3-Point Hitch Replacing hitch pins with bolts
   / Replacing hitch pins with bolts #1
beenthere
Super Star Member
Southern Wisconsin, USA
JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
From a recent post, I was reminded of replacing my seldom-used hitch pins with bolts and lock nuts.
I had a couple incidents when brush ripped the hitch pins loose and left the 3 ph arms dangling. I was fortunate to catch the problem before any damage was done (some have broken castings as a result of losing a pin).
Because I seldom (if ever) would need to remove the 3 ph arms, I replaced the hitch pins (the ones shown in the attached pic) with bolts and lock nuts. Same with the pins that attach the iMatch, as I seldom take it off (but did rip off the hitch pins on occasion).
   / Replacing hitch pins with bolts #2
I think I should probably do the same,
larry
   / Replacing hitch pins with bolts #3
:thumbsup:I haven't tried the bolts yet ,but switched all the regular lynch pins for the black heavy duty ones from Tractor Supply. So far I haven't had one of these to get pulled out by sticks yet.:D Just don't get any skin caught when closing them.:confused2:
   / Replacing hitch pins with bolts #4
I've only lost one hitch pin on my 855 and that was while using the box blade in an attempt to break up ice on the drive (sort of worked).
I don't have an i-match but do have a Pat's easy change system. Not sure if it's an idea I read here or came up with on my own but I plan to buy some heavy washers, weld some nuts to them and then use bolts and red loctite to secure them. I don't have enough of the fancy bent washers the Pat's system comes with so this would suffice and maybe not come off.
   / Replacing hitch pins with bolts #5
I find this interesting. I grew up on a farm. We used 3PH implements quite often, but I don't ever recall losing any pins. They were standard hitch pins with lynch pins to keep them in place. Why do y'all have these troubles? Just wondering.
Dave
   / Replacing hitch pins with bolts #6
Red is considered permanent. Heat must be used to get things loose. Just be careful where you use it.
   / Replacing hitch pins with bolts #7
Dave
Dunno the 'why'. can only say that I've lost several.
Presumably due to sticks getting in there and unlocking them(I lost several working a brush pile).
   / Replacing hitch pins with bolts #8
Dave
Different kind of work probably. Back and forth over heavy brush is pretty effective at getting them off.
   / Replacing hitch pins with bolts #9
I use HD lynch pins and safety wire some of them closed. I mow large areas of sage brush, 2' + tall, this can open a pin fast.
If I were to use bolts I personally would use lock nuts on them.
E/S
   / Replacing hitch pins with bolts #10
A bit off topic, but here is the photo that you may be referring to.
The washer on the right has a black, heavy duty lynch pin. They are strong.
Just using a bolt through the two washers might work.
Using a nut instead of one of the washers would also work. It would seem to be a bit rigid. I'd use a nut on one side and a washer on the other if that was the choice.
If you weld the nut to the bolt's thread then it would be permanent - until the O/A torch is used.
