Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Dec 2010
    Posts
    5
    Mahindra 4530
    Default My Mahindra 4530 has no power
    I bought a used Mahindra 4530 with 260hrs and I am having a ton of problems....please help.
    1. when tractor is under a load, typically going uphill...engine starts to smoke and tractor "wet stacks" and just wants to keep running...looks like oil of fuel is getting into exhaust from the breather tube. I disconnected the breather tube to the exhaust and problem goes away...
    2. Also noticing that tractor has no power going up a hill...runs good at idle and I can rev it up to run PTO implemtents but hit a little hill and its done..
    thanks
    Jon
  2. #2
    Join Date
    Jan 2010
    Posts
    593
    East Coast
    JD 5100R / Toro 5900
    Default Re: My Mahindra 4530 has no power
    Sorry to hear this. How long have you had it? did the prior owner know of these problems? Seems strange....
  3. #3
    Veteran Member jake98's Avatar
    Join Date
    Nov 2007
    Posts
    1,914
    Dingmans Ferry PA
    53 Cub, 70's JD 410, Kioti 25hst
    What kind of 'hill'? You're not in a higher range are you?
    Welcome to TBN.
    Kioti CK 25 Hydro: box blade, brush hog, rake, roto-till, grapple, bucket forks, de-stump cyl, Wallenstein Chipper
    John Deere 410 Backhoe Loader: 25 hoses ready to blow
    Thus by the beneficence of Providence, we shall behold our empire arising, founded on justice and the voluntary consent of the people, and giving full scope to the exercise of those faculties and rights which most ennoble our species.
    Samuel Adams
  4. #4
    New Member
    Join Date
    Dec 2010
    Posts
    5
    Mahindra 4530
    Quote Originally Posted by 9973720wb19 View Post
    not long...no the previous owner said the tractor worked great...
  5. #5
    New Member
    Join Date
    Dec 2010
    Posts
    5
    Mahindra 4530
    no...not in high gear...not a big hill by any means...i changed the fuel filters too....injection pump??
  6. #6
    Veteran Member EFC's Avatar
    Join Date
    Dec 2001
    Posts
    1,149
    Richland, Washington
    Enough
    Quote Originally Posted by whitetailworks View Post
    thanks
    Jon
    No power under load sounds still like a fuel problem, could be an obstruction in the tank blocking the fuel. Is it pouring out unobstructed?
    Buck
  7. #7
    New Member
    Join Date
    Dec 2010
    Posts
    5
    Mahindra 4530
    i change filters and fuel seems to be flowing good to them
  8. #8
    Super Star Member Diamondpilot's Avatar
    Join Date
    Jan 2007
    Posts
    16,332
    Daleville, IN
    Jinma 254/284 Ford 861 Powermaster at work
    Is there too much oil in it? Does it have the right dip stick? I would change the oil first and put in the amount stated in the manual, not by what the dipstick says. Check this as compared to the oil level before the change to confirm proper amount.
    Nothing silly like parking break set is it?
    I would remove the fuel line from the injector pump and verify good flow from the fuel tank though the shut off then the sediment bowl and down the line also. I have seen fuel lines broken down inside from bio blended fuels. Also on some tractors there is a fine screen prior to the injector pump inside the fuel line where it connects to the injector pump.
    If you are not familiar with diesel tractors the plumbing usually goes like this. Fuel tank, fuel shut off, sediment bowl, FUEL PUMP (part of the injector pump assembly), fuel filter, back to the INJECTOR PUMP, fuel injectors, then excess fuel back to the fuel tank.
    Chris
  9. #9
    Gold Member TraderMark's Avatar
    Join Date
    Feb 2001
    Posts
    377
    Southeast Georgia
    Ford 1720
    I don't know much about Mahindras but I'm curious about this .... "breather tube to the exhaust".
    Can you clarify that a little more?
    Mark
  10. #10
    Platinum Member civesnedfield's Avatar
    Join Date
    Jun 2007
    Posts
    600
    Central Maine
    2007 Mahindra 4530----1972 Massey Ferguson 1100
    I would check fuel flow. Pull the filter closest to the tank. Then open the fuel shut off valve see what kind of flow ya have.
Similar Threads
  1. Goodbye Kubota, Hello Power Trac
    By MChalkley in forum Power Trac
    Last Post: Today, 12:14 AM
  2. Kubota makes excellent tractors...but why so MUCH more expensive?
    By Owenslee in forum Kubota Buying/Pricing
    Last Post: 10-23-2009, 11:57 AM
  3. new mahindra 4530 owner.
    By zobin in forum Mahindra Owning/Operating
    Last Post: 05-14-2009, 09:34 AM
  4. Mahindra 4110 vs. 4500-2WD w/ FEL
    By tractornewby in forum Mahindra Owning/Operating
    Last Post: 02-14-2006, 10:09 AM
  5. Mahindra 4500 4 Wheel Drive (Power Loss)
    By mharrington in forum Mahindra Owning/Operating
    Last Post: 01-03-2005, 01:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
