Results 1 to 7 of 7
07-27-2011, 06:04 AM #1New Member
- Join Date
- Aug 2009
- Posts
- 9
855 Pedals - no tension
Good evening all. This issue may be related to another thread I opened. Anyway the pedals on the JD have no tension at all. If I press the forward or reverse pedal it just depresses to the bottom of the range but doesn't return. There is not tension at all.
07-30-2011, 11:15 AM #2Platinum Member
- Join Date
- Apr 2010
- Posts
- 975
Re: 855 Pedals - no tension
You broke a spring. Go to the dealer and tell him what the deal is and he will be able to sell you the correct one.
Or the spring could have been knocked off by brush. Have you crawled under there and inspected?
07-30-2011, 11:07 PM #3
I agree, sounds like you lost a spring, here's what you are looking at inside the frame, if you get someone to move the pedals (motor OFF!!) while you look under there you will see if it's gone, or what isn't happening
07-31-2011, 09:14 AM #4Platinum Member
- Join Date
- Apr 2010
- Posts
- 975
Nice pictures! Makes me almost wish I had a 855 with a broke spring just so I could use them.
(almost)
08-01-2011, 02:06 PM #5Platinum Member
- Join Date
- Aug 2009
- Posts
- 858
- Location
- Kansas
- Tractor
- John Deere 755 purchased new in 1993
OP had same question in a different thread.
http://www.tractorbynet.com/forums/j...o-tension.htmlJD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
08-01-2011, 06:56 PM #6New Member
- Join Date
- Aug 2009
- Posts
- 9
Well guys, thanks for the information. I just logged on again after spending an hour on Saturday fixing the problem. It turned out to be a simple fix. I used the diaram posted last week to trace the issue. It had simply slipped out of gear (the end of the pedals had slipped out). I just raised the arm and pushed it back in and it started. What a relief. I then spend two hours mowing and another 2 hours mulching! It's a great little tractor.
Thanks to all for the advice.
08-02-2011, 11:35 PM #7Bronze Member
- Join Date
- May 2011
- Posts
- 50
- Location
- NE OH
- Tractor
- Kubota B2320 John Deere 318
Similar Threads
JD 855 Slow Transmission
By jimsing in forum HydraulicsReplies: 1Last Post: 11-29-2010, 09:09 AM -
By jimsing in forum Parts/RepairsReplies: 0Last Post: 11-28-2010, 08:06 PM -
My HST pedals locked up yesterday.
By jinman in forum New Holland Owning/OperatingReplies: 13Last Post: 10-09-2008, 02:27 PM -
Buying JD 855
By black46 in forum John Deere Buying/PricingReplies: 1Last Post: 01-07-2008, 10:01 AM -
Belt Tension on a Rear PTO Belly Mower
By srjones in forum AttachmentsReplies: 11Last Post: 04-21-2007, 03:00 PM
