Page 5 of 21 FirstFirst ... 234567815 ... LastLast
Results 41 to 50 of 204
  1. #41
    Gold Member Jaylegger's Avatar
    Join Date
    Oct 2009
    Posts
    459
    Massey Ferguson GC2600L
    Default Re: Grease Gun and a Screwdriver
    Quote Originally Posted by RoyJackson View Post
    So...that's how it works...
    LOL varies depending on which professor you listen to but that's the jist of it.
    Didn't intend to offend anyone and trust most have a similar sense of humor.
    Nightime snowblowing in rain.
    http://www.youtube.com/watch?v=yp50hn8lHf8
    _______________________
    MF2360 Front Snow-blower, 60" MF2340 front blade/Hydraulic angle, Woods BH6000 backhoe, Land-Pride GS1548 Grader/Scraper, 54" 2315 Mulch Mower, DL100 Loader
  2. #42
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,005
    Northern Vermont
    Kubota, Case, Deere
    Gotta love the internet. I knew a long time ago about how to adjust the tip of a grease gun but like almost everyone here I often learn things that seam simple yet without places like TBN I could have gone my whole life never knowing. And I thought that the internet was just created to make it easier to distribute porn.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  3. #43
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,182
    Branson, Mo.
    Kioti DK35se Hydrostat
    Wait, wait,,, what is this screwdriver thing?? I have always used my pocket knife on those things.. and a dime on the really big ones!!!
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  4. #44
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,628
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Quote Originally Posted by k0ua View Post
    Yeah...I always thought a screwdriver was half vodka, half orange juice!!
    And who needs all that Vitamin C, anyway???
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  5. #45
    Gold Member kday64's Avatar
    Join Date
    Nov 2010
    Posts
    350
    South Eastern Connecticut
    Kubota BX2360
    Default
    Hey all,
    I justhad to attach the pictures below. I am pretty dang sure that there is no knurled knob that retracts the four jaws of my grease nozzle.
    As you can see I tried to use force and it failed. Oh well I am guessing that I will have to go out and buy a new tip. Grrr...!!!!
    I am quite please to see that it has only taken me 29 years to learn how to properly use grease guns.
    ~Kevin
    Attached Thumbnails Attached Thumbnails Grease Gun and a Screwdriver-forumrunner_20110422_193953-png   Grease Gun and a Screwdriver-forumrunner_20110422_194108-png
    Last edited by kday64; 04-22-2011 at 07:47 PM. Reason: Orginial post made with Driod App.
    Kubota BX2360, 54" Fine Cut MMM, LA243 FEL, BX2789 Rear Snow Thrower
  6. #46
    Join Date
    Nov 2010
    Posts
    350
    Kubota BX2360
    I wish I would have thought of these things. I have been using my finger nail lately. Those cute little X screws are much more difficult to use.
    ~Kevin
  7. #47
    Join Date
    Jun 2009
    Posts
    28,182
    Branson, Mo.
    Quote Originally Posted by kday64 View Post
    Hey all,
    ~Kevin
    Well looks like you were trying to unscrew it, and that is what you need to do to loosen it, are you saying when you had the wrench on the flats of the nut, and the vise grips on the knurled area you were unable to unscrew it? If it was me, I would put as much torque on it as I could, even if it broke into 2 pieces, as it is no good to you as it is. Give it another try, or get a cheater bar or put it in a vise, or whatever it takes to break it loose, because all screwed down tight, it it useless. and you have to get it off to replace it anyway.
    James K0UA
    James K0UA
  8. #48
    Bronze Member chuckd1277's Avatar
    Join Date
    Jul 2010
    Posts
    96
    CT
    Default
    I might have to invest in one of those fancy tips. I actually pulled out a zerk on my first attempt at greasing. I'm getting better at the tilt and twist technique though.
  9. #49
    Join Date
    Jun 2009
    Posts
    28,182
    Branson, Mo.
    Quote Originally Posted by chuckd1277 View Post
    Just loosen the tip on the one you have. I have never seen one that didnt loosen.. Of course if you loosen it too much, then grease will squirt from around the threads and it wont stay on by itself.. find the "sweet spot" or happy medium.
    James K0UA
    James K0UA
  10. #50
    Join Date
    Mar 2011
    Posts
    118
    Virginia
    kubota m5700
    Well I will have to admit after 52 years of greasing heavy equipment that I never new this and I have pulled my share of zerks out because the tip would not come off. Thanks TBN
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
