Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
  1. #11
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    Default Re: Spreading Stones Technique
    A shot of the same side, from the opposite end after I had filled in about half of the washed out area.
    Attached Images Attached Images
  2. #12
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    The first side is almost done.
  3. #13
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    This is the far end of the first side where the corner was almost all washed out.
  4. #14
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    Part way through doing the same thing to the opposite side.
  5. #15
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    Three and a half hours after I started, 22 tons of stone are gone. It was enough to fill in all the washed out areas and put a 1 inch layer on about 20% of the ring.
    The method which seemed to work the best, which several of you recommended, was to dump the bucket while backing up. Then move forward to where I started, lower the bucket, put it in float and back drag. I had all the tractor lights on by the time I finished. If it doesn't rain tomorrow, I'll do some more smoothing with the FEL and also pull the drag harrow over it.
  6. #16
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    BUFFALO ,NEW YORK AREA
    kubota b2400- R4 tires
    if what u are trying to fill is fairly even then go option #2 u can easily spread stone with this method. shake it out then use the back edge of the bucket to get it level, think u will be suprised what u can do with just a little pratcice.
  7. #17
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,747
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    You might be better off going by cubic yards than tons.
    If my math is correct(and there is a good possibility that it ain't) find the square footage of your ring and divide it by 324. That should be how many cubic yards of material you will need to cover it one inch deep.
    Formula:
    1 cubic yard equals 27 cubic feet.
    1 cubic foot will cover 12 square feet 1 inch deep.
    27 x 12 = 324
    Hope this helps [img]/w3tcompact/icons/smile.gif[/img]
    Thanks for the picks. They look great.
  8. #18
    Join Date
    Mar 2002
    Posts
    49
    Fairfax Station, VA
    Kubota BX22
    I just recently put down 15 tons of river rock (about 1" in diameter) with by BX22 FEL. What really worked for me was to have the toothbar attached to the loader. Then I was able to 'rake' the rocks back to a smooth and even finish by using the teeth on the bar as a rake. Didn't take long at all.....in fact, I was done so fast that I was kinda looking around for more to do !
    _Duane C.
  9. #19
    Veteran Member gerard's Avatar
    Join Date
    Apr 2000
    Posts
    1,681
    Syracuse NY
    Kubota L2500DT w/FEL
    Mike, other than your estimate being off (We did an 80x 200 outdoor with 2 inches of sand and that took well over 100 ton) save yourself some grief and try and finagle a backblade with skid shoes. Worked even better than the box blade (I have both). Set the skid shoes to the hieight you want and drive. Great for sand or stone dust. Looks like a pool table when your done. I don't care how good you are with a loader you're not going to get a perfectly uniform 1 inch layer without some type of guide/skid shoe set up (Of course you could rig up a temporary gauge to the loader if you want to but a back blade with shoes is the easiest)
  10. #20
    Super Star Member
    Join Date
    Apr 2001
    Posts
    12,096
    PA
    NH TC25D
    gerard, thanks for the tip. I have a Woods RB60 rear blade so all I'd need to buy are the skid shoes. I'll give my local Woods dealer a call tomorrow and order a set.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
