Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Jul 2010
    Posts
    10
    NE Ohio
    John Deer 2305
    Default Front tire rub....mystery bolt JD 2305
    Been a while since I was last here...I guess that is a good thing since I usually only have to visit when I have a problem....so....
    Have a 2010 JD 2305 with the 62" belly mower. This is my second year with it...and it seems as if something has gone wrong over the course of the winter.
    When (and only when) I make a sharp right turn (with mower attached) do I get a rubbing on the inside of the left front tire (see photos). It turns out the tire is acutally hitting the spring loaded pin which secures the mower bracket to the front frame of the tractor. I am pretty darn certain I did not hit anything hard enough to bend anything, everything is still working properly, but I am slowly taking pieces of rubber out of my front tire on sharp right turns.
    I contacted the dealer...they can only scratch their head. I thought about trying to relocate the roller pin inside this spring, but I think I will have issues removing it if I do that. Any ideas here other than not making sharp right turns with the tractor?
    On another note...not really sure if this could be realted, but about a week after I noticed the tire rubbing, I found this bolt in my driveway. Have no idea where it came from...the tractor, my truck, the neighbors tractor...again, no idea.
    Sent these photos to my dealer...and they have no ideas on either of these items.
    Anybody have any ideas as to what may have gone wrong, or what to do about it or where this mystery bolt may have come from? Again, everything on the tractor is still working fine, so not sure how/why/where these things came from.
    Thanks
    Mike
    Attached Thumbnails Attached Thumbnails Front tire rub....mystery bolt JD 2305-img_0127.jpg   Front tire rub....mystery bolt JD 2305-img_0128.jpg   Front tire rub....mystery bolt JD 2305-img_0129.jpg   Front tire rub....mystery bolt JD 2305-img_0130.jpg
  2. #2
    art
    art is offline
    Super Member
    Join Date
    Apr 2000
    Posts
    5,850
    central New York
    all makes and models
    Default Re: Front tire rub....mystery bolt JD 2305
    Most tractors I've seen have stops for the steering that would be adjusted to keep the front wheels from turning to far and allowing them to hit the tractor sheet metal.
    I'd check the other side or look in the owners manual and see what it may say.
  3. #3
    Gold Member
    Join Date
    Sep 2008
    Posts
    332
    Poniatowski, WI
    Bobcat CT225
    I'm with Art. I'd check the right front for that missing stop bolt. I'm guessing above and slightly behind the axle.
    -rus-
    Bobcat CT225
    middle buster, three-point forks, chain-on brush forks
    "borrowed" drag & disc stored at my house
  4. #4
    Join Date
    Mar 2010
    Posts
    75
    VA
    JD 1026R
    My 2305 mower mount came with a replacement for that bolt/pull-tab. The updated part sat lower and didn't rub. I wonder if your dealer couldn't help you out here?
  5. #5
    Veteran Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    1,279
    central Iowa
    JD 2720
    Quote Originally Posted by HunterWare View Post
    Wasn't there a thread a while back about JD replacing this pull-tab with the "L" shaped handle?
    HAVE FUN
    do yourself a favor, floss
    2720
  6. #6
    Gold Member jnjpream's Avatar
    Join Date
    Sep 2008
    Posts
    262
    Berthoud CO
    BX22
    BTW, the stop used when turning to the right is typically on the right side of the axle.
  7. #7
    New Member
    Join Date
    Jul 2010
    Posts
    10
    NE Ohio
    John Deer 2305
    Thanks for the feedback everyone....
    I have given that front axle a good look over and see nothing resembling a threaded hole for that missing bolt. When I pick the tractor up (with the bucket) I turn the wheel fully left and right....it stops in both directions with the casting banging into the hub...on both sides. Again, don't see where any type of adjustment can ocurr.
    Nothing in the manual about it, and my dealer knows nothing about it.
    I am going to go back to the dealer and inquire about the "L" bracket for the mower and ask again about the bolt.
    If any of you have a 2305, and see where the steering can be adjusted, PLEASE share a photo with me...I am ok with a hurt ego if it solves the problem for me.
    Thanks
    Mike
  8. #8
    New Member
    Join Date
    Sep 2011
    Posts
    2
    I'm having the same problem, I took it to the dealer and they replaced the pin. The tire is not rubbing now but to me this is not the proper resolution. The tire never rubbed in 100 hours so why is it rubbing now?
    Did you resolve your issue?
    Thanks
    Shawn
  9. #9
    Gold Member North Country's Avatar
    Join Date
    Apr 2011
    Posts
    342
    VT
    John Deere 2305
    Anyone have a part number for the replacement pin?
    NC
    My hills have hills.
  10. #10
    New Member
    Join Date
    Sep 2011
    Posts
    2
    The dealer didn't give me the paper work for the warranty work so I'm not sure on the part number. I'll look on the pin and see if there is a number.
Similar Threads
  1. Tires L-3130-HST right tire wear on outside. front axle problem.
    By tibzy in forum Kubota Owning/Operating
    Last Post: 04-16-2011, 07:33 PM
  2. Tires Ford 1700, tractor front tire question
    By James48843 in forum New Holland Owning/Operating
    Last Post: 08-25-2009, 05:31 PM
  3. Constantly flat front tire.
    By N80 in forum Owning/Operating
    Last Post: 07-16-2009, 11:01 AM
  4. Tires Changing a flat front tire w/o a jack is cool
    By flyngti in forum John Deere Owning/Operating
    Last Post: 01-06-2008, 12:19 AM
  5. Unexpected Tire Experience
    By robertm in forum Kubota Owning/Operating
    Last Post: 06-11-2004, 10:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
