Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
  1. #11
    Platinum Member bucktaker's Avatar
    Join Date
    Apr 2010
    Posts
    907
    Sw Ohio
    Kubota L5740
    Default Re: Making hay with 30hp tractor
    it will not be fun....been there done that baling hay with sickle bar, rake, Jd 24t baler with a mf 35... still have it all if you are near ohio and interested
    Take my advise buy a bigger 2wd tractor , haybine, rake, and round baler . you can do it your self with no additional labor.
    Kubota L5740 La854
    MF 35 Deluxe gas wloader...For sale
  2. #12
    Join Date
    Dec 2011
    Posts
    72
    Ford 1900
    Thanks, bucktaker, yeah it definitely isn't easy work but luckily I have a retired father that is just itching to do something. He's been out of the farm routine for a few years but would love to run machinery like this. Like I said and my uncle has always said, when you have a field or 2 to do and have most of the summer to do it, it really isn't bad. He now stresses every summer because of the 5,000 square and 500 round he has to have done before fall, with machines that are going to break, and in between rain storms.
    Feel free to pm with prices for the sickle, rake and square baler...
  3. #13
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,193
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    We made hay with a little IH 240, and Super C Farmall for about 12 years, pulling a JD 14T baler, and wagon that would hold approx. 60 bales. Made around 500 bales a year. No not fast, but a LOT faster and easier, than when we doodled it, and stacked by hand.
    I still have all of the above, and make about 40 squares, to take horse camping.
    My now IH 656, haybine, tedder, and 335 JD round baler makes it seem like another quantum leap with the haymaking.
    Probably as modern as I'll ever get, unless I replace the ole' IH 990 haybine. I just make 50-75 round bales for my horses, depending on the year, and hay yield.
  4. #14
    Join Date
    May 2007
    Posts
    704
    SW OH - near Dayton, OH
    1978 Kubota L285, 1951 Farmall h, 1946 Farmall m, 1950 John Deere A, 1953 Ford NAA Golden Jubilee, 195? Ford 850, 1948 Case DC
    Quote Originally Posted by Doyle670 View Post
    I have looked high and low, far and wide for an answer to my question. I have read thru forums, websites and anywhere else I thought might help.
    Does anyone know if you can make hay with a 30hp tractor?....
    You must not have searched too much - There is literally thousands of hours worth of reading on this subject with careful searching on forums like this one and Yesterday's tractors. Search under tractors like Allis Chalmers B, C, CA. Farmall A, B, C, and H. Ford 8N, 9N, 2N, Jubilee, NAA, 600 etc. John Deere B, 40, 50, etc.
    In short: Lots and lots of hay has been put up with under 25 hp and NO LIVE PTO. You will hear both success stories and horror stories.
    The key is picking a low capacity baler that will properly work with your limited hp. While new balers are available that are especially made for tiny tractors they are pricey ($15k plus new). So the cheap alternative is too look at balers from the late 1950's and early 1960's for when the farmer's common tractor was small. While very affordable a vintage baler will be 40-50 years old and will likely require some tinkering to keep working so you better be mechanically inclined. Modern square balers from the mainstream manufacturers are usually high capacity and therefore need lots of hp so are not good choices.
    Here is my kubota L285 compact tractor (26.5 max PTO hp at WOT, only around 23 PTO hp with throttle set for 540 PTO rpm). My Kubota does not have live PTO either. For comparison sake this tractor is a tad smaller than your Ford 1900 and a tad bigger than a Ford 1700. It would sorta be a Ford 1800 if Ford had built one - LOL. The baler is a 1960 New Holland 65 compact baler.
    These are actually the wife baling and raking and she conveniently spray painted herself out of my pics - she hates cameras!
  5. #15
    Join Date
    Oct 2011
    Posts
    184
    Greene, NY
    TL80a, Ford 4000, Super H, F 12, F14
    Doyle,
    I started baling in the late 50's with a nh 68 baler w/ 15hp wisconson motor with a wagon behind on hills pulled with a Super H w/ maybe 28 hp. We also conditioned hay with a Farmall F-12 (12-15hp maybe!) I would suggest a 7' haybine on your tractor if you could find one. Amount of hay on the fields matters also - ours run 100-125 bales/acre. You may also want a tedder. I now use a 489haybine, tedder, 55 rake, JD 336 kick baler, and have pulled it all with a Ford 4000. A 7600 or TL80a is now being used on the baler except when they are broke - but that is another story.
    Bob
  6. #16
    Join Date
    May 2007
    Posts
    704
    Quote Originally Posted by Sawdustsmb View Post
    Doyle,
    ...I would suggest a 7' haybine on your tractor if you could find one....
    IMOP: haybines or mower conditioners are typically not well suited to using on a small compact tractor. They are extremely heavy, they are offset 7-9 foot off the center line of the tractor draft which creates a weird pull, and most importantly they and have an enormous amount of tongue weight which makes them rough for a compact to physically handle safely even if there is adequate PTO hp to actually operate it. None of this is an issue on a normal farm tractor of sufficient size and weight, but can be an issue on a lighweight compact.
    Cutting with a compact is best handled with an old school traditional sickle mower if wanting to go cheap route. Of course a compact tractor can easily handle a small pull behind vintage crimper on a seperate trip - but that means another pass has to be made over the field. Alternatively drum mowers seem to work extremely well although I have never used one but they are available for compacts and reasonably affordable - although too pricey for my hobby operation.
    I have ran a 9 foot Hesston 1120 mower conditioner (sickle cutter with built in crimper rolls) and there is no way that I would hook it up behind my little kubota just due to the extreme size and weight of it.
  7. #17
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,104
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default
    According to Tractor Data, your Ford is almost exactly the same weight as a Farmall H and it tested at 26 PTO HP, the same as the belt horsepower of he H. Dad sold NH and the Hayliner 67 or 68 with a Farmall H or M was very popular in our area. The only problem was no live PTO on the H or M and low gear was pretty fast for large windrows. We got a Case 400 Super Diesel with live PTO for pour own haying, about 300 acres per year back then. Only thing I can think of being a problem is your Ford has a small Shibaura diesel that probably runs 2500 rpm at PTO speed while the H is a larger displacement engine turning only 1650 rpm at PTO speed. The numbers say it should not be a problem but you never know for sure until you try. When we started selling mower conditioners it took an M to pull a mower/crusher combination. The H could pull either the mower or the crusher but not both. That could indicate a 7 foot Haybine would be a bit much for your tractor. Anyway that is how we did it 50 years ago.
    Kubota M7-171, L6060, RTV 900XT, GR2120
  8. #18
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    You will be fine as long as you take your time. Growing up we always had a couple cows and one or two horses and my dad baled his own hay. The only tractor he had (still has) is a little kubota B8200 which is around 15 pto hp i think. He used all old equipment sickle mower, rake (3pt & pto driven), crimper, and NH baler converted from pony motor to pto. He has some very hilly ground and we had to be very careful with the rake and especially the baler. It wasn't nearly as fast as the neighbor with his cabbed Case and kicker baler with a wagon behind but we baled a lot of hay over the years.
    I have very fond memories of working out in the field with my dad, started helping him when i was barely big enough to lift a bale and helped him every year after that. It's a good feeling getting out in the field and baling hay.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  9. #19
    Join Date
    Dec 2011
    Posts
    72
    Ford 1900
    Quote Originally Posted by rankrank1 View Post
    Well I've found a bunch of topics for the older tractors but the problem is I know they changed how they rated the hp on newer tractors. I couldn't find any topics where a newer(>70's) 30hp tractor was running a baler.
    I guess I really just have to try it out. Worst case scenario, I'll have to buy a bigger tractor. Hopefully not.
  10. #20
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,402
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    You can do it. People have used small tractors like a Farmall Super A to pull a 2-twine small square baler like a JD 14T or like the one I have--a Massey Ferguson 124.
    Here's what I use on my 10 acres (flat pasture)
    Baler--MF124 2-twine small squares - $2000 (bought it right out of the field-previous owner baled 30 acres the day before)
    Sicklebar mower--MF 31 (7 ft)- $550 at auction plus $200 new parts
    Rake--JD 350 pto driven, 3pt hitch style - $800
Similar Threads
  1. Buying the first Test Tractor
    By JOHNTHOMAS in forum Kubota Buying/Pricing
    Last Post: 04-12-2013, 08:03 AM
  2. Bad Oil New Tractor
    By broker than broke in forum Buying/Pricing/Comparisons
    Last Post: 12-23-2010, 08:25 PM
  3. 7520 problems AGAIN...
    By CuzPat62 in forum Mahindra Owning/Operating
    Last Post: 07-15-2007, 07:55 PM
  4. GC-2310 Update -- The latest and greatest
    By Mike_in_Okla in forum Massey Ferguson Owning/Operating
    Last Post: 03-19-2006, 01:51 AM
  5. My BAD tractor buying experience
    By A_non in forum Buying/Pricing/Comparisons
    Last Post: 04-18-2004, 11:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
