Results 21 to 30 of 51
09-13-2011, 07:38 AM #21
Re: Stump Yard Wars
Hey now that's an idea, the pressure washer, I may give that a try, this weekend, I did hose off the roots some in an effort to see them better, and loosen things up, some of the larger roots had a large rock shelf under them..But all in all it is just a matter of time and effort, the stump is coming out, it just doesn't know it yet
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
09-13-2011, 08:37 AM #22Super Star Member
- Join Date
- Sep 2003
- Posts
- 13,491
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
Re: Stump Yard Wars
You should have soaked it for 24 hrs, and then cut the roots with something like this.
It can cut in any direction.J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done.
09-13-2011, 08:55 AM #23Veteran Member
- Join Date
- Jun 2004
- Posts
- 1,316
- Location
- KY
- Tractor
- Kubota L3830, Ford Golden Jubilee, AC B, '39 Sears Economy, Polaris Ranger 400
Re: Stump Yard Wars
two words. stump grinder!
09-15-2011, 07:56 AM #24
Re: Stump Yard Wars
The problem with a regular bucket is that it is too wide and you don't get enough force in a small enough area. A stump bucket is good at chewing into some of those roots and getting under the stump edge. Another way to get the tree down is to put a cable in the upper third of the tree and pull it over. Climbing a ladder in a tree is risky in my opinion to place the cable. Tree spikes are safer or a climbing deer stand.
Dave
"If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
09-15-2011, 05:08 PM #25
Re: Stump Yard Wars
What I've done in the past is to dig around as much as I can, then keep sawing away at it with an old bar and chain. Once you have it below ground level, cover it with landscape fabric to keep the suckers from coming back, and a layer of topsoil. Softwood trees aren't as bad as hardwood for regenerating.
Usually three or four sharpenings are enough to get through the average stump. I like the pressure washer idea to get some of the grit off the roots, but I think it would create a "stump in a pond" problem as a side effect.
Even a small backhoe won't get these out as fast as some of us would like, you've got to whittle away at the roots gradually. When you consider the work an excavator will do, they have a tough time with stumps too in some cases.
In the old days we'd pour a couple gallons of diesel/gas mix into the soil under it and light 'er up. Not the most ecologically responsible way to do things.
Sean
09-16-2011, 10:20 AM #26Super Star Member
- Join Date
- Feb 2001
- Posts
- 18,759
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Re: Stump Yard Wars
James, another tool that can come in really handy is a regular 1/2" drill and a large 3/8" to 1/2" drill bit. Make a series of holes in the exposed root around the perimeter like a woodpecker makes around the trunk of a tree, but drill up to the full depth of the drill shank. The drill will go into that soft root quite easily; just keep it well lubed. After you've weakened all the roots with the drill and reciprocating saw, you should easily be able to pop that stump out with all the trunk you have left for leverage.
Jim
09-16-2011, 08:01 PM #27
Re: Stump Yard Wars
09-17-2011, 06:07 PM #28
Re: Stump Yard Wars
It has rained all day today, (Lord knows we needed it) so no work today (Saturday). Looks like the stump lives for a while longer
James K0UA
09-17-2011, 07:08 PM #29Veteran Member
- Join Date
- Oct 2010
- Posts
- 1,081
- Tractor
- NHtd75
Re: Stump Yard Wars
After you get it out you can make something memorable from it. I was into making scotch tape dispensers to give away about the time I removed this oak. There is often an area of stump wood that has a unique pattern and out of that area within the square popped a dispenser.
Or you may be so aggravated you never want to see any of it except in the fire.
09-17-2011, 08:51 PM #30Kyle - CompactTractorFan
Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
Similar Threads
Stump Wars....
By JerryK in forum ProjectsReplies: 14Last Post: 07-27-2011, 09:29 PM -
Stump Burn with Blower and coal
By chopped in forum Related TopicsReplies: 1Last Post: 07-26-2011, 09:17 PM -
B7500 Vs. Stump
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 16Last Post: 10-02-2002, 02:25 AM -
PT-1418 stump grinder spin direction?
By davesisk in forum Power TracReplies: 9Last Post: 04-22-2002, 09:38 AM -
Junk Yard Wars
By Richard in forum Related TopicsReplies: 30Last Post: 07-22-2001, 05:40 PM
