Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 45
  1. #11
    Veteran Member jake98's Avatar
    Join Date
    Nov 2007
    Posts
    1,914
    Dingmans Ferry PA
    53 Cub, 70's JD 410, Kioti 25hst
    Default Re: How bad is shale?
    I'm trenching about 14"x 20" around the edge where the spring flows. Took about an hour and a half, and I'm halfway around. It's amazing how this clay muck hardens up when it's dry.. I have some pipe so I guess I'll put it in, then bury it to around 20" thick. It'll still slope away from the shop.
    Attached Thumbnails Attached Thumbnails How bad is shale?-img_4308gotshale-jpg
    Kioti CK 25 Hydro: box blade, brush hog, rake, roto-till, grapple, bucket forks, de-stump cyl, Wallenstein Chipper
    John Deere 410 Backhoe Loader: 25 hoses ready to blow
    Thus by the beneficence of Providence, we shall behold our empire arising, founded on justice and the voluntary consent of the people, and giving full scope to the exercise of those faculties and rights which most ennoble our species.
    Samuel Adams
  2. #12
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    If I had a trench like you do already done, I would line it with filter fabric, put the perf pipe in, fill it with drain rock and fold the filter fabric back over the top of the drain rock.
    The shale might be free, but unless you know what the size range really is it may cost you more than you think in the long run. Drain rock is cheap, has known properties and is easy to work.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  3. #13
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by jake98 View Post
    That's the best way to deal with wet spots.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  4. #14
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Quote Originally Posted by CurlyDave View Post
    Good info. If his shale is like what is in my area, it will hold water in a wet spot, instead of draining it.
    Don
  5. #15
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Oh, geez..........my post count was 1313.........kinda superstitious.........so i'll add a nothing post.
    Or I could change my address to "Mockingbird Lane".
    Don
  6. #16
    Join Date
    Nov 2007
    Posts
    1,914
    Dingmans Ferry PA
    Dave, if it was an important location, I'd be with you 100%, but it's a no traffic spot where I just don't want my tires to sink in the mud. I might not even throw the pipe in. I don't know how to gauge the water flow, but I guessed it to be about 5 gal./min. when it's really springin.. It used to go thru the middle of my shop when I first built it, and the drought ended. I asked my plumber buddy what to do when it first happened, he said, "stock it."
    Samuel Adams
  7. #17
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    I know you asked Dave the question, but, once it's dried up........it will be a 'traffic spot', cause your gonna mow it.
    Move the water out of your way while you have the trench dug...........it will save headaches later on.
    If you don't want the pipe and fabric.........you could do something like a 'dry creekbed'.............only channels water during wet seasons..........that requires larger rock, but presents other problems when mowing on both sides.
    Don
  8. #18
    Join Date
    Nov 2007
    Posts
    1,914
    Dingmans Ferry PA
    It'll be 20" thick where the water flows Don, I think the water will stay below the surface, it's only 1/2" or so when it runs. I keep going back and forth on the pipe, I have it so I should probably put it in there. The drive that goes to the shop needs to be raised about a foot in one section (about 75') so I'll have to get some gravel and top it all off. Even free stuff ends up costing $..
    Thanks for the replies to all.
    Samuel Adams
  9. #19
    Gold Member davygp38's Avatar
    Join Date
    May 2009
    Posts
    478
    where NY,NJ, and PA all meet
    Kubota L4400
    Where I come from, Shale is the greatest thing that was ever made. It is naturally crushed stone, it is punky, and crumbles like Grandmas pie crust. if you have it on your land you got money in the bank. 90% of the roads around here are shale base. I don't think it would be sold if it was not bank run. take all you can get. That tractor you got will spread it around.
    How do you like me now?
  10. #20
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    When I hear "shale", I think "shell".
    Where we lived when I was little, Dad had a whiteish grey sea shell brought it to fill the driveway low spots. It kind of reminds me of oyster shells, but only about an inch x an inch and a half.
    It really hurt when you walked on it barefooted.
    hugs, Brandi
Similar Threads
  1. Oil & Fuel Bad loader cylinder, and some nasty oil......
    By nmu98 in forum John Deere Owning/Operating
    Last Post: 12-13-2008, 12:02 PM
  2. Bad Post ?
    By LOOPHOLE in forum News/Feedback
    Last Post: 08-02-2007, 02:26 PM
  3. What is your take on oil shale?
    By bugstruck in forum Oil, Fuel & Lubricants
    Last Post: 09-18-2006, 12:37 PM
  4. 3 Point Hitch PHD and shale
    By jhortonvt in forum Attachments
    Last Post: 12-07-2005, 06:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
