Page 18 of 27 FirstFirst ... 815161718192021 ... LastLast
Results 171 to 180 of 261
  1. #171
    Platinum Member Dead Horse's Avatar
    Join Date
    Feb 2009
    Posts
    670
    New Hampshire
    Default Re: Logistics of firewood hauling and splitting?
    Quote Originally Posted by Lumberjack1903 View Post
    Cool thread, glad I found this one. This is mainly what we use our tractors for. For the smaller stuff the bucket works well, but for largers rounds we use logging tongs on the 3pt boom. Quick loading and unloading when you stack 'em like this on the trailer!
    For moving rounds that size I bucket them out of the woods to this.
    From there they go to the splitting yard. I only use this method when I cannot skid the whole tree out for some reason.
    Attached Thumbnails Attached Thumbnails Logistics of firewood hauling and splitting?-big-bess03-jpg   Logistics of firewood hauling and splitting?-big-bess01-1-jpg
    "We a two tractor family"
  2. #172
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,172
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by SpringHollow View Post
    In my woods, the trails are so muddy that most of the time you can not get a tractor down into them.
    Ken
    Pls tell us what tire tread you are using on your tractor.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  3. #173
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    It is one of the "fake" ones. A true 5 HP would be nicer but I have split about 20 face cord with it as it is.
    Ken
    Just wondering if you have ever put an amp clamp on the thing and watched it while running. And how many GPM is the pump. I would just like to know how many amps she draws.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #174
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,172
    VA
    Quote Originally Posted by LD1 View Post
    Is that a true 5HP motor. Like a farm-duty TEFC type. Over 100lbs
    or
    Is is one of them air compressor type motors That really arent 5HP and only weigh 30-40lbs??
    .. Hey LD! .. Pls note that true 5hp 3450rpm motors do weigh around 40lb. Check the current specs for reality. A true 5 is going to use more than 5kw. ... so near 25A @ 220V. compressor duty is a scam. [] Wish I knew, rather than suspected, the rationale behind the rating.
    larry
    This side of 40
  5. #175
    Veteran Member SpringHollow's Avatar
    Join Date
    Dec 2006
    Posts
    2,293
    South of Rochester, NY
    Power Trac 1850, NH 2120
    It is a GE 5 HP compressor motor with a face plate rating of 15 amps which lets me run it on a 12 gauge extension cord replugged for 220V. I have not hooked it up to an amp meter.
    The pump is a Haldex Hydraulic Pump 16 GPM, 2-Stage, Model# 1001507
    Ken
    PT1850, mini hoe, grapple, stump grinder, brush hog
    http://www.usadiscountgenerators.com...T1850Home.html
  6. #176
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Ken
    The reason I as is because we briefly tried a 5HP compressor duty motor on our 11gpm logsplitter. With the ram all the way extended and keeping on the valve to build max PSI, the amperage draw was 20-21 Amps. Now in reaity, you are not building full PSI 90% of the time. You will only build enough to do the work at hand. But you also have a larger pump too.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #177
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by SPYDERLK View Post
    larry
    Can you post a link to a TRUE 5HP farm duty type motor TEFC that only weighs in at 40lbs
    BALDOR L3708T
    Weighs 117lbs and FL Amps of 20.5 with a SF of 1.15. Gives you the ability to pull 23.5 Amps before any harm is done.
    A motor like this Marathon Electric 5 HP Electric Air Compressor Motor, 56 Frame - 3241192 | Tractor Supply Company Also rated at 5HP only weighs 40lbs. FL Amps of 15 and a SF of 1 means ANY time you exceed 15 amps shortens the life of the motor.
    BIG difference in these two "5HP" motors.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #178
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,172
    VA
    Ken
    You can run any true 5HP 220V motor on 12ga. Youre only drawing 25-30A. An open air run of 12ga will handle that easy. Running 12ga in a wall, or for any long run is where you would have a problem at above 20A. The wall run could be dangerous because of heating.
    larry
    This side of 40
  9. #179
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Ken
    larry
    Just another curious question. What sized breaker are you protecting that with?? Because even though your nameplate says 15A, I bet you often are pulling over 20A. Electric motors dont stall very easily. The locked rotor torque is usually 2-3 times the stated amperage. So a 15A motor WILL do the work required by say a 25A motor just by drawing more amperage, it just wont last long.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #180
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    LD, that makes me think I could substitute a 220v 5 hp heavy duty motor for my 7 hp Briggs and have a quieter splitter. Pump is 13.x gpm 2-stage barnes jobby. I know this has little to do with the thread topic...
    Jim
    "Anything worth doing is worth doing slowly" Mae West
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
