stagalv
Hello - I'm new here and to tractors. I have a few questions about my new, 40 year old tractor. It's a Ford 3000 Diesel with the 8 speed transmission.
I have run the tractor for a few hours now with a rotary cutter and have become quite comfortable in it's basic operation. A while back I bought a reproduction owners manual and it shows this 8 speed version tractor available with two different PTO's. One of them had a two stage clutch where the half way down stopped the tractors motion and all the way down stopped the pto as well. The other one only had the pto turning while the tractor was moving.
Neither of these fit mine. On mine there is the clutch which only appears to have the all the way down position which stops the tractor only but the pto will continue to turn as long as I have it engaged.
Is this a common pto style or is something not working the way it should?
Also when I engage the pto I have the shifters in neutral and have the clutch fully engaged, idle speed and not moving it still grinds and then CHUNG, starts spinning the hog. Should I be doing something else?
I would appreciate your opinion on this.
