Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Bronze Member Bradlyk's Avatar
    Join Date
    Aug 2010
    Posts
    87
    Grey County, Ontario
    Ford 3930, Ford 6600, Agco Aliss 5670, Deutz D10006, Deutz D10006A
    Default How I start AIR COOLED tractors W/O Block Heater
    The other day I had to move my 2WD Deutz D10006 to get the manure spreader out after not being started for 4 months
    So I got all my starting weapons out (Jumpers,ether...) and before I left the neighbour asked me what I was doing so I told him and he told me " To start a cold air cooled tractor without block heater get a 5 gallon pale of boiling hot water and splash it on the motor" So I got myself a pale of hot water and got to my trusty old 2wd Deutz and splashed the water on it and jumped off and got comfortable cause I thought this might take a while..
    To my suprise the starter turned 4 times and she came roaring to life ... Wow that took me by suprise
    The point of this post is for people without a block heater to learn how to start their tractors easy
    Agco 5670
    Deutz D10006A
    Deutz D10006
    Ford 3930
    Ford 4500 I
    Ford 6600
  2. #2
    Elite Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    3,144
    Saskatoon, Saskatchewan
    Default Re: How I start AIR COOLED tractors W/O Block Heater
    That's a very good tip which most people would never think of.
    It reminds me of the old Allis Chalmers WC we had. It never had any sort of block heater and when it got really cold and we needed to use it, we would pour a teapot full of boiling water (well, it was boiling when we left the house with it) over the carb. That, along with someone on the hand crank to augment the starter would usually make it fire. If not, sometimes a second pot of hot water was needed.
  3. #3
    Gold Member
    Join Date
    Apr 2010
    Posts
    329
    What happens if it doesn't start?
    If we move equipment outside after a pressure wash without blowing everything dry, we end up with frozen and stuck starter drives, control cables, governor linkages, etc. On Monday, I went out and replaced the timing belt and 2 bent pushrods in a customer's F4L Deutz. Not because they splashed water on it intentionally, but because they shut it off, and then it got a good dose of snow on top of the engine because of a missing cowling. The warm engine melted some of the snow, it ran down and got inside the belt cover...and then froze again. When they cranked the engine, a chunk of ice wedged between the belt and crank pulley, and the belt snapped.
    There are starting aids for the air-cooled Deutz available like intake heaters, and heating elements for that thread into the oil pan to warm up the oil. If you didn't want to go that route, why not use a small knipco heater and some ducting to carefully warm things up for a few minutes?
  4. #4
    Join Date
    Aug 2010
    Posts
    87
    We don't usually do that we usually put a heater in the engine under the cover and let it be for a few hours.
    But we didn't have time to wait so we just started it up and let it warm up to remove water and dry everything up
    Agco 5670
    Deutz D10006A
    Deutz D10006
    Ford 3930
    Ford 4500 I
    Ford 6600
  5. #5
    Join Date
    Oct 2010
    Posts
    138
    Salisbury, Maryland
    J-D 1070, Furgeson F-40
    Would not a propane weed killer firing into a length of stove pipe with a 90 pointing up to the block act like a 'field salamander'? Similar, more expensive units, are used to pre-heat aircraft.
    Jim
  6. #6
    Platinum Member Craig Clayton's Avatar
    Join Date
    May 2009
    Posts
    863
    Uxbridge Ontario Canada
    L2250 Kubota
    I have watched older film footage about starting air cooled aircraft bush planes engines. When they land on the frozen lake as they are setting up camp the engine oil is drained into a 5 gallon pail. In the morning the same 5 gallon pail is put on the wood stove. They pour it through the engine twice, as the tent is coming down and off they go.
    Craig Clayton
  7. #7
    Join Date
    Aug 2010
    Posts
    87
    That sounds like a good idea but wouldnt be the fastest thing :P
    Agco 5670
    Deutz D10006A
    Deutz D10006
    Ford 3930
    Ford 4500 I
    Ford 6600
  8. #8
    Platinum Member crashz's Avatar
    Join Date
    May 2005
    Posts
    944
    Eastern MA & Upstate NY
    John Deere 770, Bobcat 753
    We have had a set up called the life line. Its a generator, battery charger and slamander all in a cart. Pull it towards the "patient", place components accordingly, let it run for an hour, and come back to start up. Started all of the snow equipment for over 20 years like this. Usually it was me doing the start up while my father and his guys came in to work.
    “I've had a wonderful evening, but this wasn't it.” ~ Groucho Marx
  9. #9
    New Member
    Join Date
    Dec 2010
    Posts
    6
    Regina, Saskatchewan, Canada
    Massey GC2410TLB
    I used to have to get diesel trucks going in very cold weather. One thing we did was put some charcoal briqets in an old hupcap or garbage can lid, light them and then set them under the engine. Relatively quick, high heat and no open flames.
  10. #10
    Join Date
    Aug 2010
    Posts
    87
    Thats actually a good idea never thought of doing that
    Agco 5670
    Deutz D10006A
    Deutz D10006
    Ford 3930
    Ford 4500 I
    Ford 6600
Similar Threads
  1. BX23 block heater install.
    By Ken_CT in forum Kubota Owning/Operating
    Last Post: 11-23-2006, 10:03 AM
  2. eBay/Craigslist ebay item
    By djg in forum Yanmar
    Last Post: 06-24-2005, 08:37 AM
  3. BX2230 Block Heater?
    By HarleyScooter in forum Kubota Owning/Operating
    Last Post: 11-09-2004, 12:39 AM
  4. Block Heater Works Great !
    By rbargeron in forum Kubota Owning/Operating
    Last Post: 02-03-2004, 11:25 PM
  5. 2210 Engine Block Heater Installation
    By mhalla in forum John Deere Owning/Operating
    Last Post: 12-24-2003, 07:19 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
