Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 80
  1. #21
    Gold Member AGGIE00's Avatar
    Join Date
    May 2010
    Posts
    473
    Default Re: I think I really messed up new tractor
    What you have there looks to be pretty minor. The torque tube between the plates seems to be torqued and if cut, realigned and rewelded would be good to go. At the very most replace the quick attach. You still need to diagnose why it came loose in the first place.
    MY2012 John Deere 5083e-563 FEL, 2008 CAT 272C with 60" Bradco Mulching Head
  2. #22
    Gold Member jcliburn's Avatar
    Join Date
    Apr 2009
    Posts
    282
    Lawrence County, Mississippi
    Kubota MX5100
    My gosh, that's a clean tractor!!!
    You can check to see if your loader arms are bent by removing the SSQA frame and lowering the loader onto a level surface. I bet they aren't bent though. I think you've just bent the tube that connects the two plates.
    A new SSQA frame for my loader (LA844) was about $690 a year ago, but like I said earlier, I repaired mine instead. It works fine.
  3. #23
    Super Member
    Join Date
    Feb 2002
    Posts
    5,225
    western,pa.
    Kioti DK 35
    Its just the QA torque tube thats bent.
    Its a simple fix. Cut the tube off, get everything back to straight and weld the tube back in.
    Vince,
    Kioti DK 35
    Hustler Super Z
  4. #24
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,036
    north idaho
    Kioti DK45SE hst cab
    yup, like i thought. it looks like a real easy repair to me.....i personally wouldn't cut anything, id just first try to pull it the other way to re straighten it. chains and binders or hydraulics would work.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  5. #25
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    It looks like just the quick attach, it can be straightened.
  6. #26
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,198
    South Central Iowa
    TYM 330 HST with FEL
    Quote Originally Posted by NCCrestonMtn View Post
    The dealer I purchased both from has gone out of business. I do have the kubota insurance so I will have to check with them regarding coverage. Here are better picks. I really appreciate all the great input.Attachment 244610
    Attachment 244609
    Attachment 244611
    Curl the QA in such a position that the cylinders are about perpendicular to it. You will have the best mechanical advantage. Then chain or some other way restrict extension of the left cylinder and curl down. You should be able to twist the cross-member back to original shape.
  7. #27
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,893
    Northern Vermont
    Kubota, Case, Deere
    If you have kubota insurance I would just pay the $250 and have a dealer look at everything. It's possible you might have done damage to the grapple and loader and it would cover that too. It doesn't look hard to fix yourself if the money is an issue but if you don't get it straight you could have problems with the QA.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  8. #28
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,208
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Welcome to TBN.
    You can try to straighten things out. If unsuccessful then use a welder to fix what can't be straightened, including possibly cutting and welding the torsion tube back to straight. You may still have to replace the QA pad, but you'll find out when all is done. Your right hyd cylinder is down to the loader arm and hopefully not bent at all or twisted. Make sure to check where the cylinder mounts at the top of the loader arm to see if the brackets are out of line at all.
    When done you now know not to try to lift such a long load with the grapple. The sway on a long log- 30' or so can really exert drastic racking force on the loader arms, as in your case, and if you got it too high off the ground would lift one of your rear wheels off the ground in virtually no time in an attempt to flip the tractor entirely; so be careful going forward from this point and cut trees into more manageable size, and keep the center of gravity low by keeping the larger logs close to ground until you have more hours on the clock.
    Also use adequate ballast on the rear of the tractor.
    FWIW, the original pics can be seen better by clicking on them and pressing the control and + buttons to expand the size of the pic on your screens
    Second set was better though....
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  9. #29
    Platinum Member wcampbell47's Avatar
    Join Date
    Jul 2009
    Posts
    706
    Texas Coast
    Kubota B7510 and L3901
    I have a new B3200 with the "braceless" loader and a 5 year old B7510 with a loader that has a brace or bar from sidearm to sidearm just in front of the steering wheel.
    The older loader seems much more sturdy than the new. As long as I am picking up a balanced load the B3200 seems ok, but it sure twists more than the older one if most of the load is on one side.
    Is it possible that more pressure on one side caused the loader arms to "twist" allowing the grapple to become disconnected. That combined with a loose fit either a bucket or grapple seems like a bad recipe.
    Caution: Some of my posts may be politically incorrect.
    Kubota B7510 & L3901
  10. #30
    Gold Member North Country's Avatar
    Join Date
    Apr 2011
    Posts
    368
    VT
    John Deere 2305
    Quote Originally Posted by Redneck in training View Post
    If it bends back to neutral using just hydraulic pressure, then it's been weakened too much and will bend again under normal loads.
    NC
    My hills have hills.
Similar Threads
  1. Buying the first Test Tractor
    By JOHNTHOMAS in forum Kubota Buying/Pricing
    Last Post: 04-12-2013, 09:03 AM
  2. Bad Oil New Tractor
    By broker than broke in forum Buying/Pricing/Comparisons
    Last Post: 12-23-2010, 09:25 PM
  3. Tractor Failed To Start/White Gunk in Fuel
    By dmccarty in forum Oil, Fuel & Lubricants
    Last Post: 06-30-2010, 08:54 AM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
  5. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
