Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 80
  1. #11
    Elite Member
    Join Date
    Aug 2011
    Posts
    2,687
    Earth
    Deere
    Default Re: I think I really messed up new tractor
    These are very small pics but from what I see the loader itself is not damaged, only the QA system, as others have mentioned. This is a difference between $3,000-$4,000 and $300-$400. All that would have to happen is pull the pins and put a new QA system on.
    My guess to what happened is you forgot to put the QA lever down and it came off or it raddled out of position. This shouldn't have happened though and if you have a good dealer (or the kubota insurance) you won't be paying anything
  2. #12
    Gold Member
    Join Date
    Jun 2010
    Posts
    291
    This looks like what happened to my tractor.....I was told it bent (torqued) the tube that connects both sides to the front end loader...
    The cost to repair was four hundred fifty dollars....I couldn`t see where the machine shop cut the tube and re welded, as they are a very good machine shop....I`m sure if you get involved personally and take it to a competent machine shop you would save some money...I had to pay for the transportation and profit for the dealer who did the details.....Tony
  3. #13
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,571
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Welcome to TBN. Well that sure ruined your day. Take some better pics so we can all see a little better. I would check with Kubota Tractor Insurance they may very well cover this. If they do not cover this you may be able to cut the torque tube, realign the quick hitch and then weld it back.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #14
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,149
    north idaho
    Kioti DK45SE hst cab
    Quote Originally Posted by MartianTractorMan View Post
    i dont think the amount of damage would even exceed the deductible on any insurance. More than likely if the QA is damaged it could be straightened and strengthened pretty cheaply.
    it almost looks like you could just straighten it out without any major effort at all. I have had one side contract more than the other side on other tractors before, and all i had to do as fully retract both sides to level it out..even if a little brute force was necessary.
    then again, i might revise this thought if i could see better details.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  5. #15
    Veteran Member Hooked_on_HP's Avatar
    Join Date
    Dec 2005
    Posts
    2,050
    Coal City IL
    Ford 1900 FWD Kubota F2100E
    If you bought the tractor and grapple from the dealer and it came unhooked because of a loose fit I think the dealer is responsible for the repair. There have been a lot of posts about quick attaches not matching up properly. The end result is what happened to you. When you get it repaired check the rest of your attachments fit propperly.
    Bill
  6. #16
    Platinum Member mcd176's Avatar
    Join Date
    Nov 2007
    Posts
    500
    Wheeling, WV
    Kubota M6800HD / Kubota B2150
    First of all Welcome to TBN, I am sorry for your misfortune. I agree with some of the others, before I did anything I would contact your dealer if you purchased the tractor and grapple from them, looks like a bad fit.
    Kubota B2150
    Link to my custom cab: http://www.tractorbynet.com/forums/b...completed.html
  7. #17
    Gold Member jcliburn's Avatar
    Join Date
    Apr 2009
    Posts
    282
    Lawrence County, Mississippi
    Kubota MX5100
    Same thing happened to me last February when my grapple detached on one side while clearing heavy brush. (One of the quick attach pins came unlatched when a limb hit the latch arm.) The tube that connects the two SSQA plates got bent as a result of the uneven load.
    I cut the tube in two places, then fully curled the SSQA to ensure the plates were inline, then welded the tube back together. Nary a problem since then.
    http://www.tractorbynet.com/forums/o...ng-game-3.html
    http://www.tractorbynet.com/forums/w...me-repair.html
  8. #18
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,293
    South Central Iowa
    TYM 330 HST with FEL
    I would just twist the QA the other way. I would use the tractor hydraulics to do so. I would put a stop on the left cylinder so it could stay few inches extended and then curl up. Alternatively you could chain the right cyclinder to prevent it extend and curl down. It should twist the QA straight. The QA is not torsionally too stiff as the strength is provided by whatever is attached to it.
  9. #19
    Join Date
    Apr 2009
    Posts
    282
    Kubota MX5100
    Quote Originally Posted by Redneck in training View Post
    None of that worked when it happened to me. Might work for the OP though...
  10. #20
    New Member NCCrestonMtn's Avatar
    Join Date
    Jan 2012
    Posts
    5
    North Eastern NC
    Kubota L3800
    The dealer I purchased both from has gone out of business. I do have the kubota insurance so I will have to check with them regarding coverage. Here are better picks. I really appreciate all the great input.I think I really messed up new tractor-leftbentqa-jpg
    I think I really messed up new tractor-frontbentqa-jpg
    I think I really messed up new tractor-rightbentqa-jpg
Similar Threads
  1. Buying the first Test Tractor
    By JOHNTHOMAS in forum Kubota Buying/Pricing
    Last Post: 04-12-2013, 08:03 AM
  2. Bad Oil New Tractor
    By broker than broke in forum Buying/Pricing/Comparisons
    Last Post: 12-23-2010, 08:25 PM
  3. Tractor Failed To Start/White Gunk in Fuel
    By dmccarty in forum Oil, Fuel & Lubricants
    Last Post: 06-30-2010, 07:54 AM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 10:56 AM
  5. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
