Results 121 to 130 of 156
06-06-2012, 06:01 PM #121
Re: Grease Gun and a Screwdriver
A very good point. I try to regularly inspect the entire tractor, but that only takes a couple minutes. I'm sure the greasing will get easier. Time to suck it up and do it before any more playing.
I'm about to start building a little tractor shed/barn on the land, too. Once I have a shed with a tool bench in it, I think this will all be easier to deal with.
06-07-2012, 03:58 PM #122
I love that post!
Since I started to read this post, I dont even look at my cheap grease gun anymore. I got myself a Linken one-hand grease gun / really nice! So far in this thread there haven't much reaction about battery operated grease gun two-hand vs one-hand. Anybody went for the air compress one?
Phil
What about grease for the FEL, is this an all time favorite?
http://www.epc.shell.com/Docs/GPCDOC...%29_TDS_v1.pdf
Shell LubeMatchPhil
06-08-2012, 10:41 AM #123
Ok, i'll chime in once more on this one.
Did the greasing last night, and it was no sweat. Not sure why I was complaining so much previously. Yes, I had to tighten and loosen the nozzle each time, but with gloves on and a good supply of rags it was no big deal. After 25 hours since the last time, almost every pivot point was still totally full of grease (as in, one pump and it was already squirting out), so that makes me feel a bit better.
06-08-2012, 10:46 AM #124
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
06-09-2012, 10:31 PM #125
I agree- I'll ease up now that you seem to be getting the seriousness of doing the greasing whether you have time to do it or not. It's really cheap insurance when you think about it.
I get it that you're pressed for time, who isn't?, but a little time with a good quality grease gun and some investment in your machine pays off in the short and long run. You didn't buy the cheapest tractor you could find, so apply the same principle to your tools for maintaining it. Just look at it as time well spent toward SAVING yourself money on repair bills which cost a he** of a lot more than greasing time/materials.
You haven't failed your machine, you just haven't respected it enough yet.
You'll get the hang of it....
Keep plugging along.2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
Scag Wildcat: Kawasaki 26HP.
Bunch of STIHL chainsaws
: 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
07-17-2012, 09:34 PM #126New Member
- Join Date
- Feb 2010
- Posts
- 6
- Location
- Fredericksburg Va
- Tractor
- Ford 1700, TaiShan Mountaineer 254, Owatawna Mustang Skid Loader, Huber Mainainer with Dozer blade
As I have always heard on auto repair shows on both Tv & Radio
"Grease is always Cheaper than Steel"
I have to admit I knew about the adjustment part of the tip before this thread.
The part of changing the grease tube that was hardest for me was to get the plunger to stay locked out. Eventually I resorted to using a small pair of vice grips to clamp down on the rod; because the place in the end cap that are supposed to hold it was worn out (I guess I did not lube it enough)
I had a many a tube sent flying across the shop or field just picking it up to put the two halves back together.
07-17-2012, 09:57 PM #127
07-17-2012, 10:36 PM #128Veteran Member
- Join Date
- Jun 2006
- Posts
- 1,237
- Location
- West Cascades Washington State
- Tractor
- PT 422
07-20-2012, 08:02 AM #129Bronze Member
- Join Date
- Sep 2010
- Posts
- 93
- Location
- Central Maine
- Tractor
- Kubota BX25
Sixty-four here and still learning even though I've been greasing for nearly a half century. This forum is tops.
Proofread carefully to see if you any words out.
BX25, BX2750D Snowblower, Bro-Tek thumb, BXpanded Forks, Ballast Box, 3-PT Pallet Forks ...... My Kubota Pics
02-11-2013, 06:10 PM #130Gold Member
- Join Date
- Apr 2011
- Posts
- 303
- Location
- Simpson Corner NS Canada
- Tractor
- jinma284
I have never noticed that. In the morning you just know where I will be, checking out my greese gun. I have always wondered why the fit is so sloppy on my tractors zerks.
