Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Feb 2011
    Posts
    18
    Deere 318
    Default Snowblower (Deere Model 49) Restoration
    Hello,
    I probably didn't get this post into its appropriate sub-forum or whatever. I apologize if this is in the wrong spot
    Anyway, my question:
    Just finished sandblasting and priming my snowblower. I am eager to get it all reassembled. I put on 2 coats of RustOLeum metal primer and so far 2 coats of the Valspar JD Yellow implement paint that Tractor Supply carries. My question is how many coats of paint would you guys apply? I was originally thinking I would put on many coats while its all apart and everything is easily accessible. But after 2 coats, it seems like plenty to me. And, I now remember that I #$ing hate painting
    Does this paint go on a little thicker than normal paint or something? Seems thick to me. I also did 2 coats of black high gloss implement enamel on the auger.
    So, more coats of paint or she's good?
    Thanks for any opinions!!
    Mike
  2. #2
    Join Date
    Oct 2009
    Posts
    146
    Default Re: Snowblower (Deere Model 49) Restoration
    wish i could help but really not sure. i would take my time and check other sources. you've already got the hard part done so don't rush it. i know how it is to want to finish a project and later became sorry i didn't put alittle more effort into it.
    steve
  3. #3
    New Member
    Join Date
    Nov 2011
    Posts
    3
    kubota b3000hsdcc
    hi i am caseyandlacey im just started would you tell me if i am here but i cant help you
  4. #4
    New Member
    Join Date
    Nov 2011
    Posts
    3
    kubota b3000hsdcc
    i am new cant help you but can u tell me if your getting this message
  5. #5
    Join Date
    May 2008
    Posts
    1,304
    Eastern Ia
    JD 4310 eHydro,
    If it looks good, I would stop.
  6. #6
    New Member
    Join Date
    Feb 2011
    Posts
    18
    Deere 318
    Mfreund, thanks for the reply. I did stop. She's 90% back together. And I took another look at the can, it's enamel, not paint. I don't know much about painting but assume that enamel is thicker? Makes sence now. So, everything got 2 coats of primer and 2 coats of enamel.
  7. #7
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default
    Quote Originally Posted by Gravel7
    That should be fine. Next spring, clean it up and check for chips and paint them. That's what I'm going to do with my blower that I just renewed.
    How about some pics?
  8. #8
    New Member
    Join Date
    Feb 2011
    Posts
    18
    Deere 318
    Default
    I do have a few pictures....I'll post them when I get home in a few hours. Thanks for the reply!!
  9. #9
    New Member
    Join Date
    Feb 2011
    Posts
    18
    Deere 318
    Default
    Snowblower (Deere Model 49) Restoration-image-2793107150-png
    First time posting pictures, hopefully this works. First one is a before shot. The rust was all through the inside.
    Snowblower (Deere Model 49) Restoration-image-3706657485-png
    Snowblower (Deere Model 49) Restoration-image-101172582-png
    Couple sand blast shots.
    Snowblower (Deere Model 49) Restoration-image-3658043162-png
    Primed.
    Snowblower (Deere Model 49) Restoration-image-4196197404-png
    Snowblower (Deere Model 49) Restoration-image-1879603725-png
    Snowblower (Deere Model 49) Restoration-image-3787644072-png
    All done!!
  10. #10
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Default
    Good job!
Similar Threads
  1. I need a lot of pictures of a John Deere Model A styled. Thanks
    By XIXO123 in forum John Deere Vintage Tractors
    Last Post: 12-31-2010, 09:06 PM
  2. Lambert Model HS-68P-1 Snowblower?
    By monkers in forum General Lawn & Garden
    Last Post: 03-02-2010, 05:23 PM
  3. Home Depot
    By BrokerBob in forum John Deere Buying/Pricing
    Last Post: 07-12-2002, 09:09 PM
  4. JD 5400
    By heehaw in forum John Deere Buying/Pricing
    Last Post: 04-10-2002, 08:17 AM
  5. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
