Results 1 to 10 of 34
07-06-2011, 07:45 AM #1
Need Help; Setting Granite Step
Call for help here....
I just installed a cobblestone patio at the front of my home. Today I compact the blocks and then add polymeric sand to the joints, wet, and bingo...Done.!!.......Well, sort off.
I need to set a 4' by 2' granite step at the front door. It weighs some where around 300lbs. I can get under it as it sits right now on blocks. I figure to use 2 straps to pick it up with the bucket and move it into place but, what do I do once it is lowered onto the straps.??....How do I set it in place.??
Wish I had forks.....JD770 '92 4x4 SMC FEL JD Ballast Box 6' CountyLine Back Blade 6' CountyLine Rake CountyLine CarryAll
64" Frontier Snowblower
Favorite Color....Green
The sky was yellow and the sun was blue.
07-06-2011, 07:58 AM #2
Re: Need Help; Setting Granite Step
Block's and lever"s
Egon
50 years behind the times
Livin in a
Worn out skin bag filled with rattlin bones
07-06-2011, 08:30 AM #3Super Member
- Join Date
- Feb 2008
- Posts
- 7,737
- Location
- somewhere usa
- Tractor
- stuff
Some pieces of pvc pipe and as Egon mentions blocks of wood and pinchbar.
I use forks to get them close but still use the old methods for positioning large slabs of stone as they can be easily broken.
07-06-2011, 08:37 AM #4
07-06-2011, 08:52 AM #5Platinum Member
- Join Date
- Aug 2005
- Posts
- 950
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100 (50 Hp, 42.5 pto) 1968 Cub, B7200 HST
I lowered mine in with forks (it is a bit easier than the bucket but hey of u have the bucket it will work fine), just use a "digging bar" (long steel bar with a flat end), and a log or big rock as a lever point. Lift one side a wee little bit, slip the strap out, then do the other side. The bar will also let you lever the slab into place. We just sat a 1345# concrete slab this way, leverage is your friend!
1985 B7200 HST
1968 IH Cub Lowboy (being rebuilt currently)
07-06-2011, 09:10 AM #6Member
- Join Date
- Sep 2006
- Posts
- 25
- Location
- Flint Hills of Kansas
- Tractor
- Challenger 295
You could use the straps, set the granite on some chunks of ice, remove straps and wait for ice to melt....
07-06-2011, 09:14 AM #7
[QUOTEYou could use the straps, set the granite on some chunks of ice, remove straps and wait for ice to melt....[/QUOTE]
Five Stars for that idea.
Egon
Livin in a
07-06-2011, 09:45 AM #8
07-06-2011, 01:05 PM #9
07-06-2011, 11:45 PM #10Member
- Join Date
- May 2011
- Posts
- 38
- Location
- Sunshine coast British Coloumbia
- Tractor
- Kubota tbd
Similar Threads
Bx24 --Step by Step attach the 3 point Hitch
By Hotwheels in forum Kubota Owning/OperatingReplies: 11Last Post: 11-19-2012, 09:08 AM -
Ford 3000 Clutch Release Finger Setting
By John Ford3600 in forum New Holland Owning/OperatingReplies: 0Last Post: 11-12-2010, 11:52 PM -
Mow Using 960 PTO Setting?
By bp fick in forum Kubota Owning/OperatingReplies: 15Last Post: 10-11-2010, 10:25 AM -
Another old guy step
By kubotajoe in forum Build-It YourselfReplies: 10Last Post: 12-31-2006, 10:36 AM -
repost - step on Grand L
By HunterdonPaul in forum Kubota Buying/PricingReplies: 16Last Post: 10-15-2001, 11:27 PM
