Page 11 of 16 FirstFirst ... 891011121314 ... LastLast
Results 101 to 110 of 156
  1. #101
    Veteran Member Gizmo2's Avatar
    Join Date
    Jul 2006
    Posts
    1,917
    New York
    JD 2320
    Default Re: Grease Gun and a Screwdriver
    Quote Originally Posted by BuckeyeWilly View Post
    I love this grease gun but I do see where the rubber hose makes it hard to put pressure and keep the tip on the fitting. Also, even with the tip adjusted down tight it was still easy to pull the tip off the zerk. I think its times someone invents a better way to grease equipment!!!!!
    I have a pistol type hand grease gun (IMO better than the two hand unit) and the best thing I ever did was to extend the hose by about a foot, makes the greasing job sooo much easier.
    JD 2320, 200CX FEL/61" bucket , 46 BH/16" bucket, FEL Forks, 72" Snow Blade, Landscape Rake, Ballast Box, PHD, The Wife
  2. #102
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,728
    Branson, Mo.
    Kioti DK35se Hydrostat
    Fortunately everything on my tractor is easily reached with a straight push of my hand held grease gun with a straight pipe so I can put some real push on the thing to pump grease into balky zerks. I have other guns which I dont use anymore as the little handheld does everything I need. Now if you have a zerk that absolutely will not take grease, they make a tool to clean up the channel. Or you might just have to take apart whatever it is that wont take grease and clean out the old hardened grease and dirt and start over. I have never had to do that, I try to grease often.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  3. #103
    Elite Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    4,720
    Northern Vermont
    I came across a one piece grease gun tip. It's never been used so there's no grease in it. Since I didn't care about it I put the flat part in a vise and a pipe wrench on the knurled part and just destroyed it. All I can figure is it's a cheap pressed together head. I should have taken pictures.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
  4. #104
    Join Date
    Nov 2003
    Posts
    927
    Theresa, NY
    NH2120 RTV500 Bobcat S250
    I bought a new grease gun at Autozone today and there is nothing in there about the adjustment. I knew about it from somewhere, but I didn't know what knurled was, so this thread has enlightened me also.
    Tom
  5. #105
    Bronze Member ding2520's Avatar
    Join Date
    Jan 2007
    Posts
    61
    S.E. MN
    2006 John Deere 2520
    Here is an explaination as to what a knurl can be.
    Attached Thumbnails Attached Thumbnails Grease Gun and a Screwdriver-knurl.jpg
  6. #106
    Join Date
    Mar 2006
    Posts
    218
    South Central KY
    Kubota B3030HSD
    This thread was a learning experience for me although I've had mixed results adjusting the knurled tip and loosening it usually results in lube coming out the threads. Maybe I need a higher quality tip. Now if someone would just figure out a way to get that dang PTO coupling on easier... ;-[
  7. #107
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,190
    Southern VT
    '10 Kioti DK 40se/hst
    WOW! 11 pages on grease gun nipples and knurled tips, etc. IMPRESSIVE!
    I must admit that even though I owned and ran a foreign car shop for more than ten years we didn't have to grease a lot of fittings- mostly because most cars no longer have grease fittings.
    So when I got my first tractor I had to break out the old grease gun and it took me forEVER to grease the tractor! What a pain and time consuming too.
    I thought, I'd better find a quicker way to do this job or its not going to get done very often. I had some trouble with some zerks, and couldn't get the end to release and did what everyone else did; cursed a lot, yanked and pulled and pried, etc. Then I got a pistol type gun because I hate the lever type for all the same reasons as mentioned. I had some trouble with it too and thought maybe I was doing something wrong. So I took some time to investigate. I found the hose end had flats for a wrench to attach and the tip was knurled so I took to dismantling the end. Low and behold I found one of the guns tips had a jaw that was upside down and therefore wouldn't work properly. So I fumbled with it until I thought it was right based on the other tip, and then I had the brilliant idea that maybe it was meant to be adjusted loose or tighter depending on the zerk fit.
    Low and behold I was onto something! A genius I concluded I must be!
    But dam med if I was 'gonna share my newly discovered idea with the rest of the world, so I bought out the printing company that used to write the grease gun instructions and ordered a bunch of cheap toilet paper and started printing the NEW instructions that NEVER include anything about twisting the tip!
    The rest is history- suckers!!
    Moral of the story: NEVER look at the directions! Its like staring into the sun.
    If it went together it must be able to come apart; unless its made in Taiwan, China, Mexico, Ubeakistan, Freakistan, or anywhere near yur anus.
    If you think its a piece of junk and poorly designed by idiots it IS: refer to " if it went together above..."
    If all else fails, then you're done- go home.
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
  8. #108
    Join Date
    Jun 2009
    Posts
    7,728
    Branson, Mo.
    Quote Originally Posted by Coyote machine View Post
    OMG.. you DO have a sense of humor and a turn of phrase.!! I just picked myself up off of the floor..
    James K0UA
  9. #109
    Join Date
    May 2009
    Posts
    2,190
    Southern VT
    Quote Originally Posted by k0ua View Post
    James K0UA
    Thanks man! I appreciate the opportunity to hone my razor sharp wit whenever I can! This forum gives me plenty of opportunity.
  10. #110
    Join Date
    May 2012
    Posts
    2,241
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by tawilson View Post
    I had a friend help me with some engine work last summer and he put on a pair of disposable latex gloves before he started and I've been sold ever since.
    Call me dainty, but that's what I do too. I hate getting grease over all my other tools or my manual, or my tractor so I end up pulling them off halfway through then putting another pair on. I must go through three pairs before I'm done. I'm still covered with grease everywhere but my hands, but at least my hands are clean so I'm not spreading grease all over the house when I go in.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
