Results 11 to 20 of 20
05-17-2011, 04:41 PM #11
05-17-2011 04:41 PM # ADS
05-17-2011, 07:52 PM #12Platinum Member
- Join Date
- May 2004
- Posts
- 788
- Location
- Harpers Ferry WV
- Tractor
- Kubota L4330, 6 rear remotes
Re: Lifting logs with a SCUT bucket
I don't understand why he is against hooks on top ...but I would say having only two hooks, one on each side, is an invitation to disaster ...or a requirement for always using twice as much chain as otherwise required.
I have found it very (very) important to have any (heavy) chained load centered...otherwise raising the bucket raises the opposite rear wheel, which can be very disconcerting (and dangerous, depending) ...and, I have a heavy tractor, big loaded turfs, and usually an implement on the rear.
I'd discuss this again with the dealer
05-17-2011, 08:05 PM #13Elite Member
- Join Date
- Nov 2005
- Posts
- 2,857
Spend money (-:
At least add a grapple to the bucket.
Better yet get a separate grapple.
Is this a li'l tractorette ? (I don't know the Kubota product line)
Does it have a hoe ? If so and if that has the capacity to lift what you want to move around - add a thumb to the hoe.
05-17-2011, 08:31 PM #14Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,753
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Hook at the center can result in a bent bucket (unless you brace it...been many many threads on that).
Hooks on the ends distribute the load (on the bucket) better and you can use one chain (if it's long enough) by running through those outer hooks, then to the item you're lifting. Wish I had a pic since that would show the rigging a lot better then I can explain it.
My bucket has 3 hooks...one in the center (for light work) and two outboard (heavier stuff, obviously). Mine are positioned the same as Veresjwv's are (pics in post #11).
But I agree with you on NOT using one outboard hook to lift a load.Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
05-17-2011, 08:41 PM #15Veteran Member
- Join Date
- Jul 2005
- Posts
- 1,924
- Location
- NH seacoast & Coos County
- Tractor
- Kioti DK45S
Since you're talking lifting onto the splitter I'm assuming you're already cut to length. Use tongs or something like this Log Grabber alternate to tongs
These hooks are used on wreckers & may be available for less $. Or you could cut the handle off a couple of pulp hooks & weld on some chain for under $100.
If you have a quick detach bucket you could get a fel mount short boom pole & with wood would still weigh less than a bucket full of dirt & would have better reach.
Also keep in mind that lifting from one end mounted hook places tristing force on your FEL arms. Bend buckets are easier to fix than twisted loaders. When lifting from corner hooks with the chain at 45 degree angles to the load doubles the effective load on each chain. Reinforce your bucket for a center hook or get a quick attach boom pole/forks. MikeD74T
05-17-2011, 09:43 PM #16Bronze Member
- Join Date
- Apr 2011
- Posts
- 67
- Tractor
- Looking
Thanks for all the input.
Just to clarify: what I'm planning on doing sounds similar to what RoyJackson described: string a chain across both outboard hooks, then center a chain with tongs coming off that. Already using the neighbor's splitter and have a design for a horizontal homebuild ready to go...Reg you're already hurting my feelings and my "l'il tractorette" hasn't even arrived yet. I admire all the big boys but my property doesn't justify anything bigger than a subcompact. I had to laugh at the smart@ss comment about cutting smaller logs, you're right that would seem to be the easiest solution
But the situation is, the tree guy drops off what he likes and I don't turn anything away when it's free wood. I only have an 18 inch bar on my saw and it's a bigger pain to cut a 24" or 30" log with a saw than it is to dump it on the splitter and let the 4 head take care of it that way. As far as loading in the truck, I only have a 5 foot lift on the bucket so loading on the tailgate is exactly what I had in mind. Still need to figure that one out, because with the log tongs there's no way I can lift the bigger pieces that high. It's not a necessity now to load the truck, but one of the local surgeon's gave me a green light to go down to his yard and take away the bigger pieces he's got there (again, I can cut those pieces up with the saw for transport but even a chunked up 30" piece is a hefty lift into the pickup). I agree on the grapples, but I used up all my points getting the wife to agree to the tractor to begin with, it's been made very clear that there will be no expensive implements added on any time soon.
Best place for a heavy duty set of tongs? Straps for logging? Any more pics or ideas would be appreciated.
05-17-2011, 11:03 PM #17Platinum Member
- Join Date
- May 2004
- Posts
- 788
- Location
- Harpers Ferry WV
- Tractor
getting big pieces into the truck: (1) its amazing what you can haul up an inclined plane...make/buy one, then rig a pulley at the front of the bed, behind the cab and with winch rope, pull it up the ramp by backing tractor up ... (2) buy a small HF (ATV) winch and mount in truck bed, pull up ramp; (3) push up ramp w. bucket; (4) make a "loading dock" to get your tractor high as/higher than the bed...or, your truck lower
Just thinking out loud
05-17-2011, 11:03 PM #18Veteran Member
- Join Date
- Jul 2005
- Posts
- 1,924
- Location
- Tractor
- Kioti DK45S
sw18x " string a chain across both outboard hooks, then center a chain with tongs coming off that.'
Be very careful with that. Sideloaded hooks can release a chain quite easily if you bump the load on tailgate or splitter. MikeD74t
05-18-2011, 12:26 AM #19Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
sw18x
I have used my logging tongs to lift large rounds onto the splitter, but found that the tongs and chain would get in the way of splitting.
What I do now, is have the firewood blocks cut to length with the chainsaw. Then I roll one or two of them into the bucket and move the bucket to the splitter with the lip at splitter height. Then I can pull a block at a time off onto the splitter. Half of the first split goes back in the bucket, while I either hang onto the other half or let it drop to the ground.
I find when working alone, that raising the large rounds in the bucket and working out of the bucket works most efficiently for me. Don't have the bucket and chain and logging tong hanging around over the splitter when I'm splitting, as it is not as safe as I'd like it to be.
Another option I've used is to put an empty pallet on my forks, and roll some rounds on the pallet and use that pallet as a work platform at splitter height.
For any very large rounds, or knarly crotches, I just bust them down into smaller pieces using the chainsaw. It is prolly as fast as raising them onto the splitter.
05-18-2011, 03:42 PM #20Silver Member
- Join Date
- Nov 2008
- Posts
- 110
- Location
- Washington Grove, Maryland
- Tractor
- Kubota, BX22
SX18x,
I have a BX22 with the FEL & BH. I put a Bro-Tek Thumb on the BH & splitting is now a breeze. Definitely the way to go if you can. Forks on the Bucket if not. The advantage with the BH is being able to pick it up and shift it around until it will sit on the splitter, less of an issue if your splitter is vertical. My
T-Man.
Similar Threads
BX2360 and lifting logs
By sw18x in forum Kubota Owning/OperatingReplies: 21Last Post: 05-25-2011, 11:01 AM -
Bucket forks, but wait! These are different!
By whodat90 in forum Build-It YourselfReplies: 6Last Post: 11-17-2010, 03:35 PM -
welding chain links on bucket and loader arms
By stevef in forum AttachmentsReplies: 25Last Post: 01-19-2010, 07:46 AM -
Backhoe Backhoe bucket mount
By davesisk in forum Power TracReplies: 5Last Post: 06-12-2002, 04:45 PM
