Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Platinum Member bironacad's Avatar
    Join Date
    Jan 2011
    Posts
    604
    Southern Ontario, Can
    New Holland 3045/2010
    Default CVT tranny update New Holland 3045
    I tried to make this post awhile ago and it got lost in cyber space so if it appears twice my apologies.
    I was asked to update this forum as to how I like the CVT tranny after using it for awhile. I now have 130+ hours on the tractor and IMHO it has done more then I could have hoped for. I have put in a foundation, chipped brush, hauled logs, bush hogged and mixed cement with the new tractor and it has been a real treat. No stalling as some thought it might and the forward back leaver is not an issue. I particularly like push button the range selection. SO thumbs up for the new old tech, lol.
    Attached Thumbnails Attached Thumbnails CVT tranny update New Holland 3045-backfilled.jpg   CVT tranny update New Holland 3045-icf.jpg   CVT tranny update New Holland 3045-threepoint-mixer.jpg   CVT tranny update New Holland 3045-dirt.jpg
    “If at first you don't succeed, you are running about average.”
    M. H. Alderson
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Gold Member
    Join Date
    Jan 2007
    Posts
    283
    Hillsboro, NH
    Kubota L4310
    Default Re: CVT tranny update New Holland 3045
    I missed your initial post. Is this your first tractor? If not, how was the transition?
    Some mentioned / inferred that some dealers didn't perform adequate calibration - did you need to? or was the tractor already setup?
  4. #3
    Join Date
    Jan 2011
    Posts
    604
    I had a gas tractor, see my avatar, lol. There is definitely a change from gears to hydrostatic drives to CVT. There is a slight pause before engaging going from forward to reverse and a different feel that takes awhile to get comfortable with but once there it worked extremely well. This is my first cut tractor for sure but I really had my doubts when reading posts about the perceived differences between the hydrostatic and CVT. I have a cub cadet hydrostatic and it is a weird feeling with the lack of solid control going down an incline I don't get that with the CVT. It really does a good job with the dirt. I don't have teeth on the FEL but was able to gouge out and remove load after load of soil no problem. It sounds different and feels different but works great, lol.
    M. H. Alderson
  5. #4
    Elite Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    4,145
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    Quote Originally Posted by bironacad View Post
    Glad the CVT has been working out for you. I have yet to try one on
    a tractor....it does look like a very promising alternative to HST.
    I see you are using ARXX ICFs. Did you pour all the stem walls with your
    tractor mixer?! Or did you shute it or pump it?
    See my TBN projects at:
    http://mysite.verizon.net/resyfcgt/
  6. #5
    Join Date
    Jan 2011
    Posts
    604
    Quote Originally Posted by dfkrug View Post
    I have a bum ticker so I did the footing in stages (13+ yards) with the mixer. A few hours ever other day depending on weather and how I felt. Five cubic feet per mix, 70+ mixes, yikes so I pumped the 7+ yards for the ICF, lol
    Attached Thumbnails Attached Thumbnails CVT tranny update New Holland 3045-pumper.jpg
    M. H. Alderson
  7. #6
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,981
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    I have the same mixer and my ticker only keeps me guessing. All I know is, shoveling that thing full is a workout for me. How do you fill yours? Hoppers, or like me, with the 'hand operated backhoe?'
    The system isn't broken...
    ...it's fixed!
  8. #7
    Join Date
    Jan 2011
    Posts
    604
    Quote Originally Posted by Short Game View Post
    To load the mixer I was using a three\two\one mix, so to keep the proportions right I had sever drywall pails and filled them and dumped them into the mixer. For filling the footings I dumped into a wheel barrow or right into the form. Note the happy faces, lol, my cousins heart is worst then mine.
    Attached Thumbnails Attached Thumbnails CVT tranny update New Holland 3045-pails.jpg
    M. H. Alderson
  9. #8
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,981
    Sunny SW Washington
    Since one of the selling points of this mixer was that a full load uses one whole sack of cement, I developed a technique for adding the cement. When it's time to put it in, I toss it in, sack and all. Of course, I get someone to help me lift it. After just a few tumbles, the sack is torn open and emptied, and the paper comes to the top and I just pull it out.
    It's hard for me to believe now, except for my bad back reminding me, that I used to be a hod carrier, and then after that, a brick, stone, and block layer. Now I weigh 46 pounds more than a sack of cement and it hurts to put on my socks in the morning.
    ...it's fixed!
  10. #9
    Join Date
    Jan 2011
    Posts
    604
    As I often say it is not the age but the mileage. I chose wear out instead of rust out lol. Take it easy with you in spirit.
    M. H. Alderson
  11. #10
    Elite Member beppington's Avatar
    Join Date
    May 2010
    Posts
    3,940
    N Cent FL
    Kubota Grand L3940
    That is a great line!
    Please consider donating to the Cystic Fibrosis Foundation
    Kubota 3940
Similar Threads
  1. Tranny temp gauge sensor; where to put it?
    By RobertN in forum Trailers & Transportation
    Last Post: 07-30-2009, 01:32 PM
  2. Tuff Torq K66 tranny
    By CBR600F4I in forum Parts/Repairs
    Last Post: 05-08-2009, 03:18 PM
  3. Komatsu D31S basic tranny questions
    By Dcara in forum Construction Equipment
    Last Post: 04-07-2009, 06:15 PM
  4. Help with my Ford Ranger Tranny and Drive Shaft
    By JoelD in forum Parts/Repairs
    Last Post: 03-28-2009, 01:51 PM
  5. Don't be fooled by Microsoft Update eMail!!!!
    By Junkman in forum News/Feedback
    Last Post: 05-03-2004, 06:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
