Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Join Date
    Dec 2009
    Posts
    136
    Solon Springs, Wisconsin
    New Holland T 1520
    Default Re: Need Help; Setting Granite Step
    The blocks of ice idea is too good not to try
  2. #12
    Join Date
    Aug 2008
    Posts
    1,555
    Barrington, NH
    Bobcat CT230
    I had a couple in this size range of field stones when I did my front walkway. I wrapped a logging chain around the stone, hooked it to the trailer hitch and dragged it next to where I wanted it laid.
    Once the hole was ready, I took a couple of 4x4s and put them next to the rock on both sides. Then used a 6 foot pry bar to inch it into place. (lift, wiggle, drop, repeat on other side, then back) (Didn't have a back hoe, 3 pt, or FEL at the time.)
  3. #13
    Veteran Member JDGreenGrass's Avatar
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by Rustywreck View Post
    I agree.
    I am going to do the blocks of ice along with the pinch bar. I am going to set the flat back, oval front 7" step on the ice Sunday morning 'bout 7am. I figure by mid afternoon she'll be all set and in place with nothing but a minor puddle of water hanging around.
    The cobblestone patio has been hard work but turned out great. I have one more "layer" of polymeric sand to sweep into the cracks and gaps and then getting the step into place at which point I will be done. Boy, a little carpentry project and stacking more wood will be a pleasure after this brick stuff.
    JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
    64" Frontier Snowblower
    Favorite Color....Green
    The sky was yellow and the sun was blue.
  4. #14
    Gold Member BeeferMan's Avatar
    Join Date
    Jun 2008
    Posts
    402
    North Central MA
    Case 1194, Ford 641, NH TT75A
    The blocks of ice idea is great, too good not to try as someone said. But myself, I would have set the block down then just pulled the straps out...
    Case 1194, NH TT75A, Ford 600, Bobcat A300, balers, rakes, mowers, tedders, spreaders and lots of other toys as well...
    - Jim
  5. #15
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by JDGreenGrass View Post
    I agree.
    We build alot of patios in my business and generally use a plate compactor and mason's sand both as a bed and in the cracks after setting. No problems or issues with the sand, curious why you need to use the polymeric sand and what benefits you feel you are getting for the increased cost?
    In my locale we have several different colors available and can usually get something to match for around $25/ton.
  6. #16
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by jenkinsph View Post
    I dug out space to add about 6" of inch and half gravel on top of what was already there, hard pan gravel. I compacted the gravel with a #500 rented compactor. Then, I screeded more of the gravel to get the pitch correct, 1" for every 4'. Compacted again to a near final grade surface. Then, I screeded a bed of sand to a final grade on which the pavers would lay. I laid the pavers and rented a #160 compactor to "set" the pavers down into the sand. At this point the pavers became very secure. No teddering or movement. Then, I swept the polymeric sand into the joints and gaps between the pavers, watered and allowed the poly sand to set and bond. In a half hour it was a rock solid finish. Really nice.
    Tonight I am going to sweep another round of the poly sand over the pavers to make the "gaps" even less deep. Water and be done with it all.
    This is my first experience laying pavers and I used all the advice that the stone center offered, people that have an excellent reputation in this area.
    Jenks...Are you saying you use just a pebble sort of sand...no bonding agent.?? Over time I would think that you would loose the sand.?? Not to mention tracking it. Don't get me wrong, I think I could have gone with just sand but, I think I gain a better end product using the bonding sand.
    I have no idea what he charged me for the sand.?? I can say I paid about $1100 for the paver patio which is roughly 18'x24'. I am thrilled with the finished product. Love the edgeing blocks.
    I am going to post a thread in the Projects forum after I get my granite step in place.
  7. #17
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by BeeferMan View Post
    No, you wouldn't have done that.
    It would become a try, try again scenario.
  8. #18
    Veteran Member hunterridgefarm's Avatar
    Join Date
    Jul 2005
    Posts
    2,116
    Western NC
    Kubota L3130DT, Kubota L185DT, JD LX277
    I like the ice method. Just get a torch and melt the ice once the step is in place. You don't leave it to melt and come back and see the ice melted uneven and the step slid out of place.
    I recycled old granite steps from another farm we have, 5'x10"x8"...heavy. Unfortunitly mine were uneven on the bottom so I had to pour a footing and set the fist step on a bed of mortar, let it setup, fill in behind it then set the next step. Moved them in place with the forks on the tractor and use a crowbar to position. This was before the sidewalk was put in so I had to allow for the thickness of the sidewalk. I don't have a good picture of the finished work but you can see part of the steps in the picture.
    Attached Thumbnails Attached Thumbnails Need Help; Setting Granite Step-100_0818-jpg
    Attached Images Attached Images
    I suffer from MPD...Multiple Project Disorder
  9. #19
    Join Date
    Oct 2009
    Posts
    1,578
    Maine
    John Deere 770
    Quote Originally Posted by hunterridgefarm View Post
    Of course I am not going to leave it unattended. I will be home watching the ice melt throughout the morning. When things need an adjustment I will be handy and ready with a pry bar to square things up.
    I want to see how even the ice blocks melt. I am willing to bet there won't be much prying. We'll see and I will report back.
  10. #20
    Gold Member acme97's Avatar
    Join Date
    May 2011
    Posts
    327
    Cottageville, SC
    Kubota L35, Kioti DK50SE
    Sounds like you need a chair, beverage, and cooler full of ice-shims just in case.
Similar Threads
  1. Bx24 --Step by Step attach the 3 point Hitch
    By Hotwheels in forum Kubota Owning/Operating
    Last Post: 11-19-2012, 09:08 AM
  2. Ford 3000 Clutch Release Finger Setting
    By John Ford3600 in forum New Holland Owning/Operating
    Last Post: 11-12-2010, 11:52 PM
  3. Mow Using 960 PTO Setting?
    By bp fick in forum Kubota Owning/Operating
    Last Post: 10-11-2010, 10:25 AM
  4. Another old guy step
    By kubotajoe in forum Build-It Yourself
    Last Post: 12-31-2006, 10:36 AM
  5. repost - step on Grand L
    By HunterdonPaul in forum Kubota Buying/Pricing
    Last Post: 10-15-2001, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
