Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,769
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Default Re: drawbar
    Here is a picture of my Ford Jubilee with the drawbar, drawbar stays, and blue colored drawbar lock installed. Notice the notch cut out on the lock. It is clearance for the stay. That means you can only put it on the left side. If you put it on the right side, the slot will be on the bottom. You could cut a slot in both sides, but you might not be using the stays, so it doesn't matter. By the way, most of these locks are a bit loose and your drawbar will still rotate some, but within limits.
    Attached Images Attached Images
  2. #12
    Join Date
    Sep 2002
    Posts
    163
    Southport NC
    TYM 723
    Default Re: drawbar
    Thanks Guys!!! [img]/w3tcompact/icons/smile.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
