Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Gold Member
    Join Date
    Apr 2002
    Posts
    316
    Peabody, Ma.
    KUBOTA BX-22
    Default Re: Stump Digging
    I'm in the process of making a ripper tooth that will go on the backhoe after removing the bucket. it is 18" by 5" and 1" thick has an 82 degree knife edge that I hardend to a 65 rockwell to hold the edge sharp. I will be welding the mounting plates onto it at work tomorrow. I'm hoping to stick it in the ground and curl the the blade just like the bucket and cut the roots. this should put all the force on the knife edge with success I hope. I do not have a digital camera yet but drew up a picture to show what it looks like.
    Attached Images Attached Images
  2. #12
    Join Date
    Oct 2002
    Posts
    65
    Cut -N- Shoot Texas
    '02 JD 4110 HST
    Good idea on the Hoe attachment. I am starting to realize that the most useful attachment for a tractor is a welder...LOL
  3. #13
    Join Date
    Jun 2002
    Posts
    873
    N Central Ohio
    NH TC35D/SUPER H&M/F-20/JD B&D/FORDSON/JD250 SSL
    AND SOMEONE THAT CAN OPERATE THE HOT GLUE GUN.
    LOL
  4. #14
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    On our large backhoes for road construction, etc.. We have some units equipped with a 'thumb' to grab rocks /limbs easier.
    Have also seen a scisor attatchment... consisted of 2 fixed blades, and i moving blade that scisored in between the clearance of the other two blades. Worked well on 4" - 6" stuff... any blade should be good on roots, etc
    good luck!
    Soundguy
  5. #15
    Join Date
    Jan 2001
    Posts
    21
    Raleigh, NC
    3710HST
    Or if you don't have a beater chainsaw, take a couple whacks at the taproot with a sharp mattock after you expose it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
