Page 7 of 10 FirstFirst ... 45678910 LastLast
Results 61 to 70 of 96
  1. #61
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Default Re: No idea what year this Backhoe is
    Tks Gale,
    what really has my head scratching, is when the unit was off any time of the day or night I could go out and move the shifter without starting the tractor, before all this.. and now it won't move running or not.
    1.Or is it not supposed to move when the engine is not running?
    2.Does the transmission hold the pressure on the block valves to allow it to move without the engine running??
    Or am I over thinking. I just want to be thorough.
  2. #62
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,841
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    One will have to find the logic flow chart of the system I expect to answer those questions.
  3. #63
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    first I must find a logic person to read it.. lol
    Yes, looking at it,
    I just removed the high pressure line test gauge plug, like you suggested and wound the motor over with nothing coming out of the line, also the blocker valve body is off with nothing coming from the port holes. mmmmmmmm... doh!
  4. #64
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,841
    Murray, KY
    Does the hoe and FEL use the same source of fluid or do you have to levels that you have to check and maintain?
    It seems you have a supply issue to the transmission. If you do not have flow from the test port nearest the transmission pump then you have a blockage, twisted shaft, etc would be my guess.
    Personally I would idle the tractor and see if you get any fluid at the test port that you have open.
  5. #65
    Platinum Member herringchoker's Avatar
    Join Date
    Oct 2004
    Posts
    750
    New Brunswick, Canada
    Kubota B7800, Case 450
    The only time the F-N-R shift lever is supposed to be locked in neutral is when the engine is turning at 1200-1500 RPM or higher. That's when the pump creates enough pressure to overcome the springs in the blocker valve that keep the blocker pins from entering the F-N-R control valve bore between the lands on the spool. If the lever won't move and the linkage is free, it seems to me that either one or both of the blocking pins (or something else) is jammed in the valve bore. But that wouldn't explain the lack of oil pressure.
    The transmission and Fel/hoe have separate reservoirs.
    Gammer - I'll scan some more and e-mail to you.
    Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 74" rear snowblower (shrunk to 62").
    Kubota RTV500.
    Case 450 c/w 6-way dozer.
  6. #66
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Awesome Tks,
    Your a life saver!!
    I'm stumped, trying to rap my head around this, I don't want to pull it apart until I know If the pump is gone or something like that. I'm pretty shore that something is blocked. I'm wondering If I can send compressed air through the pressure test line, and how much pressure is safe without damaging anything.
  7. #67
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,841
    Murray, KY
    Since the transmission and Fel/hoe have separate reservoirs is it possible you over looked one? Which reservoir did you put the Sea Foam in or did you do both?
    When you topped of the transmission reservoir how much oil it it hold. Did it leak out again like before? Could you have an air block for some reason that is causing the pressure not to build?
  8. #68
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    The transmission itself is isolated from the rest of the unit will hold app 18L.
    It didn't leak out but I need to change it,
  9. #69
    Join Date
    Oct 2004
    Posts
    750
    The normal line pressure at the test port varies from 95 to 170 psi depending on temperature and engine speed. Since that's in the same range as normal compressed air (at least in my shop), it might be worth trying to blow back through the test port. Maybe try shifting the F-N-R lever while you have air pressure applied.
    Kubota RTV500.
  10. #70
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Tks, herringchoker for the input,
    I did put some air through the test port, with no change. I'm in the process of changing the fluid in the tranny, trying to get has much of the contaminated fluid out. I think I had too much in it, It calls for 18L I had about 20L+, doesn't help. anyone guess why the tranny lost it's pressure completely. Did anyone ever take the 2 lower pressure regulating valve bolt and bypass valve bolt off without removing the tranny?
    Attached Thumbnails Attached Thumbnails No idea what year this Backhoe is-fordreverser3-jpg   No idea what year this Backhoe is-transmission-oil-jpg
Similar Threads
  1. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 04:12 PM
  2. What year ford backhoe?
    By rmo5095 in forum Construction Equipment
    Last Post: 04-18-2008, 08:09 PM
  3. Dead Birds on Backhoe
    By AlanB in forum Rural Living
    Last Post: 04-02-2008, 03:20 PM
  4. backhoe or mini excavator
    By HURLEYSLAWNCARE in forum John Deere Buying/Pricing
    Last Post: 01-06-2006, 08:59 AM
  5. Backhoe Backhoe quandary
    By aloha in forum Attachments
    Last Post: 12-22-2003, 10:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
