Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    Default Easy Way to Mount Tire Chains
    I mounted my chains today and snaped a couple pictures for the benifit of anyone who is trying to find an easier way. This is not a novel or new approach. Many already use this well know method. It is almost to easy. I learned it here on TBN several years ago. Hope this might help someone else.
    Layout chains. Surface gripping side up. Run a bungy through the rim and hook each end to the chain. Drive forward pulling the chains up over the tire. Stop and arrange them once or twice. When you are all the way around and the joint is in a good location hook them together. They will be tight to the tire and easy to hook.
    Attached Thumbnails Attached Thumbnails Easy Way to Mount Tire Chains-mntchains1.jpg   Easy Way to Mount Tire Chains-mntchains2.jpg   Easy Way to Mount Tire Chains-mntchains3.jpg   Easy Way to Mount Tire Chains-mntchains4.jpg
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Join Date
    Jul 2011
    Posts
    956
    Central wisconsin
    International 2500a
    Default Re: Easy Way to Mount Tire Chains
    thanks for the pictures,makes a whole lot of sense.this would save a lot of time.
  4. #3
    Veteran Member wedge40's Avatar
    Join Date
    Oct 2007
    Posts
    2,024
    I dont have chains for the tractor. YET. And I heard of this method for awhile now. I've learned two valuable things from your post.
    1st. How easy it is get the chains on once laid out and aligned.
    2nd. I'm not the only who waits till we have 6 inches of snow on the ground before I start getting my equipment ready for winter.
    Wedge
    1967 Ford 4000, Box blade, straight blade, FEL, Rake, Bushhog, Backhoe, Jinma chipper, KKII tiller, Grapple.
  5. #4
    Platinum Member Mike476's Avatar
    Join Date
    Jun 2010
    Posts
    862
    Annapolis Valley, Nova Scotia
    MF 135 Z134 Continental, MF 1660 Cab
    Quote Originally Posted by wedge40 View Post
    Wedge
    Put me in that group too!
  6. #5
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    I read somewhere on here
    "Why put off till tomorrow what you can put off till the day after tomorrow"
  7. #6
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,758
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Excellent method with your style of rim.
    Unfortunately my rims do not have those spaces to pass the bungee cord as mine are welded all around and no holes.
    I do however use bungee cords but in a much more complicated way, so much so that I am tempted to weld a couple of 1/2 washers to have something to hook on.
  8. #7
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    I used to use a 6' piece of 1/4" rope to make a long loop tied to the chains. I would hook the loop into the tire lugs on top. But you probably need Ag tire for that to work.
  9. #8
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    5,246
    north idaho
    dk45se hst cab
    I simply lay out the chain behind tire, then jack up the rear axle. hook a link of the chain in the tire lug and roll the tire. the chain pulls itself up the tire. Hook, tighten and lower tractor.
    I used to chain up my truck the way your showing here, but mu 2 link tire chain for my dk45 is all 3/8" chain and weighs a &^%$ of alot. i tried to do it this way first time, but couldn't lift the chain up and under the fender.....too tight and too heavy.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  10. #9
    Veteran Member rekees4300's Avatar
    Join Date
    Feb 2010
    Posts
    1,963
    Indiana
    JD4300 HST 4WD
    Quote Originally Posted by Gordon Gould View Post
    That method also works with R4s.
  11. #10
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Quote Originally Posted by grsthegreat View Post
    I guess I don't understand. Whats to lift
Similar Threads
  1. Tire Chains, Home Made Anyone done it?
    By CowwFace in forum Build-It Yourself
    Last Post: 12-18-2010, 12:06 PM
  2. Traction Tire chains in transit. Can't wait!
    By Marveltone in forum Owning/Operating
    Last Post: 11-21-2010, 09:13 PM
  3. Are rubber tire chains better than steel tire chains?
    By tacarima in forum Owning/Operating
    Last Post: 05-09-2010, 07:45 AM
  4. Chains types of tire chains
    By Dale1995 in forum John Deere Owning/Operating
    Last Post: 01-02-2009, 11:32 AM
  5. Tires tire size/ratio, replacement discussion, big repost
    By BrettFF205D in forum Yanmar
    Last Post: 03-24-2002, 08:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
