Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Feb 2009
    Posts
    1,874
    Northern NY
    Kioti CK27, 1940s Farmall A
    Default loader problem found
    On a recent visit to my brother we noticed a loose bolt on the loader mount. On closer inspection we found it was very close to becoming a major problem (damage wise and possible injury) There were 3 missing bolts and 8 were sheared off. Not much left holding. We were able to make the repair (lots of hours getting old bolts out and actually did a little modification. The tractor is a 30 hp 4wd - no need to mention make - don't need a fight. (not a Kioti) I will say that when I returned home I checked and torqued my mount and all was fine. Just a reminder that may save someone a problem. Check for loose bolts.
    Loren
    Kioti CK27 gear w/Loader
    1940s Farmall A
    12 acres, wife and dog Phoebe
  2. #2
    Join Date
    Nov 2010
    Posts
    125
    Holly, MI
    Kubota L2850 Hydrostatic/ Deere 5410 w/loader
    Default Re: loader problem found
    While replacing clutch on my tractor also found 3 loose loader bolts and one broken bolt.
    The three loose bolts showed major wear marks. The loose bolts were replaced but still need to extract broken bolt.
    Very surprised to find these bolts loose and so worn. Photo shows the bolts that were at issue. All the other bolts were tight.
    Attached Thumbnails Attached Thumbnails loader problem found-loader-bolts-loose-jpg
    MichKubota - L3650GST, L4150DT, Gannon Box Blade, York Rake
  3. #3
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    This is what causes 95% of the broke bell housings on tractors. Does not matter what brand it is. I have seen just about every color with a broken bell housing and its usually found when its too late that loose or broken loader bolts are the culprit. Going over everything once a year will prevent all this.
    Chris
  4. #4
    Platinum Member BTI's Avatar
    Join Date
    Feb 2002
    Posts
    783
    Nelsonville, Ohio
    CK20S Hydro TLB-LK3054-CK30H
    Loader attachment bolt re-torques are some of the most forgotten things.
    When we service tractors they always get re-torqued.
    You can always tell who re-torques bolts.
    Almost all tractor loader frames attach the same way.
    Make doesn't really come into play here.
    They should be part of every owners maintenance program.
    That reminds me I need to re-torque mine LOL
    BTI
    BTI
    *******The poster formerly known as Kiohio******
    740-753-9242
  5. #5
    Join Date
    Apr 2010
    Posts
    975
    Good reason to continue using locktite on all bolts. Actually, either locktite them because you don't want them to come off or neverseize because you do.
  6. #6
    Join Date
    Feb 2009
    Posts
    1,874
    Northern NY
    The person I worked with on my brothers tractor (20 years working on tractors) does not put locktite on the bolts. Feels it makes it too difficult to remove if they fail. He has had good results with clearing paint from all contact surfaces of mounting bracket and applying a coating of locktite to these. In theory to act as an adhesive. He also likes to use grade 8 flat washers as he's feels that soft lock washers can compress and result in the loosening of the bracket.
    He claimed that he has had no failures when he remounted in this way. We also installed an extra grade 8 bolt in a newly drilled hole in the forward part of the bracket (original had one soft bolt in a sloppy hole)
    Just thought I'd throw this out there.
    Loren
    1940s Farmall A
  7. #7
    Join Date
    Sep 2010
    Posts
    112
    Mahindra 4025
    My dealer occasionally reminds me to keep an eye on my loader nuts. For sure, if you're lifting half a ton of rocks and one of those bolts suddenly comes loose, you're going to have a MAJOR mess on your hands.
    - Ruark
  8. #8
    Gold Member Happyman's Avatar
    Join Date
    Jun 2008
    Posts
    478
    Kents Store, Virginia
    Kubota Grand L 3940
    Quote Originally Posted by BTI View Post
    BTI
    I re-torque loader and wheel bolts at least once a year as part of the major fluid change schedule. Haven't found any loose yet, but was told by my dealer that loose loader bolts is very common and a cause of severe damage to the tractor. Preventive maintanance is where's it's at
    Grand L3940 HST, Wallenstein BX62 chipper, Woods GTR72 tiller, Woods BH90-X backhoe, 724 FEL, forks, 1000lb PTO rotary spreader, Woods PRD8400 finish mower, Leinbach 7' landscape rake, United 7' box blade, Pequea 80 bushel manure spreader, Woods 7' Brush Hog.
  9. #9
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by Ruark View Post
    - Ruark
    My wife is always looking out the window for the loader nut
    Or nut on the loader.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  10. #10
    Veteran Member varmint's Avatar
    Join Date
    Mar 2003
    Posts
    2,399
    Northern Maryland
    Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
    Who knew to check loader mounting bolts?? When I added power steering to my B8200 kubota, I had to modify (i.e., cut out some metal) the loader frame at the rear. The loader is a Bush Hog universal model. In order to make sure I didn't loose any strength, I installed a bracing tube under the tractor to tie the two rear mounts together and support the area where I had trimmed... used grade 8 bolts, oversized at that, and painted everything when I was done. I figured the extra weight, down low, wouldn't hurt anything, either. So far, no problems. But I will check tightness of everything I can access, just in case. If you look closely at the foto, you can see where I trimmed away steel on the original bracket, for clearance of the steering cylinder, and the new tube/ bolt heads below.
    Attached Images Attached Images
Similar Threads
  1. Loader Loader problem solved
    By B2930 By the Water in forum Owning/Operating
    Last Post: 08-02-2010, 03:26 PM
  2. Loader Hydraulic Problem
    By Jackfr in forum Hydraulics
    Last Post: 08-01-2010, 11:24 AM
  3. Check your loader towers 270 TL
    By RADIUM in forum New Holland Owning/Operating
    Last Post: 06-09-2010, 10:17 PM
  4. 430 Loader Problem
    By Dicky in forum John Deere Owning/Operating
    Last Post: 08-12-2007, 12:33 PM
  5. Loader problem Cylider or Valve...Help!
    By Mike_VT in forum Parts/Repairs
    Last Post: 05-31-2007, 06:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
