Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
  1. #21
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Default Re: Store diesel in plastic?
    I have always wondered about this. Plastic is an insulator and any electrical charge the builds up in the fuel is stored. The can is much like a layden jay. I always figured there was more to it then that. But given the current crop of worthless spouts it makes we wonder.
  2. #22
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Another thought... many fullsize trucks and SUV's, both gas and diesel, have 30 to 35 gallon PLASTIC tanks and people park them in their garages every day without a second thought. In the event of a fire, how is that any different than a plastic drum of fuel stored in the garage?
  3. #23
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    more than 1 type of plastic....
    styrene melts in fuel.... truck air line plastic lines take diesel no problem .... types 1 thru 6 ... each has it's use.
  4. #24
    Gold Member BigMike50's Avatar
    Join Date
    Mar 2013
    Posts
    391
    Uranus
    2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
    Quote Originally Posted by Sutol View Post
    I store diesel and petrol in plastic containers, no chance of sparks
    My car has a plastic diesel tank
    you can put a cigarette out in diesel fuel.
  5. #25
    Gold Member Recoveryhill's Avatar
    Join Date
    Sep 2010
    Posts
    399
    St. Croix, Virgin Islands
    Kubota L3700SU
    Quote Originally Posted by dynasim View Post
    It is odd to me, though, that you can't buy small metal fuel containers, and believe their absence flows from the stupidity of standards writers(mainly epa sourced). Again, I could be wrong.
    Chris
    It is against OSHA rules to have fuel and other flammables stored in plastic on job sites or manufacturing plants, etc. You must use metal cans. They are widely available but cost a lot more than plastic jugs. Justrite Mfg. Co. L.L.C. - Safety products
  6. #26
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,781
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154S
    I am not a big fan of storing any fuel in any container that is not kept full as much as possible, including your gas or fuel tank on your vehicle...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  7. #27
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,969
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Store diesel in plastic?-img_0946-jpgI store 26 gallons when the tank is full of diesel in one tractor (photo) and 8 in the other, one on each side of my shop. Then I have 100 gallons of diesel in a steel tank(when full) plus my plastic gasoline 5,2.5 &1 gallon ones on a shelf directly over the fuel tank. I keep my fuel in the boat /lawnmower storage shed with few spark producing agents (electric lights, battery tenders only) Gasoline containers are the air tight new style so no fumes get out of them and the steel diesel tank is unvented and pretty tight so no fumes come out of it either although the side will ping sometimes when they expand or contract with the temp changes. I don't worry about fire melting the tanks because if something does catch fire with enough intensity to melt the plastic, a little more fuel is not going to change the outcome which would be a totally destroyed building.
    I saw my friends house burn to the ground except for a couple of sheetrock wall when his boat caught fire from some faulty wiring (we think) which then set his attic on fire. He was directly across the road from the volunteer fire department and there was nothing they could do, it burned so fast that by the time the firemen had assembled it was past saving. I am at least 5 miles from the fire station and I for sure wouldn't stand a chance of saving anything from a fire therefore I keep my insurance policy up to date.Store diesel in plastic?-putting-slate-shop-june12_10-jpg
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  8. #28
    New Member
    Join Date
    Mar 2013
    Posts
    8
    Montgomery, TX
    JD 2320
    Recovery your correct. On our rigs OSHA will not let any petroleum or combustible substance be in plastic due to static electricity being store on plastic. Without the container conducting ground it cannot be discharged. That being said I have never heard of one instance where an explosion occurred. It is driven from the industrial side such as in plants (not the living kind).
    plastic fuel tanks on mechinery, car, tractors are connected to ground through wiring. But then you have lawn mowers with plastic without wiring, I have one. This is the same govt that tells us they can help us make every decision because they know better than us what we need. Ha.
    Quote Originally Posted by Recoveryhill View Post
  9. #29
    New Member
    Join Date
    Mar 2013
    Posts
    8
    Montgomery, TX
    JD 2320
    Gary-I am okay with plastic containers for fuel storage. As you have stated it is more about where you store the containers. A metal can can cause the same about of damage as plastic. This is a discussion that has endured a long time. Simply put use what you feel is right by evaluating the comments and focus more on where it is stored.
    Today shreaded wheat is good for you, but next week someone might choke on it and then it will be labeled dangerous.
  10. #30
    Epic Contributor jerrybob's Avatar
    Join Date
    Mar 2010
    Posts
    21,437
    Somewhere in Washington
    yanmar 186D....JD LT180....DR Brush Cutter
    Quote Originally Posted by BigMike50 View Post
    True....but.....smoking is bad for your health and not recommended by the surgeon general. I am surprised the government does not require a warning label on diesel storage tanks indicating the danger of putting cigarettes out in diesel fuel.
    Most of the stuff people worry about.......ain't never gonna happen anyway!
    Tacocat spelled backwards is Tacocat
Similar Threads
  1. diesel fuel additive??????????
    By whitearrow in forum Oil, Fuel & Lubricants
    Last Post: 04-27-2012, 12:34 PM
  2. 2008 Trans Mule diesel rear plastic fenders stress cracking
    By nickel plate in forum ATVs & Utility Vehicles
    Last Post: 04-03-2010, 11:28 AM
  3. Plastic drum OK for diesel?
    By AndyR in forum Oil, Fuel & Lubricants
    Last Post: 11-07-2009, 07:46 PM
  4. Replies: 64
    Last Post: 04-05-2009, 12:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
