Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 53
  1. #11
    Join Date
    Oct 2011
    Posts
    54
    Michigan
    John Deere 2305
    Default Re: Help with a bulldozer
    This is a huge project you are taking on, I helped my friend work on a road through a swamp to his deer blind using a John Deere 450C dozer and 310G backhoe. We put two years into it working on it off and on before he finally said enough after many hours and a few hundred gallons of diesel. We also regraveled a road for his parents with the same dozer and it took us a full day with three of us. Me running the dozer, my friend loading with the backhoe, and my friends cousin hauling with a Chevy C60 with a 5 yard box. We spread the gravel 6in deep for about an eighth of a mile and it was a ton of work. Just make sure you want to go down this road(no pun inteded) before you start the job.
  2. #12
    Member
    Join Date
    Dec 2010
    Posts
    27
    NY
    Kubota L4240
    Default
    I just dont know how else to do it. I own the land and want to make it perfect for hunting.
  3. #13
    Join Date
    Jul 2004
    Posts
    1,985
    Bancroft, Ontario
    JD4300
    What part of the country are you in, how far is it accross the swamp, what was the swamp built on, what are you going to be driving on this road,(weight and width) etc?
    Ten years ago two of us built 1/4 mile of road accross a cedar swamp just using my JD4300 (FEL) and a couple of chain saws. Took about a month working 40hr weeks. That swamp was built on 1000yrs of beaver droppings but the road was only for occasional use by a pick up truck and Suburban, (Daily ATV or ski-doos) so we were able to make the road base out of corderoy then bucket in fill to cover it.
    A dozer would have been useless without a excavator and a fleet of trucks hauling fill.
    Built about 2 miles of road that year, mostly thru hardwood ridge country, and billed the customer for 1000hrs of tractor running time. Pretty well paid for the new tractor in 6 months.....plus had the time of my life at my new "job".
  4. #14
    Join Date
    Oct 2011
    Posts
    54
    Michigan
    John Deere 2305
    Quote Originally Posted by csharpe5097 View Post
    Is there a bottom to the swamp? The swamp we were building the road through had a bedrock bottom. If there is no bottom to the swamp the project is over before it even got started. There is really no other way to do it but just remember Murphy's Law and multiply x4 when using heavy equipment it's also not cheap to fix what get's broken either.
  5. #15
    Member
    Join Date
    Dec 2010
    Posts
    27
    NY
    Kubota L4240
    Default
    I live in upstate ny and the swamp has mostly birch trees. There is a foot if black dirt and then pure grey clay. Would an excuvator work better then a dozer. If so what size.
  6. #16
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    33,370
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    I want to make a road thru my birch swamp. What kind of dozer should i buy. I am going to have to push down alot of trees and not get stuck in the mud.
    Also be sure to make sure you have the proper permits if needed to move soil in a swamp before you buy a dozer. Swamps are usually wet lands and wet lands are usually covered under some laws. The fines could outweigh the cost of the dozer.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  7. #17
    Super Member
    Join Date
    Jul 2009
    Posts
    8,442
    SW WA
    Kubota BX2360
    Why do you need a road to hunt? Wouldn't cleared trails be good enough?
    Bruce
  8. #18
    Member
    Join Date
    Dec 2010
    Posts
    27
    NY
    Kubota L4240
    Default
    I need enough to get my kubota rtv through.
  9. #19
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,133
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    What I would do before I would spring for a dozer and find out the swamp is to swampy, hire out a dozer or try your backhoe. If he makes it awhile without any problem you might have him do the whole thing and be done with it.
    About 20 years ago I had to put a driveway through some swampy land and I had a guy with a D8 cat, I think it was, to do the work. I was really concerned about him getting stuck as he plowed into it. But he didn't hesitate and he didn't have any problems with it. I had 7 or 8 dump trucks hauling fill that had a lot of 6" to a foot in diameter rocks in it. The trucks would back down the driveway and the cat would just spread it around. After the boney type fill was brought in about 4-6" of road gravel went over the top. I never had a problem with it to this day and I would have bet I would have been sinking all the time.
    I don't think it would pay to put dirt as fill, but stoney fill would work. Depending where you are, that might be expensive hauling. I had to haul about 50 quad-axle loads in. Maybe you don't have to go as thick as I did.
    Then again, when somebody mentions swampy land, how swampy is that. It might be like quicksand or it may just need a foot or to of solid fill over the top.
    If it were me and I had a backhoe, I would get a couple trucks of boney fill and start at the beginning and see how it goes. You should be able to tell how muddy it is before you get in to much trouble. Keep a winch handy and keep us posted.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  10. #20
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,453
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    I have built some sections of corduroy road thru some wet holes using old RR ties that I could get for free. Not nearly as good as a rock base but alot cheaper and plenty good for my tractor. I know a man with a cedar stand that he is cutting. He has made about a hallf mile of corduroy road thru his swamp with cedar slabs and logs to run his tractor and winch on. It is a lot of hand work though.
    Attached Thumbnails Attached Thumbnails Help with a bulldozer-p1010855-jpg   Help with a bulldozer-wintercorduroy-jpg
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
Similar Threads
  1. Will box blade do this, or do I need a bulldozer?
    By Missouri Pioneer in forum Attachments
    Last Post: 11-10-2011, 03:15 PM
  2. Replies: 82
    Last Post: 09-08-2011, 03:24 AM
  3. homemade bulldozer
    By casetractor in forum Build-It Yourself
    Last Post: 04-08-2011, 08:21 AM
  4. JD 1010 bulldozer
    By philbuilt in forum John Deere Buying/Pricing
    Last Post: 01-07-2008, 10:29 PM
  5. Grading Anyone ever use a blade as a bulldozer?
    By JYD in forum John Deere Owning/Operating
    Last Post: 12-10-2007, 02:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
