Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 51
  1. #11
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,680
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST
    Default Re: Stump Yard Wars
    Like I have suggested before, put some C4 plastic explosive under the thing.....AND, if you use enough..... the stump will not be on your property when you are done....
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  2. #12
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,718
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by JerryK View Post
    Its a little close to the house for the explosives, though I am sure they would work really well, Just some more cutting of roots, I can see (maybe a better method of cutting, those things are huge) and it will be out.. probably gonna have to wait for a bit, I am out of town for a while. The loader is fine, and the little shovel worked well for what it is.. a backhoe would have been a lot better. But the shovel broke a lot of the smaller roots, and dug up a lot of rocks and dirt. There is no damage to the loader or bucket. Updates when I can work on it again..
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  3. #13
    Veteran Member tungularafishcamp's Avatar
    Join Date
    Sep 2010
    Posts
    1,584
    kodiak island, Alaska
    kubota L2800, 1/2 of a L48
    James, what about getting a old mobile home and tie it to the stump, next passing tornado should just come along and grab both of them
    Rick
  4. #14
    Join Date
    Jun 2009
    Posts
    27,718
    Branson, Mo.
    Quote Originally Posted by tungularafishcamp View Post
    Rick
    Along the same line, how about sticking an 8 foot copper coated ground rod in the top of the stump and wait for the next lightning storm. KABOOM.. kindling.
    James K0UA
    James K0UA
  5. #15
    Join Date
    Sep 2010
    Posts
    1,584
    Quote Originally Posted by k0ua View Post
    James K0UA
    You folks get all the fun weatherthunderstorms, tornados, and Dolly Parton too
  6. #16
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,276
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Quote Originally Posted by Ductape View Post
    If you need to weaken it by cutting some of the roots, I recommend using a sawzall with a pruning, or wood cutting blade. Or......... borrow a neighbor's chainsaw.
    Probably not f you want to stay on good terms with the neighbor.
    The sawzall is the best way.
  7. #17
    New Member
    Join Date
    Jun 2009
    Posts
    7
    Massachusetts
    Cub Cadet 129 Hydrostatic
    I have dug out Oak stumps on my property. There is not enough money in the world to have me do it for someone else...
    I did use my sawzall, with a 12 inch blade. (You can by a multi pack of blades for the same cost and damage repair efforts to driving your chainsaw into the dirt)
    The advantage of the sawzall is that you can dig below a bit, and cut the tap root.
    I did find that dragging hard on the stump sideways, then cutting on the other side make the cuts, especially those 1/2 in the dirt worked well. Each root cut let the stump roll a bit more. At first the movement is very little, but as you cut more, it will lay over more.
    I have not seen an easy way to do this on the cheap. Rent big stuff, or work hard. If it was easy, many of us would have less stumps.
    In reading some of the other responses, I am reminded of the movie 'Fandango' I think. Is there a train track nearby? Maybe you could wrap a chain around it, and have a large hook on the other end at the railroad track, and wait for a train to go by...
    Have fun.
  8. #18
    Join Date
    Feb 2004
    Posts
    2,680
    I got rid of a huge willow stump many younger years ago by digging all around it by hand. Even dug underneath it...all pick and shovel work. Then wacked all the roots I found with an axe. Took two 4 wheel trucks to yank it up out of the hole, even after I dug a half arse ramp for it to slide up. Every time I pass on of them 'pay to exercise here' places I remember that stump... old memories, or maybe it was old nightmares.
  9. #19
    Gold Member Stonehaller's Avatar
    Join Date
    Sep 2009
    Posts
    486
    Mid-Michigan
    Kubota L39
    A method I used to get out stumps with taps roots (before I had a backhoe) was to cut as many of the surface roots as I could easily get to then hook a chain around one of the larger roots and rap it part way around the stump so when I pulled with the tractor it would twist the stump. Sometimes I would have to reverse the chain rap to twist both ways to break the tap root.
    Kubota L39TLB
  10. #20
    Platinum Member DAY's Avatar
    Join Date
    Feb 2011
    Posts
    664
    Eastern PA
    Ford 4500 TLB, Kubota L2900GST
    If you have electricity at the tree (sawzall), you probably also have water. Then, if you have a pressure washer, you can get down in there and weaken the lifelong relationship between the roots and the soil.
    When my chainsaw guys says "this is the last time I can sharpen this one" it gets assigned to Root Detail.
Similar Threads
  1. Stump Wars....
    By JerryK in forum Projects
    Last Post: 07-27-2011, 10:29 PM
  2. Stump Burn with Blower and coal
    By chopped in forum Related Topics
    Last Post: 07-26-2011, 10:17 PM
  3. B7500 Vs. Stump
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 10-02-2002, 03:25 AM
  4. PT-1418 stump grinder spin direction?
    By davesisk in forum Power Trac
    Last Post: 04-22-2002, 10:38 AM
  5. Junk Yard Wars
    By Richard in forum Related Topics
    Last Post: 07-22-2001, 06:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
