Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member
    Join Date
    Mar 2006
    Posts
    48
    Connecticut
    2011 Kioti CK20S HST TLB, JD 1939 Model L, Cub Cadet 2135 Lawn Mower
    Default 3 pt Attachments w/BX25 and Kioti CK20s HST
    I am looking at purchasing one of the two listed tractors as a TLB package. I currently do not have a need for any 3 pt. attachments - but want to think about the future and not limit myself. With these two machines are there attachments that you can not get? I realize there are wieght limits and size limits given the 3 pt. strength and the Kioti has more lift than the BX. But what I am wondering is getting a machine this size - are there attachments that you just can't get? As a newbie - I don't know what I might be mssing. Thanks
  2. #2
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,714
    Beaver Creek, Northern Michigan
    Kubota BX2360
    Default Re: 3 pt Attachments w/BX25 and Kioti CK20s HST
    Quote Originally Posted by Roxburyeric View Post
    Because these subcuts are soooooooo popular, the implement folks have kept up with just about every offering you can possibly think of. Most items are in the 48"-54" width and most even are designed to take into account the low ground position of these tractors. Absolutely no worries.
    BP
    "Some chickens, some gardens and a Kubota."
  3. #3
    Join Date
    Sep 2007
    Posts
    645
    the three point is exactly why I am looking so hard at the kioti, the bx does not have position control, as my previous JD 2305 did not. once you've used a tractor with that feature you'll hate not having it. It was a feature I had always taken for granted on machines growing up on a farm, I didn't even realize they make tractors without it until I got the 2305 and it drove me nuts.
  4. #4
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    There will be *some attachments* that you can't get, but just about everything a homeowner/property owner would want they can get. The ones you may not be able to get are usually farming/haying implements or specialty attachments...Darn, I really wanted that forestry mulcher...
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
  5. #5
    Gold Member
    Join Date
    Apr 2010
    Posts
    332
    Pennsylvania
    Yanmar sc2400 TLD, 1989 Ford 2120 with loader
    I don't want to thread jack, and I must sound like a broken record at times, but the cub yanmar scuts do have position control 3pt hitch. Just something to consider.
  6. #6
    Elite Member
    Join Date
    Jan 2010
    Posts
    2,524
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    You probably won't find a hay baler or a gravity wagon you can pull, and it might be kind of tough plowing a field . All kidding aside, there are Sub-compact sized implements available for just about anything you want to do... other than actual farming. Mow, till, plant, move dirt, move snow, carry stuff, tow stuff, lift stuff, generate electricity, split logs, etc., etc.
  7. #7
    Gold Member
    Join Date
    Jan 2011
    Posts
    263
    IN
    Kioti CK30, JD X475. HPX Gator, Woodmizer LT10
    Get the CK 20, so much more tractor for about the same money or less! The subcompacts require the "L" limited implements due to the reduced lift height. If you use a reg. Cat. 1 implement on a sub, you won't get it up very high. That's why an "L" implement is needed.
    The CK 20 gives you more weight, higher profile and a lot more loader lift.
    Plus, Kioti builds a real nice tractor and 4 yr. warranty.
  8. #8
    Member
    Join Date
    Mar 2006
    Posts
    48
    Connecticut
    Thanks for the re-assurance on the attachments. Now just have to make up my mind on which tractor. BX25 is about $2K less and would be local buy - local Kioti price is $4k higher. The 2k higher kioti price is only 135 miles away - so not really far but not local.
  9. #9
    Elite Member Dmace's Avatar
    Join Date
    Oct 2005
    Posts
    3,838
    Wakefield, NH
    Kioti CK20 HST
    I noticed that kubota list the 3pt hitch as "Optional" in their specs, you might want to make sure it's included in the price. Other than that, it is a Category 1 so it should take the same type of implements as the Kioti. It just can't handle the heavier attachments like the Kioti.
    Derek
    Kioti CK20HST
    KL120 FEL // KB2365 BH // 60" JRW 3ph snowblower // 48" HD Boxblade
    Sims-Cab Depot heated cab
    Quote Originally Posted by DiamondPilot
    Now it's time for Ford and GM to step up
  10. #10
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Quote Originally Posted by Dmace View Post
    That's just on the BX25 TLB...
Similar Threads
  1. Kioti CK20S hst or Kubota B2320 hst
    By Kiotikarl in forum Kioti Buying/Pricing
    Last Post: 07-12-2011, 12:33 PM
  2. Update on loader repair program from Kioti Jan 30
    By IslandTractor in forum Kioti Owning/Operating
    Last Post: 03-08-2007, 01:04 PM
  3. kioti warranty
    By headachers in forum Kioti Owning/Operating
    Last Post: 01-29-2006, 08:39 PM
  4. Kioti owners - Proud?
    By lcisled in forum Kioti Buying/Pricing
    Last Post: 09-30-2005, 10:59 AM
  5. Is Kioti Viable for the Long Term??
    By viking65 in forum Kioti Buying/Pricing
    Last Post: 05-16-2005, 09:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
