Results 1 to 10 of 72
09-06-2010, 09:16 AM #1Elite Member
- Join Date
- Aug 2007
- Posts
- 3,712
- Location
- Ontario Canada
- Tractor
- Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
Stuck partly in pond. 2nd time I've done this
Hmmm, I never said I was so smart!
God Bless our brave men, bring them home, safe again.
09-06-2010, 09:35 AM #2Veteran Member
- Join Date
- Sep 2002
- Posts
- 2,189
- Location
- Southeast PA
- Tractor
- John Deere 2520, John Deere X534, Gator HPX 4x4, 14SB, Honda TRX 420 FE
Re: Stuck partly in pond. 2nd time I've done this
YIKES!!!
"Nothing so needs reforming as other people's habits."
Mark Twain
09-06-2010, 09:37 AM #3Elite Member
- Join Date
- Aug 2007
- Posts
- 3,712
- Location
- Ontario Canada
- Tractor
It was not easy to get out either!
09-06-2010, 09:38 AM #4Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,460
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
Looks like you have some sticky soil but what type of tires are them? Looks like R4's on the front but the rears look like Turfs?
Chris
09-06-2010, 09:39 AM #5Member
- Join Date
- Jan 2010
- Posts
- 35
- Location
- colorado
that is stuck....
does your tractor have a big brother who can pull him out
09-06-2010, 09:39 AM #6Super Member
- Join Date
- Feb 2006
- Posts
- 6,764
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Steeper than it looks and mushy due to the vegetation holding the water. Maybe a bit of sand and gravel after you get it mowed. That is a flail on there isnt it?
larryThis side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, Flail,
SK Tilt Tatch
, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
09-06-2010, 09:42 AM #7
Been there done that ... a wrecker and $70 solved the problem.
09-06-2010, 09:46 AM #8Elite Member
- Join Date
- Aug 2007
- Posts
- 3,712
- Location
- Ontario Canada
- Tractor
The rear tires are R4 slicked up with mud! The implement on the back is a box blade pretending to be an anchor. That particular area of the pond is pure sand but I slide so far in that I got into the clay a bit. A pure recipe for stuck if ever there was one.
I had to get a skid steer over because the flat on top of the bank is very short and then the forest starts. The problem we had was the rears of the skid steer would come up off the ground when we tried to pull and we'd lose traction. It took patience, perserverence and two shovels to get her out.
What happened was I like to keep that bit of the bank clear. Every now and again I grade it with a rear blade. This time I went back too far because the box blade is not near as far out behind as the regulat blade. The wheels sank in, the tractor was bottomed out, the blade was embedded. A perfect setup if I do say so myself.God Bless our brave men, bring them home, safe again.
09-06-2010, 09:49 AM #9Gold Member
- Join Date
- Apr 2010
- Posts
- 287
I saw a late 60's Case backhoe in that situation when I was surveying on a highway job. The operator asked a D10 Caterpillar to back down and give him a tug with his winch. The guy wrapped the cable around the front axle and gave the D10 operator the nod. Next thing we saw was a couple of gallons of engine oil spilling from the cracked block. Turns out the engine held the Case front end to the back end. The suction of the muskeg was more than the casting could handle, though the D10 didn't care, either way.
Last I saw of the hapless backhoe operator he was walking over the hill on his way home. He knew he was finished.
09-06-2010, 09:53 AM #10Gold Member
- Join Date
- Mar 2008
- Posts
- 258
- Location
- Ohio
Similar Threads
Buying advice and the best time of the year to buy needed.
By EddieWalker in forum General Lawn & GardenReplies: 17Last Post: 08-20-2008, 08:21 AM -
New Pond
By mrolson in forum ProjectsReplies: 106Last Post: 09-09-2003, 12:45 AM -
JD 4000 series wheel bolts
By Anonymous Poster in forum John Deere Owning/OperatingReplies: 5Last Post: 04-13-2002, 10:56 AM -
History of Time...
By JohnMiller3 in forum Related TopicsReplies: 1Last Post: 04-07-2002, 06:09 PM -
Time of Day
By Muhammad in forum News/FeedbackReplies: 9Last Post: 08-10-2001, 01:05 PM
