Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 71 to 80 of 96
  1. #71
    Platinum Member herringchoker's Avatar
    Join Date
    Oct 2004
    Posts
    744
    New Brunswick, Canada
    Kubota B7800, Case 450
    Default Re: No idea what year this Backhoe is
    I don't see how you can get at those without removing the tranny.
    Have you checked to see if there is oil flow to the cooler? (See the oil-to-cooler test - p. 32). You can do that externally.
    I was just looking at the Diagnosis Guide (p. 34) for low line pressure (you have no line pressure?) and it lists among the possible causes: sticking regulating valve, clogged oil distributor passages, and clogged sump oil strainer. I'm still wondering if some crud from the dirty oil got into some of those small passages. Hate to say it, but I can't see how you can find out without removing the tranny.
    Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 74" rear snowblower (shrunk to 62").
    Kubota RTV500.
    Case 450 c/w 6-way dozer.
  2. #72
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Dho!
    tks, herringchoker
    I'm wondering if the oil was too contaminated that it lost it's prime & that's why there is no pressure.. or if it is even possible....
    it's pissing me off, if I remove the tranny , do I change the torque converter, seals & pump to be on the safe side mmmmmmmmm!
    where to order these parts? I will need to sell my home, if I order from the dealer I guess lol
    It would be nice to know if they need to be replaced!!
  3. #73
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,581
    Murray, KY
    265 MF / JD 310B Backhoe
    That fliud looks like that in the lift of our old dump truck. My brother said valves can rust in position when parked when you have that much water in the oil but I have never looked inside of a valve.
  4. #74
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    put clean fluid in the tranny & pulled the plug from the cooler line while the engine was running to see if any pressure was there, not a drop came out
    going to start pulling it apart this week..... wondering what to replace besides the torque, pump & seals. Where to buy these parts...
    does anyone know what other rims out there will fit on the front of a 4500 Ford
    an old 70's 3/4 ton ford for instances.
    16" 6 hole
  5. #75
    Join Date
    Oct 2004
    Posts
    744
    Sorry to hear that - splitting the tractor is a big job, especially with the cab. Keep us posted.
    Re the wheels, 3/4 tons have had 8-stud wheels since almost forever. Ford 1-tons up to 1966 and Dodge up to about 1969? had 6-bolt rims, but I don't know if the bolt centres were the same as the tractor. You might have better luck with agricultural equipment. Newer GM 1/2 tons also have 6-bolt wheels.
    Kubota RTV500.
  6. #76
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,581
    Murray, KY
    Could there be a collapsed filter or something. Pumps seldom just quit like that from my limited experience.
  7. #77
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    I was this was the case but no, I changed the fluid & Oil with no avail.
    Need to know were to buy a Torque Converter & Pump, with seals.
    finally getting nice weather!!
  8. #78
    Join Date
    Dec 2010
    Posts
    65
    Nova Scotia
    Ford 4500 tlb
    Split the Machine, not good, here are the pics, torque converter damaged, I'm not surprised. Just hope the shaft on the pump side is ok. Anyone know how to remove the pump? Was the plate on the Torque Converter altered with the weld around the bolts or is this normal...
    Attached Thumbnails Attached Thumbnails No idea what year this Backhoe is-dscf2233-jpg   No idea what year this Backhoe is-dscf2238-jpg   No idea what year this Backhoe is-dscf2242-jpg   No idea what year this Backhoe is-dscf2232-jpg
  9. #79
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,581
    Murray, KY
    Looks like you did a great job of getting it opened up. Hope you find what you need in the way of parts at a good price.
  10. #80
    Join Date
    Oct 2004
    Posts
    744
    Did you get page 12 of the manual? It looks like you just have to remove the 4 bolts to remove the pump.
    It looks to me that the drive plate may have had some fatigue cracks around the bolts and somebody has welded them up, but I never had mine apart that far so that's just a guess.
    Kubota RTV500.
Similar Threads
  1. Backhoe 12" versus 16" Backhoe Bucket Size
    By Don_Curley in forum Kubota Owning/Operating
    Last Post: 07-27-2009, 05:12 PM
  2. What year ford backhoe?
    By rmo5095 in forum Construction Equipment
    Last Post: 04-18-2008, 09:09 PM
  3. Dead Birds on Backhoe
    By AlanB in forum Rural Living
    Last Post: 04-02-2008, 04:20 PM
  4. backhoe or mini excavator
    By HURLEYSLAWNCARE in forum John Deere Buying/Pricing
    Last Post: 01-06-2006, 09:59 AM
  5. Backhoe Backhoe quandary
    By aloha in forum Attachments
    Last Post: 12-22-2003, 11:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
