it starts to get hotter and hotter and stops at 3/4 on the gauge. Gauge is functioning properly and the thing never over heats. We don't know what thermostate degree is in it right now. I see that there are a few differnt degress, 165, 172 and 188? that I can buy. Which should I try? We are in TN so we don't have cold cold weather so I was thinking about the 165? What do you guys recommend?
    Andy G
  2. #2
    Join Date
    May 2009
    Posts
    1,616
    Default Re: 1710 running hot
    In replacing the water pump you may have fixed something that was causing the temp to read low. Most engines run in the 180 - 200 deg. range. 3/4 hot means nothing by itself; it must be tied to a temperature. If you have access to an Inferred Red thermometer, test the temperature at the T-stat housing, it will read close to the T-stat rating. The operating temperature of the T stat is stamped somewhere on the case, it could be in Fahrenheit or Celsius.
    The engine manual is a good source for the T-stat rating.
  3. #3
    Join Date
    Aug 2010
    Posts
    606
    West Tennessee
    Kubota L3240 GST
    O.k will try that, but where or what is the t-stat housing? I would say the thermastat housing. right
    thanks
  4. #4
    Veteran Member K7LN's Avatar
    Join Date
    Feb 2009
    Posts
    1,762
    Michigan
    JD455 & JD790
    Quote Originally Posted by Agrantina View Post
    I see that there are a few different degrees, 165, 172 and 188? that I can buy. Which should I try? We are in TN so we don't have cold cold weather so I was thinking about the 165?
    I would go with the 188* thermostat that you probably have presently installed. The ~165* units went out of vogue when people only had alcohol to use as antifreeze. A 180 - 195 degree range is ideal.
    JD 790 w/70 FEL & 7 BH on turf tires
    JD 455 w/60" MMM & 54" front blade
  5. #5
    Join Date
    Aug 2010
    Posts
    606
    West Tennessee
    Kubota L3240 GST
    That is what the local parts guy said also. We will try that one and see. Is there a Possibility that something else could be wrong? Hoses are new, new water pump... Is there a way to check/ clean the radiator also? The fins look to be in good shape and doesn't look to be clogged up. We checked the temp with a thermometer and its reading 200 when it gets to 3/4 on the guage so it does get a little hotter that it should be. Like I said before it takes it about 20 to 30 mins before it starts getting hot? and thats when you are working with it. If you stop cutting, tilling and let it just run it goes back down to the 1/2 mark on the guage. thanks
    Andy G
  6. #6
    Join Date
    May 2009
    Posts
    1,616
    Good, now we know that the gauge and end temperature are in step.
    A dirty radiator is possible, dirt, seed does get into the air side of the radiator and may be hard to spot.
    I had to take my radiator out to give it a good cleaning. Do not use a pressure washer or you will destroy the fins, a light hosing will do. If you can see through the radiator on many spots it is most likely clean.
    20-30 minims to get to 200 F, on another thought; it is the NORMAL temperature. It takes 30 Min to get to 200F, how hot does it get at 30 min + 10, +20. + 30? If the temperature holds at 200 than you are ok.
  7. #7
    Gold Member
    Join Date
    Nov 2009
    Posts
    331
    Wichita, Ks. metro area
    Kubota B1750HST
    Were you able to get all of the air out of the cooling system?
  8. #8
    Join Date
    Aug 2010
    Posts
    606
    West Tennessee
    Kubota L3240 GST
    Not sure what you mean? How do I do that?
    Andy
  9. #9
    Gold Member ampa's Avatar
    Join Date
    Feb 2009
    Posts
    456
    Loosin' the rad cap so as it's just sittin' in it's unlocked position, start up the ol' tractor let it run so as to reach opening temp (180-200) the air if any will flow out as well as some of the coolant, but will ease up when most or all the air is out......hope this helps.......Ampa
  10. #10
    Gold Member
    Join Date
    Nov 2009
    Posts
    331
    Kubota B1750HST
    Exactly as AMPA says. Leave the cap off and watch the coolant for signs that the t-stat is opening and closing (fluid level dropping). You may want to add coolant at that time. It may take 10-15 minutes of idle time to burp the air out of the system.
Similar Threads
  1. Kohler running on one cylinder
    By jdgreg in forum Parts/Repairs
    Last Post: 08-04-2017, 04:09 PM
  2. Kioti LK3054 4WD diesel not running
    By Teri in forum Parts/Repairs
    Last Post: 09-19-2012, 11:25 AM
  3. Oil & Fuel Kubota M105s, Hydraulic Oil HOT!!
    By KyDiesel44 in forum Kubota Owning/Operating
    Last Post: 06-05-2010, 11:23 AM
  4. MF-205 Industrial Trans Won't Engage When Hot
    By jfharper in forum General Vintage Tractors
    Last Post: 05-04-2010, 06:05 PM
  5. 3184 running kind of hot
    By Suribachiae21 in forum Cub Cadet Tractors
    Last Post: 05-10-2008, 08:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
