Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Anyone tried to make small ditches with blade?
    I have some standing pools of water here and there in my field. Has anyone used their back blade to make small trenches to drain water etc? My blade tilts vertically about 30 degrees and my 3-PT has position control. I gave it a shot and found it tough not to dig in too much, completely miss, etc. My ground is pretty soft right now but it is pretty un-even making blade control interesting.
    Any techniques (asside from practice) that will work for a newbie? Is there a home-made tool that might work better? I only need to go down less than a foot. (Yeah I know, a shovel works but I'm lazy.)
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: Anyone tried to make small ditches with blade?
    Finding 3pt attachments, such as a one-bottom plow, or a sub-soiler tooth should work. Getting that deep with a rear blade isn't easy. I use both, the one-bottom plow and/or the sub-soiler tooth.
  3. #3
    Join Date
    Jan 2001
    Posts
    2,518
    Capital District, Upstate New York
    Satoh S650G, MF135, MF165, JD5205
    <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/47-222638-Ditchingwithmiddlebuster-800.jpg>For a down and dirty cheap ditching tool… try a middle buster…</A>
    A 1-bottom will over turn the sod over onto itself and the subsoiler is way too narrow… but if that’s all you got… then that’s all ya got and make many many many passes… [img]/w3tcompact/icons/wink.gif[/img]
    Like Beenthere has mentioned... getting depth is tough with these implements...
    Attached Images Attached Images
  4. #4
    Join Date
    Jan 2001
    Posts
    2,518
    <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/47-222640-Ditchlonglongview%3D800.jpg>One of the ditches I did for my Father earlier last year with both a middle buster and rear blade...</A>
  5. #5
    Join Date
    Jan 2001
    Posts
    2,518
    <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/47-222642-Ditchingwithrearblade-800.jpg>To clean up the ditch edges and gain more depth... I used my 8' rear blade...</A>
  6. #6
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Looks like you can get 45 Degree tilt or more on yours. Mine is 30 Degrees max. Maybe I'll give it another try though.
    Thanks everyone for your suggestions! Now I have options.
    Randy Redding
  7. #7
    Join Date
    Jan 2001
    Posts
    2,518
    <font color=blue>...Looks like you can get 45 Degree tilt or more...</font color=blue>
    I could do a 360 degree with my old 7'... the 8' is a hair too long... (my 3-pt... just goes so high in the air...[img]/w3tcompact/icons/blush.gif[/img]) [img]/w3tcompact/icons/wink.gif[/img]
  8. #8
    Von
    Von is offline
    Advertiser
    Join Date
    Apr 2000
    Posts
    1,589
    Western New York
    Kubota B2710
    Wow John!!.... Is there anything you don't have photos of? or should I not ask!!![img]/w3tcompact/icons/laugh.gif[/img]
  9. #9
    Join Date
    Jan 2001
    Posts
    2,518
    <font color=blue>...Is there anything you don't have photos of?...</font color=blue>
    Ok Von... buddy... oh pal... your wish is our command... pick a card, any card... what would ya like to see...? [img]/w3tcompact/icons/blush.gif[/img][img]/w3tcompact/icons/eyes.gif[/img]
    [img]/w3tcompact/icons/grin.gif[/img]
  10. #10
    Join Date
    May 2002
    Posts
    579
    Harrisburg, Illinois
    MF 165, Kioti 2554
    How 'bout a Minneapolis-Moline rotary cutter? [img]/w3tcompact/icons/laugh.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
