Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
  1. #11
    Join Date
    Apr 2000
    Posts
    1,780
    North Central Arkansas
    John Deere 4520,
    Default Re: Next project, brush hogging (I think)?
    Quote Originally Posted by IronHog View Post
    Two words: Roundup
    Thank me later.
    I agree if was left by the right of way mowers for the power lines there most likely is trash in the area. Knock it back with weed killer next year be able to see what is there.
    ken
  2. #12
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,816
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    I sure can't beat the advice given so far, I have mowed such areas and keep the FEL bucket pretty low which has saved my tractor and cutter.
    I prefer a broad leaf control product like Crossbow so I don't kill the grass. After the die off, you will be able to see the fence better and probably be able to get a bit closer with the tractor. After that, it is going to be manual labor to do it right.
    In the end I guess it just depends on what you want it to look like.
    "In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
  3. #13
    Platinum Member DAY's Avatar
    Join Date
    Feb 2011
    Posts
    664
    Eastern PA
    Ford 4500 TLB, Kubota L2900GST
    I second the advice to walk the area first. Considering the damage that might be avoided, you're getting "paid" a $100 an hour to take a hike. Besides, you need the exercise!
  4. #14
    Gold Member acme97's Avatar
    Join Date
    May 2011
    Posts
    327
    Cottageville, SC
    Kubota L35, Kioti DK50SE
    I don't think you need to really walk the line. As others have said keep the bucket low - I usually keep mine at a slight angle upward so that if I do hit something, it rides up. Go very slow, and always keep an eye all around you. Make sure you are prepared for getting swiped by thorns, and running into wasps. Do your first pass on the outside limit from the fence so you don't hit it. Also double check all the pins to make sure they are wired in and you don't get them pulled out. Check for any dangling hoses etc that might be caught on something. Keep in 4 wheel drive, and watch your temps. You might want to clean the screens before each pass. Where outside of DC are you? I'm up in Alexandria, but my place is in SC.
  5. #15
    Super Member Farmwithjunk's Avatar
    Join Date
    Aug 2005
    Posts
    7,514
    Mt Washington, Kentucky
    Where do I begin.....
    Here's one of my favorite tricks, and it doesn't cost a penny....
    Wait until the dead of winter to mow.
    You have less (maybe no) foliage to contend with. That's a plus.
    You have less "critters"/insects to contend with. That's a plus.
    Brush has less "life" in it, resulting in easier cutting. That's a plus.
    Gives you an excuse to play with the tractor when there isn't much else to do. That's a plus.
    After that, you can start off fresh in the spring, no brush in the way, and keep it tended.
    There are three kinds of men;
    1.) The ones that learn by reading
    2.) The few who learn by observation
    3.) The rest of them have to pee on the electric fence for themselves.
  6. #16
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,265
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Quote Originally Posted by deere5105 View Post
    If I were dealing with this, I would run bucket about 2' to 3' above ground...
    I'd suggest keeping the lip of the bucket (lower (down to about 6-8 inchs might be better) no more then 12" off the ground and the bucket in dump about 45 degrees down.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  7. #17
    Gold Member silvertramp's Avatar
    Join Date
    Feb 2010
    Posts
    374
    W. MA.
    Yanmar 276D
    Initial cutting like that is much easier in the spring/fall. Before or after the growth season. You'll be able to see much better.
  8. #18
    Join Date
    Jul 2010
    Posts
    526
    kubota 4200
    Oh this one is easy! Set the mower low and go over it without the mower on. Go slow and with two wheel drive. If the mower hangs on something get out and see what it is. If it goes smooth then go back over it with the PTO and the bush hog runnin'. On thing wrong is that method won't find wires/cables. But as far as something "big" it works. If I have a patch of stuff I've not mown in ages or I'm unsure of I'll just set my MX 6 low and drag it over the area to check it. If it all goes ok I power it up and mow.
  9. #19
    Join Date
    Sep 2009
    Posts
    999
    Southeast La.
    Kubota 2320
    Make sure you bring some light tools with ya in case your hog gets fouled up with wire or other junk . Most definitely be aware of mean critters that swarm out of the ground . Watch for tractor dippin' to the side . You may be driving into a hole that will roll ya .
    There are old sailors and there are bold sailors, but there are no old, bold sailors.
    B2320, 48 " Woods Brushbull, LA304 loader, modified Kingkutter carryall, Middle Buster
  10. #20
    Join Date
    Jun 2011
    Posts
    176
    St Louis Mo
    LS R4041EZ
    I second TripleR on the crossbow. I use it to get the brushy stuff killed and leave the grass. To keep the grass under control there will be some point in which you will need to get off the tractor (i hate this part) and get a heavy duty whacker. I know there is a tow-behind (DR I think) Fence mower that operates on a spring mechanism when it hits the posts but unless you have alot of fence the cost would be prohibitive.
    Dwight
    2011 LS R4041EZ w/FEL, 1949 Farmall Cub, Rotary Cutter, Box Blade, Harrow Disc
Similar Threads
  1. Brush Hogging and Tree Trimming at the same time
    By TGF in forum Owning/Operating
    Last Post: 07-22-2010, 08:26 PM
  2. Brush Cutter Project
    By shaun2733 in forum Build-It Yourself
    Last Post: 11-08-2009, 09:55 PM
  3. Brush Cutter Project
    Last Post: 08-11-2009, 10:58 AM
  4. heavy brush hogging
    By rantumscoot in forum Buying/Pricing/Comparisons
    Last Post: 07-10-2004, 12:42 AM
  5. Brush hogging and top links pins
    By RichZ in forum Owning/Operating
    Last Post: 09-23-2002, 08:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
