Short Game
I have a 12,000 lb. Warn winch on my box blade.
I learned this from another person's mistake: Do not use a winch cable for a tractor pull. Use the winch to pull, but then, only with the winch. The gears are built to handle the motor's strength, not the tractor's. Once the load is where the tractor will be pulling it, then drop it from the winch cable and attach it to the tractor. I saw a guy with a JD450C with a hydraulic winch pull a load with the winch cable using the tractor's drive. It ripped the gears out of the winch in a split second. It was an expensive lesson.
I pull lots of logs with the box blade. It has a receiver hitch right through the center of the blade. I hook to the trailer ball, as it is the lowest point on the box blade that I can hook a chain. Once the load is where I can get close to it, I reconnect short and lift the 3PH to raise the front of the log for easier towing. This has worked very well for me. I don't worry about a back flip with this method because the box blade would act as a wheelie bar.
When I'm winching, I often have to chain the front of the tractor to a tree to keep it put. I have been amazed how hard that winch can pull, especially when I hang a block and double up the cable. Still, the tractor in low range could overstress the gears in the winch. One, or the other, tractor or winch, but not both.
