Results 31 to 40 of 221
10-19-2010, 06:42 PM #31
10-19-2010, 08:29 PM #32Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
Re: Logistics of firewood hauling and splitting?
Chilly - Do those four legged things I see with the blankets on them get involved in the firewood business? BTW I like your northern woods.
Here is my splitter - cycle time is slooow. My internal hydraulics aren't what they used to be
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
10-19-2010, 10:41 PM #33
We have a couple that can be "helpful", one youngster in particular likes to move things when you're not looking.
Have you ever looked at the electric over hydraulic splitters, Gordon? It's all we use these days, will split 90% or better of whatever we stick in it. A fraction of the cost of gas or 3ph splitters.
I started splitting with an axe a lot of years ago, I can still do it if the mood strikes me. I actually enjoy it for an hour or two.
The woods aren't too bad, but the areas we're cutting in should have been thinned before now, a lot of windfalls and blow-downs. Hard going with anything but a winch, we use the ATV or tractor with a snatch block to get the wood out to a hauling road and go from there.
Sean
10-20-2010, 07:07 AM #34Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
I have never seen the electric over hydraulic splitter. Right now I am looking for a splitter. I find all the info and pro/cons on splitters here very interesting and informative. Right now I think I would like a stand alone unit but would not pass up a good deal on a 3pt splitter. I will check out the electric over hydraulic ones. Thanks
gg"If you're not making any mistakes then you're not doing anything"
10-20-2010, 09:07 AM #35Silver Member
- Join Date
- Dec 2007
- Posts
- 140
- Location
- Coventry, CT
- Tractor
- Kubota B7800
Greenspot,
Could you please post some more photos of your log hauler?
It seems to have a hinged section. How does it all work?
Thanks,
BillBill Hoffman
B3030HSDC with loader, quick hitch, rear blade, rear rake, boom pole, clamp-on forks. Kubota Zero turn mower, Cadet 1811 w/MMM and a bunch of other stuff.
10-20-2010, 10:50 AM #36
I have tried several methods, re: the original question, with the goal of minimizing the amount of handling.
When logging where it is tight, I have cut to rounds and loaded into a dump truck, to haul to the splitting yard.
Now, after a couple years of running it, I have gotten good at skidding out logs, even in tight spaces, with a big tractor and a Farmi J601. So pretty much that is the preferred set of tactics. Fell, inch, limb and chip in situ. Skid to the splitting yard, buck ssplit and stack.
Pictures tell the story. I put up 40+ cord this year.
Second to Last pick is the '68 F800, off to the left...... good ole "yard truck"
"We a two tractor family"
10-20-2010, 10:51 AM #37Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
I've yet to see an electric splitter that wasn't very, very sloooow. And it required two buttons to be pushed simoultaneously to operate them. I've looked at the electric to use in the garage during the winter to further break down split wood for some smaller kindling-sizes, but know they are much too slow to do much production work. For sure, a bench would be needed to get the little things up off the ground. Watching some of the videos of their operation, makes ones back hurt as they are on hands and knees, or stooped over pushing the two buttons.
Maybe there is a splitter "electric over hydraulic", but I'm thinking that Chilly807 meant "electric versus hydraulic".
10-20-2010, 10:58 AM #38Gold Member
- Join Date
- Mar 2009
- Posts
- 307
10-20-2010, 01:13 PM #39
Well, on and off since April, in between, other chores. I have an apple orchard I care for, about 45 acres, between meadows and trees. That plus about 60 acres of forest.
So between brush cutting, mowing, equipment and facility maintenance chores, I squeeze in firewood production, weather permitting.
Getting the process down to a fine science is important for me as I would otherwise spend more time on it than I would prefer.
I heat my rather large home with firewood, via a Central Boiler...... making the whole cycle quite rewarding to me. I never know how much time I am going to have to spend on the farm, so this year i really put my shoulder into it.
10-20-2010, 01:18 PM #40
Mine has an electric motor running a hydraulic pump, 4 tons of splitting force. Not much compared to the 15-20 ton gas models.
However, for the 4-5 cords we cut every year, it works fine. Occasionally a big snarly piece of wood gets set aside for the chainsaw, but that's ok with me. The two-button system is easily "got-around", mine has a spring holding one lever depressed, just one finger required to run it.
We split all our wood within 100 feet of the house, so power is never an issue. I have a folding table the splitter sits on, the splitter stores under the bench in the garage. I think the cycle time is about 12-14 seconds, which is fine if you're not in a hurry. One person splitting and the second one stacking makes for a comfortable pace for everybody. $379 Cdn at Home Depot. No gas fumes, no noise, and you can chat while you're splitting wood if you choose. Splitting kindling in the garage or basement is do-able in the dead of winter too.
Now... if you're going to split more than 5 full cords a year, if you're in a hurry, or if your wood is more than 12-14 inches in diameter, it's not the right tool for you.
There are 220 v models with considerably more power and speed, in time I'll build one of those as the parts appear. For now, I'm happy with the one we have, which is a Ryobi. I think the same splitter is sold as Homelite now.
Sean
