whodat526
how does the combustion not reach the cylinder walls if it does why do they need such big piston and cylinders and why is there always carbon build up along the side of the top of the cylinders
Pyrolyzed oil. This is the hottest area on the walls, and the annular area between the cyl and the piston above the top ring captures a small amt of the hot power stroke gases. When crossing TDC [or BDC] there is long dwell in the position compared to other stroke points. The long period spent in the hot area near the head causes pyrolysis of the minute oil/gas there. Since the rings never scrape there it builds up til it almost touches the piston. At that point the area becomes violently scavenged on each stroke enforcing an equilibrium between growth/loss.how does the combustion not reach the cylinder walls if it does why do they need such big piston and cylinders and why is there always carbon build up along the side of the top of the cylinders
Size of piston/cyl is there to give force from the combustion pressure. The extremely thin area not combusted in a warmed engine makes little difference in force and power.
larry
from what u just stated how i read it is that combustion does use the complete cylinder. And since diesel is sprayed all over the cylinders diamater it use the whole cylinder to fire not just the middle right or does the diesel just drip into the cylinder when it opens
The diesel is sprayed in at near TDC into the highly compression heated air in the cyl. That air is so hot the fine spray injection ignites and burns. I think injection continues for a small part of the power stroke. This can happen because injection pumps deliver higher pressure than the pressures reached in the cyl at full throttle. So ... no dripping -- a fine spray to maximize ignition and burning. A diesel is superior this way because the fuel is injected during the burn. The part of the fuel that doesnt burn [if any] is the portion that ends up very close to the cyl wall before it is totally burned. This tiny thickness of poor to no burn is not enuf to really matter -- 99&44/100ths % of the cyl is used. The point I was making is that the flame stops just short of touching the cylinder wall.from what u just stated how i read it is that combustion does use the complete cylinder. And since diesel is sprayed all over the cylinders diamater it use the whole cylinder to fire not just the middle right or does the diesel just drip into the cylinder when it opens
Its a matter of degree as to remanent oil film left by rings. And it may be hard to accept, but the combustion does not reach the cyl walls. They are "cold" and the mixture near them is poor due to being stagnant. In a truly cold engine the flamefront stops well short of the walls [a few thousandths "]. At operating temperature it gets closer, but the combustion cycle is so short the flame still cannot breach the proximal growingly stagnant area. The best way I know to see a demo is to wave your propane torch across a piece of hot oiled metal. It wont burn the oil unless you expose it to the torch much longer than a power stroke takes.
larry
