montelatici
Any good and do they make them to fit a loader with tooth bar, without removing tooth bar?
Not sure about toothbar applications. I will tell you that I have a set of light duty (800 lb.) Paynes. The clamp ons always want to twist sideways if you don't hit your target squarely. I've welded some angle iron "wings" onto them and it helps somewhat but doesn't eliminate the problem.
My goal is to eventually convert the bucket to skid steer attach and then purchase a separate set of forks. Much better visibility and stability if you don't happen to get into a pallet (or other load) just right.
Thanks, I have a quick connect on my L3700SU, but the pallet forks for a quick connect are so much more expensive. I was just trying to save a buck.
I can speak only for myself but the set I have can be put on over my tooth bar. Actually the tooth bar helps keep them in place.
Al
Same here. Mine chain on with load binders. You can put them anywhere between the teeth.
