Page 2 of 10 FirstFirst 12345 ... LastLast
Results 11 to 20 of 96
  1. #11
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Default Re: No idea what year this Backhoe is
    Quote Originally Posted by teg View Post
    I don't know the year but you get an A++ for those photos
  2. #12
    RIP
    kenstrac's Avatar
    Join Date
    Jan 2009
    Posts
    765
    So central NH.
    Kioti DK 45
    Quote Originally Posted by gammer View Post
    Sorry Guys, I took the pics from my Iphone I thought the pics could be enlarged when opened, I will get better pics, ASAP! I'm curious to see what year this is wiring is a mess couple of cylinders are leaking tires are in bad condition, e was starting it with ether in the morning he said it didn't have glow plugs. But I see it has a block heater. I don't understand people not taken care of something this expensive.
    Thanks for the help
    Check if it has a thermostart and if is working.
  3. #13
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    where would it be located?? there is alot of pieces missing off of this unit. it has no cluster in it. it has a block heater if that counts
  4. #14
    Bronze Member Bradlyk's Avatar
    Join Date
    Aug 2010
    Posts
    88
    Grey County, Ontario
    Ford 3930, Ford 6600, Agco Aliss 5670, Deutz D10006, Deutz D10006A
    So I got it right with the ford 4500 Industrial
    Good guess since I have one
    Agco 5670
    Deutz D10006A
    Deutz D10006
    Ford 3930
    Ford 4500 I
    Ford 6600
  5. #15
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Thanks Bradlyk!
    for the input, are you a 100% sure because I need to get parts & a manual. I looked for a dealer but can't find one to call. I went to plug the block heater in put it didn't sound good, probably needs to be replaced...
  6. #16
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    953
    Gator Country
    New Holland TC40D HST 4WD FEL/BH
    ... I don't understand people not taken care of something this expensive.
    We used to have a backhoe we bought used. Ended up using it for scrap metal.
    The problem was, it was a 1953 Case and we could no longer get parts. It wasn't in the best condition when we bought it. It had been well used. We used it quite a bit. When the hydro pump started not working right, that is when we started having real problems.
    We could not find the parts to properly rebuild the pump. Though we did manage to make it work, we also experienced similar problems with the hydro cylinders.
    When the engine started to have major problems (it had major wear and many, many hours on it) the machine slowly died on us.
    After many years of sitting, it got to the point where it would cost more to fix it then to get something newer.
    Sometimes, the proper care of an older machine is not always because the people who own it do not care. Sometimes it is simply not practical.
    New Holland Workmaster 45 2WD Gear
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  7. #17
    Join Date
    Apr 2010
    Posts
    975
    I hope you didn't pay too much, because that unit was rode hard at some point. Front loader has scabs and other repairs. The bucket cylinder was broken off the hoe. Those things are signs of long hard use, possibly abuse.
    Have you inspected the entire machine for other signs of repairs? Especially for signs of current un-repaired cracks. It looks like the machine was given a slathering of paint, that can hide cracks for a while.
    Then check the front spindles for wear, then each pin/bushing for wear. Each bushing on that machine is at least $50 for the press in bushings + the removal and installation cost. Pins are probably 2-3x that (each). It's very easy to spend more in pins and bushings than the entire used machine cost. And that is the reason that an expensive tool can get neglected. Cost to repair gets to be way high. At some point, it's cheaper to buy a new one than repair the old one, so it gets beat on until it's ready to drop and sold.
  8. #18
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,734
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    That is a clean/straight looking BH to be going on 40 years old. Most are more beat up and glassless if they have an enclosed cab.
    Someone has put new injectors from the look of it some maybe it has been keep up other wise as well. Tires look like have a lot of tread for personal use.
    We bought a 1983 JD 310B in the spring and due to markings on it could have been a rental at some point with a lot of wear/patching on both buckets and slack in all of the pins but it runs well and digs well.
    I have factory shop manuals for all our equipment that I found on E-Bay.
    Bet you have a lot of fun with that toy.
  9. #19
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    I got pics from the starter side, this unit is in rough shape hyd lines need to be replaced the out shielding falls off when you tough it. pins on the loader look like it needs to be done. cyl are pitted, power steering not working, found the block header needs to be replaced leaking a bit just wondering if a universal would work.
    Happy New year everyone!
    Attached Thumbnails Attached Thumbnails No idea what year this Backhoe is-dscf2121-jpg   No idea what year this Backhoe is-dscf2120-jpg
  10. #20
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,532
    Lincoln County, NC need new avatar!
    Just a Scag
    It is a 1973 Ford 4500 TLB. Built May 10 1973. Block heater is a 1-1/2" frostplug style. Parts and service available at any New Holland dealer.
    Spring is the season of optimism.
Similar Threads
  1. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 04:12 PM
  2. What year ford backhoe?
    By rmo5095 in forum Construction Equipment
    Last Post: 04-18-2008, 08:09 PM
  3. Dead Birds on Backhoe
    By AlanB in forum Rural Living
    Last Post: 04-02-2008, 03:20 PM
  4. backhoe or mini excavator
    By HURLEYSLAWNCARE in forum John Deere Buying/Pricing
    Last Post: 01-06-2006, 08:59 AM
  5. Backhoe Backhoe quandary
    By aloha in forum Attachments
    Last Post: 12-22-2003, 10:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
