Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Aug 2011
    Posts
    1
    Default Frontier Grooming mower compatible with iMatch?
    I have a Frontier 72 inch grooming mower and I just bought an iMatch. It says it's compatible but the literature talks about a "conversion kit." Is this just the set of bushings or something else? The mower doesn't appear to be compatible. Thanks, in advance, for your help.
  2. #2
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,273
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Default Re: Frontier Grooming mower compatible with iMatch?
    The Frontier mowers are (depending upon the year of manufacture) built by Woods (my 72" RFM is a Woods), BEFCO and others.
    My Frontier/Woods has the bushing kit installed to fit the iMatch hooks. The 3PH attach frame, when hooked on the iMatch, is fixed. The deck will pivot around the lower pins a bit, and there will be chains running aft from the uppr 3PH attach frame to near the aft section of the deck, rather then solid metal straps.
    Sorry, I don't have pictures of my mower on this computer, but it looks just like a Woods PRD7200 with the exception of the modifications listed above.
    How about posting a picture? One close up showing the 3PH frame in it's entirety would help.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  3. #3
    Platinum Member catdozer's Avatar
    Join Date
    Sep 2011
    Posts
    508
    Indiana
    Bobcat CT235
    Default
    This may help a little, its a woods but not in green, a metal strap will run from the lower links to the top link, then the metal straps from the top link to the rear mower is replaced with chain. This is how I use mine since I think it flexes better for mowing my trails.
    Attached Thumbnails Attached Thumbnails Frontier Grooming mower compatible with iMatch?-image-3350597848-png   Frontier Grooming mower compatible with iMatch?-image-126822769-png
    Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
Similar Threads
  1. Mowing JD iMatch compatibility with Bush Hog mower
    By NH_Dan in forum Owning/Operating
    Last Post: 09-15-2014, 05:21 PM
  2. Frontier Grooming Mower Price Check
    By jimccraig in forum Attachments
    Last Post: 04-04-2008, 12:09 AM
  3. Need a Frontier finish mower or spreader??
    By Shawk in forum John Deere Buying/Pricing
    Last Post: 12-30-2006, 12:15 AM
  4. Mowing Frontier Finish Mower
    By Kahuna in forum John Deere Owning/Operating
    Last Post: 12-29-2006, 10:50 PM
  5. Mowing JD 261 Grooming Mower
    By MikeSimpson in forum John Deere Owning/Operating
    Last Post: 05-16-2000, 10:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
