Results 1 to 10 of 15
05-29-2011, 05:29 PM #1New Member
- Join Date
- May 2011
- Posts
- 5
- Location
- Southern Wisconsin
- Tractor
- John Deere 755 MFWD
755 John Deere, 4wd Front Spindle Play-Movement
Hello all from Wisconsin.
I have a JD755, 4wd with some front wheel play. I do not have a lot of experience in this department, tractor department that is, but if it was on my car I would suspect that a wheel bearing is out. I looked up assembly diagram of the front spindle assembly and while there is bearings, shims and other related items there is not a nut to tighten. Kind of looks just like snap rings that hold the spindle together. I am suspecting that it needs a little play for the worm gear drive. So I am wondering if this is normal for this tractor and what would be excessive?
Thanks for all the help!
05-29-2011 05:29 PM # ADS
05-29-2011, 06:27 PM #2
Re: 755 John Deere, 4wd Front Spindle Play-Movement
Welcome to TBN!
05-30-2011, 10:38 PM #3Silver Member
- Join Date
- Aug 2009
- Posts
- 136
- Location
- Southern Quebec
- Tractor
- Deere 855
I just replaced the final drive seals on my 855 last year. Same front axle as 755. Basically there are 2 identical bearings on each side for a total of 4 bearings. I would change them ASAP before the gears and seals wear out or break.
05-30-2011, 11:46 PM #4Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
dsmau
Where do you think the "play" is coming from? Worn gears, or worn bearings?
Since you experienced the change-out, how is play taken up - - with shims?
05-31-2011, 09:30 AM #5New Member
- Join Date
- May 2011
- Posts
- 5
- Location
- Tractor
Thank you for the replies.
dsmau,
Did you end up replacing just the seals or did you end up replacing all of the bearings, shims, etc..?
05-31-2011, 02:45 PM #6Silver Member
- Join Date
- Aug 2009
- Posts
- 136
- Location
- Southern Quebec
- Tractor
- Deere 855
My only problem was leaking front spindles so all I did was to change the seals. While I had everything in hand, I checked the bearings and they were in good shape. I have not seen shims and there are no shims in there according to the manual.
Service Managers at the dealer told me that bad bearings can cause seals to fail but that was not my case. 20 year old seals tend to be quite fragile and I had just worked in the mud up to the front axle...
You just need to flush the oil, take off the 6 bolts behind the wheels and pull. Everything falls in your hands and you need a GOOD pair of snap ring pliers to take the final assembly apart. Don't forget to get a new gasket (one per side) and 2 quarts of GL-5 Gear Lubricant to put it back together.
05-31-2011, 02:50 PM #7Silver Member
- Join Date
- Aug 2009
- Posts
- 136
- Location
- Southern Quebec
- Tractor
- Deere 855
Can you define more where the "play" is?
Is it when you rotate the wheels back and forth in their normal spinning movement OR when you push and pull with one hand on the bottom and one at the top of the wheel?
If it is the later, only the bearings can cause the play as far as I see it.
05-31-2011, 03:02 PM #8Silver Member
- Join Date
- Aug 2009
- Posts
- 136
- Location
- Southern Quebec
- Tractor
- Deere 855
05-31-2011, 03:05 PM #9Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
dsmau
Those posts helped, and I also could see no place for shims.
Also wondering where the "play" is.
05-31-2011, 03:22 PM #10New Member
- Join Date
- May 2011
- Posts
- 5
- Location
- Tractor
When I have the front wheels off of the ground and proceed with the left-right or push-pull test they do have some movement. You can actually see the wheels, not so much when you are driving, shift or drop when you lift the front end off of the ground. I only noticed it because I was checking tire pressures.
I also looked through the SM and did not see a takeup nut or shims. So I am thinking I may have some bearings going out. What do you all think?
Similar Threads
Front-End Loader 27hp John Deere 790 4wd
By 790greene in forum AttachmentsReplies: 14Last Post: 04-11-2012, 10:09 AM -
CL Scam?????
By Kubota 2350 in forum John Deere Owning/OperatingReplies: 30Last Post: 11-02-2010, 06:55 PM -
John Deere 755 blowby
By Marty6645 in forum Parts/RepairsReplies: 5Last Post: 01-05-2007, 05:42 PM -
John Deere, how did you make my tractor?
By JohnMiller3 in forum John Deere Owning/OperatingReplies: 1Last Post: 07-29-2001, 04:23 PM
