Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
  1. #31
    Join Date
    Aug 2005
    Posts
    1,491
    Guernsey Co. Ohio
    Ford 3000, JD 2550
    Default Re: Mowing Roadside Ditch?
    The more familiar you get with the tractor, the more you’ll be able to do. In the end, that hill won’t be any problem and you’ll have it cut clear to the fence.
  2. #32
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,816
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    Congratulations, slopes are really hard to judge from a picture and always feel a lot steeper while you are actually on the tractor or at least it does to me.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  3. #33
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Quote Originally Posted by blount2000 View Post
    Well, I succeeded in mowing up a little bit higher on the ditch. The county has not cut in a while, and the tall grass was blocking my view whenever turning out of the driveway so I went ahead and cut what I could. As described in my original post, it was still a bit spooky mowing on the incline.
    I wasn't able to cut the entire length of the fence line, but at least I can see now when pulling out of the driveway. I still need to try to get a bit closer to the actual fence, but that will be a challenge for another day.
    The first picture is from back in May when I was originally asking about mowing the ditch, the second picture is from when I cut the ditch this weekend (you can see the cut is a little closer to the fence), and the third picture is of the ol' girl who is doing the work!
    It may not be the prettiest tractor, but it still works mighty fine!
    Yeah,u can go way wider on the tires!!!Why do they not mow to the fence-line?
  4. #34
    Super Member teg's Avatar
    Join Date
    Jul 2005
    Posts
    5,725
    Raleigh, NC Hillsville, VA
    L2800 - HST
    Looks like the worst part is behind you... and the part by the fence is (a little more) level.
    The "get a bigger tractor" people are destroying what TBN was, a friendly forum... now it's IF YOU DON"T DO AS I SAY!!!! or WHY ARE YOU NOT LISTENING TO ME!!! Get over it, it's just your opinion... a small tractor is just fine!!! (Zipping up my flame suit!!!)
  5. #35
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    As said before pictures don't do slopes justice. Here's some shots of my old kubota B2910 on a slope that I mow regularly. I took these shots in response to those who had told me you can't run on 15 degree slopes.
    Attached Images Attached Images
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  6. #36
    Join Date
    Mar 2009
    Posts
    18,816
    Missouri
    Quote Originally Posted by ovrszd View Post
    Great pictures.
  7. #37
    Silver Member ametcalf's Avatar
    Join Date
    Apr 2011
    Posts
    173
    Central KY
    Kubota BX23
    I recently relocated out in the country to a 10 acre piece of property. About 7 acres is flat pasture/fields and the other 3 acres is woods. I'm a new tractor owner (I'm new, not the tractor!), and I mow the pastures using a Ford 8n with a 5' bush-hog. Since everything I mow is flat, I haven't had any instances where I felt real nervous or anything.
    However, last week I made a partial pass to cut along the ditch at the road (between my fence-line & where the county mows the roadside) and I did not like the feeling of it at all. The ditch is relatively smooth and is not super steep or anything, but the sensation of mowing "unlevel" kinda spooked me, so I elected to not mow the rest of the ditch.
    I'm wondering if I was just being too cautious (i.e. scared), or is the "unlevel" sensation normal and is just something that people get used to the more they use a tractor?
    I think we are all assuming that you have an override clutch on the pto between the tractor and the bush hog. It keeps the momentum of the spinning bush hog blades from pushing the tractor when you depress the clutch. I found that without an override clutch an 8n is hard to mow with even on level ground. A friend of mine got pushed through a fence and almost over a river cliff before he got his stopped.
    ametcalf
    All I need to be a better mechanic is a bigger hammer.
    2004 BX23, 72" Landpride finish mower, 48" Howse tiller, Home made brush forks, grapple, and plywood skidplate.
    Allis Chalmers 5040, 6 Bushhog, Boom pole, PHD, Box Grader, Rear Blade, 2 bottom plow
    2000 Crewcab Super Duty F250 Powerstroke Diesel 260k miles
  8. #38
    Join Date
    May 2006
    Posts
    16,759
    Missouri
    Quote Originally Posted by TripleR View Post
    Great pictures.
    Thanks TripleR, living up to our motto, "Show Me State", pictures are a necessity!!!
    Richard
  9. #39
    Gold Member
    Join Date
    Jun 2007
    Posts
    284
    PNW
    '07 KuBoTa B7800 and Jinma 254
    Blount2000,
    You might like to look into obtaining a sickle mower of this type: Ford 501 Mowing Machine/Sickle/Brush/Disc Mower | eBay
    I'm not sure that any are made anymore (probably got deemed "unsafe" by Nannygovma) but there are many available in most any condition. The Ford versions are parts available items meaning that old ones can be kept cutting for years.
    The implement seems perfect for your situation since they are hinged to be able to adjust to several angles of slope and would allow for cutting that bank while keeping the tractor on more level stable ground. They were used for Hay mostly in their day and by their nature would not make good brush and vine cutters. For your grassy slope it's what I'd be looking to buy, even though most seem like weird "Rube Goldberg contraptions".
    I don't think you're wrong to play it safe on slopes as they can be all kinds of tricky. I've got areas I won't try to cut except by backing my cutter up and down in dozens (hundreds?) of tedious fuel burning movements rather than risk watching my high side front wheel rise slowly a foot off ground if the low side encounters even a slight dip. It's scary as all get out and no slope is worth having the tractor roll downhill with me in a back wrenching upside down ride, strapped poorly into the seat.
  10. #40
    Veteran Member MESSMAKER's Avatar
    Join Date
    May 2009
    Posts
    1,557
    Bluegrass,KY
    Bobcat ct 225
    Remember to lookout for dips or holes on the low side. They can make things exciting quick. This can lead to trouble if you are close to the safe limit already.
Similar Threads
  1. Buying Advice Advice on 2320 purchase for mowing and snow removal
    By JJKJ in forum John Deere Buying/Pricing
    Last Post: 12-20-2009, 09:58 PM
  2. Mowing It's better than a BX for mowing!!!
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 07-08-2009, 10:16 AM
  3. Mowing BX2350 Spring steep hillside mowing in Ky
    Last Post: 04-04-2009, 09:07 AM
  4. Mowing Mowing ditch
    By SCOTTO in forum New Holland Owning/Operating
    Last Post: 09-07-2006, 07:50 PM
  5. Screw the Backhoe for the Oozama Ditch! Or, ...
    By glennmac in forum Projects
    Last Post: 06-25-2003, 12:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
