Results 111 to 120 of 221
01-09-2011, 06:22 AM #111Elite Member
- Join Date
- Nov 2005
- Posts
- 2,838
Re: Logistics of firewood hauling and splitting?
"or some other type of equipment"
ONE draft horse - though this is probably not what you wanted to think about (-:
There are still some folk who do this, SOME could almost be described as "hobby loggers", they just like working the woods with horses.
That doesn't mean they're available for exploitation, but you might be able to have them get wood out for quite a bit less per cord than anyone else would do it for.
Option B; Cables, winches, chains, but you are probably looking at a LOT of length for that, i.e. CO$T.
01-09-2011, 08:15 AM #112Veteran Member
- Join Date
- Dec 2006
- Posts
- 1,530
- Location
- South of Rochester, NY
- Tractor
- Power Trac 1850, NH 2120
I use the Honda powered portable winch with a 300' rope and pulleys when necessary. I almost bought a 600' rope but i have not needed more than 300' so far since i have trails at the tops of the ridges. It has pulled 24" diameter logs up with no problems. I liked it so much that I became a dealer.
KenPT1850, mini hoe, grapple, knuckle boom, stump grinder, brush hog
http://www.usadiscountgenerators.com...T1850Home.html
01-09-2011, 08:42 AM #113
I have some trees that are quite a distant in the woods from the edge of a field. I have some very long heavy rope that an electric company lineman gave me. Question is what kind of a knot do I use on the rope, so it can be untied after tighting up? And how do I tie this knot? I'm thinking back to my Boy Scout days and a bowline knot comes to mind, but not sure.
Thanks for all the great information that comes from here.
Clayton, with a 4200 John deere and a 3point splitter.
01-09-2011, 08:47 AM #114Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
You can use a portable winch as said above. If you get one this is a good setup for it. They are a little expensive but might be worth it to you. Look in Baileys for one also.
I'm not a boy scout but I just have a small loop in the end of the rope with a surgeons knot. Push the rope through the loop to make a choker.You dont have to tie the log on each time.
The surgeons knot gets pretty tight with time but can be untied with persistance or .... a knife"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
01-09-2011, 08:54 AM #115Veteran Member
- Join Date
- Dec 2006
- Posts
- 1,530
- Location
- Tractor
01-09-2011, 10:47 AM #116
Yep "bo lin".
I am a "hobby" logger in my own forest. There is very little flat ground on my farm and where the good firewood is located is NOT it.
I burn firewood to heat my home and put up prox 40 cord this year.
I enjoy the work so much, I WISH I could get my neighbors to ask me for help on interesting "technical" pulls..........
I use a farmi 601 with a big 100hp 4wd tractor. Fun times!!!!!!!!!"We a two tractor family"
01-09-2011, 11:06 AM #117Platinum Member
- Join Date
- Nov 2005
- Posts
- 653
- Location
- Southwestern, PA
- Tractor
- 1958 Ford 961 Powermaster
It seems like most people are cutting live trees instead of dead/dried still standing trees. Is there a specific reason for this other than not enough dead trees to supply the demand?
Kubota L5240 with loader and backhoe
1958 Ford 961 Powermaster LP
01-09-2011, 11:21 AM #118Elite Member
- Join Date
- Oct 2004
- Posts
- 2,895
- Location
- limerick pa lycoming county pa
- Tractor
- kubota bx23
figure eight knot
How to Tie a Figure Eight Knot | eHow.com
there are some youtube instructions too
I use them to pull wire at work the other one is a tracer eight puts aloop in the end of the line
tomIf it ain't broke we will help you brake it
If it is broke we will help you get it fixed!
01-09-2011, 11:25 AM #119
Most of what I take for firewood is spars........... THAT is why I need the equipment I have. They are where they are and I need to get to them.
When I take live stuff it is because of maintenance and caring for my orchard. Over years trees encroach the orchard........ THAT is where I draw the line."We a two tractor family"
01-09-2011, 02:29 PM #120
Ever hear of widow makers ? they are found more on dead trees the live.
As for the dead trees, you need to ask yourself why is it dead? Its mostly because of bugs or disease. Many states now have laws on "transporting" dead or diseased trees. Quite ofteen they say diseased wood cannot be moved more then 50 miles, or cannot bring outside wood into state parks, etc. I can go on and on as it varys from state to state but how often do you see the rules/law being enforced?
