Results 1 to 10 of 43
09-16-2010, 02:04 PM #1
Tire Chains - best style
What would give better grip climbing hills: a duo-grip or 2-link ladder chain?
I'll be climbing a gravel driveway that has a fairly steep section with my 4x4 Kubota (w/ turfs), and will be pushing a 650# snowblower in reverse. I'll probably put chains on both front and back, but hope to get a freebie set of truck chains that I can kludge onto the front wheels. I was originally planning on a 2-link ladder chain for the rear, but saw the duo-grip chains which look pretty cool and are cheaper, although they don't appear to have as many cross-links as the ladder.
41-14-20 Tire Chains
I've never bought or used chains on my tractor before, so any other relevant advice is appreciated.
thanks - JayC
09-16-2010, 04:39 PM #2Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Re: Tire Chains - best style
I would definately go with an "H" pattern like the "duo-grip" with either v-bars or studs. Mine has welded studs and they make my tractor virtually unstoppable on ice and snow. Good in the woods to but not for asphalt.
They are made in Norway. Brand name is Tellefsdal and were less money through my dealer than any internet chains I could find.
Here is a picture I had from this spring. Blow it up to get a good look at the chains."If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
09-16-2010, 04:59 PM #3
Hey Gordon -
Yup - those chains ARE nasty alright. Nice road grader too - is that a DIY?
I tried to find distributor/dealer information for Tellefsdal chains in the USA, but had no luck. Do you have any contact information I could try?
What do you suppose those chains would do to concrete? I park my tractor in a concrete-floored garage bay.
JayC
09-16-2010, 05:05 PM #4Veteran Member
- Join Date
- Feb 2004
- Posts
- 1,049
- Location
- Vanderbilt, Michigan, USeh?
- Tractor
- Mahindra 5035, JD 2240, 420
I have chains simular to the Duo-grip with bars. The bars really chip up the concrete in the pole barn. Since I park in the barn, if I ever bought new chains, I would go without the bars. But, heh, that is just me....
2011 Mahindra 5035 HST/loader/595 hoe/18" bucket, 48" QA forks, 1981 JD 2240 Reverser 51ptoHP/2.5 tons of snarling fury, 6' Ford backblade, 30" reinforced dirt scoop, homemade boom, 79" JRW rear snowblower, Son of Jinma 8" chipper, 2002 BR Dodge Cummins H.O. 6spd.
09-16-2010, 05:45 PM #5JCBGuest
2 link ladder chains on my truck are pretty awesome and I'd recommend them for anything, but gordon's chains look nasty and probably have even better grip.
That said even standard chains are a huge improvement and if you are parking on concrete pay heed to what Jerry said.
09-16-2010, 05:59 PM #6Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
I bought my chains through Desmarais Equipment in Orleans, VT.
802-754-6629. Andy is a good guy to talk to. There is a distributor in Manchester, NH. Will have to get back to you on info there.
I also park in garage. I put down an old piece of plywood on concrete floor."If you're not making any mistakes then you're not doing anything"
09-16-2010, 06:34 PM #7
The two link chains may be smoother on hard surfaces. I use 4 link V-bar front and Duo-ladder combination chains on the rears. Work very well in anything I've encountered. The V-bars do dig in a lot. I cover concrete with some old plywood (and just move a couple of pieces to drive out) to prevent damage.
09-16-2010, 07:07 PM #8Bronze Member
- Join Date
- Sep 2008
- Posts
- 87
- Location
- Quebec, Canada
since we are on the subject of protecting concrete. just thought I would share my experience.
I used to work at a ski hill driving the snow cats grooming the trails and they had carbide ice picks on the tracks that would shatter the concrete so when we pulled them into the garage for maintenance we drove them up on sections of old conveyor belts from a quarry. That saved the concrete.
I suppose those horse stall mats or rubber mats for stairs would work also. the conveyor belts where only about 3/4 inch thick but they did the job and looked cleaner than a bunch of plywood lying around.
although plywood is cheap if you have some scraps lying aroundJames
KUBOTA B7800, LA402 FEL, LAND PRIDE BB1560, PRONOVOST PUMA-64
JD X320, POWERFLOW BAGGER
09-16-2010, 07:13 PM #9Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,922
- Location
- Foster, RI
- Tractor
- JD 750
Any chains will help a great deal. I have 4 link regular chains on all tires and even these made my tractor virtually unstopable when pushing snow or skidding logs in snow and ice. I have ags on my tractor and found the chains to fall nicely into the ground as the tires rotated. I do not snug up the chians any more tightly than I can by hand meaning I do not use a leverage device.
09-16-2010, 07:17 PM #10Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
Could not find the info on the distributor in Manchester, NH. Sorry. It was an old e-mail. I e-mailed a question to Norway and the response came back from Manchester.
Similar Threads
Chains Tire Chains for 4520
By jcmseven in forum John Deere Owning/OperatingReplies: 1Last Post: 09-26-2005, 10:36 PM -
Chains Tire Chains
By ThisldooFarm in forum Owning/OperatingReplies: 30Last Post: 02-24-2005, 08:05 PM -
Chains Got tire chains for x-mas, now I have questions
By Todd_C in forum Owning/OperatingReplies: 9Last Post: 12-26-2004, 11:51 PM -
Tire Chains
By dj1701 in forum AttachmentsReplies: 17Last Post: 09-27-2003, 08:42 PM -
Chains Another tire chain post: "Roller" tire chains
By hazmat in forum Owning/OperatingReplies: 16Last Post: 02-12-2003, 09:19 PM
