Page 1 of 9 1234 ... LastLast
Results 1 to 10 of 87
  1. #1
    Bronze Member Machold's Avatar
    Join Date
    Jul 2009
    Posts
    99
    Wellandport, Ontario
    Kubota B3030 & B7400
    Default PULLING
    What is best for pulling? Do I attach my chain to the hook/clevis on the tongue; or can I attach it to a drawbar on the 3ph? Pulling logs, deadfall, stuff.
    B3030 FEL; B7400 MMM; F2560
    LP Grader, Kub Snowblower
    Wallenstein Chipper, Nicholls Landscape Rake 5ft
    SplitFire Log Splitter, Vintage Oliver Sickle Mower 7'
    www.machold.ca
    Stihl 009l; Jonsered 2138C; Makita/Dolmar DCS510;
    EFCO 165; Solo 656, Echo PAS w/pole saw
    Miller AC/DC Thunderbolt
    www.wainfleetwag.com -www.macdezart.com
  2. #2
    Gold Member BethesdaEC's Avatar
    Join Date
    Oct 2010
    Posts
    448
    Ellicott City, MD
    JD 2520
    Default Re: PULLING
    Get one of these and attach it to your draw bar.
    Drawbar Hook - 0268080 | Tractor Supply Company
    JD 2520 with 200CX, 46BH, BB1060 box blade and 54 front blade, Artillian forks, IMD 10K generator, Wallenstein BX42r
    Bob Cat FastCat Pro 48
  3. #3
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Default Re: PULLING
    Quote Originally Posted by Machold View Post
    Most on here will say to use the tractor drawbar(tongue as you call it), instead of the 3pt. for safety reasons.
    They claim that pulling from the 3pt. can cause flip overs.
    http://www.tractorbynet.com/forums/o...back-flip.html
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  4. #4
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,927
    Northern Vermont
    Kubota, Case, Deere
    Default Re: PULLING
    I use a 3pt cross drawbar with a twisted clevis.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  5. #5
    Veteran Member wedge40's Avatar
    Join Date
    Oct 2007
    Posts
    2,216
    Default Re: PULLING
    Keep the drawbar low and you should be fine..
    You did say puling not jerking?
    Just make sure there is some ground clearance on the log being pulled.
    Wedge
    1967 Ford 4000,Mahindra 4530 with FEL and BH, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple. Mahindra 4530, with FEL and Backhoe.
  6. #6
    Super Member
    Join Date
    Jul 2009
    Posts
    8,574
    SW WA
    Kubota BX2360
    Default Re: PULLING
    Quote Originally Posted by crazyal View Post
    I see both twisted and straight clevises in the stores. I've always used straight and can't recall ever having a situation where I needed a twisted.
    What are the reasons people use one or the other?
    Bruce
  7. #7
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Kubota B7800 with FEL
    Default Re: PULLING
    A twisted clevis attached to a draw bar is good for stretching fence. When you need two legs of the chain going vertical instead of horizontal.
    I used to do the Hokey Pokey but I turned myself around.
  8. #8
    Join Date
    Apr 2011
    Posts
    80
    maryland
    kubota g2460 Kubota L4330
    Default Re: PULLING
    I use the hook from Tractor Supply also. I have a grader blade on the 3pt hitch and run the strap or chain over the blade to lift the end of the log off the ground when I lift the blade.
  9. #9
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    Default Re: PULLING
    On my hydro-stat I always pull from the 3pth but on a stick shift I would never (unless it was a real light pull).
  10. #10
    Join Date
    Dec 2010
    Posts
    190
    Washington state and Ak
    5300 John deere,53 harry ferguson, ck20 kioti, 135 ferguson, 350jd dozer, k40 kubota excavator
    Default Re: PULLING
    for pulling logs and such it is easy to make one of these. I built this in a day for my quad and I also use it behind my 135 ferguson. It folds down to make a good trailer too. Would only use it on the drawbar though. Using the 3pt will rotate up as the frontend will come up if you have good traction.
    the one on my jd has a hyd winch, and some hooks on the lower crossbeam.
    Attached Thumbnails Attached Thumbnails PULLING-p1000337-jpg   PULLING-p1000162-jpg
Similar Threads
  1. Pulling with the Drawbar
    By Caretaker in forum Safety
    Last Post: 02-16-2015, 12:47 PM
  2. pulling weight???
    By c23380 in forum Owning/Operating
    Last Post: 01-13-2009, 01:58 PM
  3. 1958 Ford 841 temp rises pulling bush hog
    By floppy in forum New Holland Owning/Operating
    Last Post: 10-15-2008, 11:06 PM
  4. TC26DA No Pulling Power
    By HUCKthe1 in forum New Holland Owning/Operating
    Last Post: 09-23-2008, 03:21 PM
  5. Pulling technique
    By dbrienza in forum Projects
    Last Post: 08-28-2001, 11:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
